Question about GE Profile PB970 Electric Kitchen Range
Front panel lettering erased
I have a stainless steel PB970 range and the "diagrams" and lettering around the knobs erased. Is my only option to change the entire front panel (if so, what is the part #) or do I have any other options?
2 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: I have GE XL44 white gas oven and range I want
Yes. But you probably won't like the price.
Do to repairclinic. com and put in your model number to check for parts.
Posted on Jan 03, 2010
How do I replaced the control panel on a GE profile stove JGS905? The words are all coming off and it looks bad.
Hello. Part designation 18 on the exploded parts diagram is the control panel assembly. The part number is WB36T10666. The knobs pull straight off of the valve shafts. There are 4 black glass retainers that screw onto the valves which hold the control panel firmly. These will have to be removed(unscrew them counter-clockwise carefully because they can cross-thread easily. Be especially careful when replacing them!!) Take pix as you go if needed and make a diagram if you have to. It's not that hard to replace the panel. I hope I helped you!
Sep 07, 2015 | GE JGS905SEKSS Stainless Steel Gas Kitchen...
Can a dent at the front of a steel oven be fixed?
probably not perfectly, but you can order a new panel
Dec 24, 2014 | Stainless Refrigerators
Letters wearing off stainless steel
depending on the appliance and series you could replace the logo or of its etched on and came off ET al designer series, you would have to replace top for cooktop or door for fridge or door panel for oven or range . Model serial helps pin the answer more specific . Hope this helps
Dec 06, 2012 | Dishwashers
What is best way to replace the touchpad and computer on a whirlpool # GE397LXUB05?
make sure the power is off,open the oven door,look up and remove any screws that's holding the control panel in place.remove the knobs and if any screws are in the side of the control panel remove them.you should be able to access everything from the front,just take your time,look around and remove the screws holding down the control panel,i just worked on one this morning,there was three screws on the bottom and one screw on each side and the control panel came off but it was a different model number but i got at everything from the front.good luck with your machine
May 20, 2011 | Whirlpool GW397LXUS Stainless Steel Gas...
I would like to replace the front panel with a stainless steel panel. Where can I find one. Thank you
ApplianceArt.com has many stainless options included custom stainless panels for dishwashers. They also have faux stainless options
Nov 13, 2010 | Frigidaire 24 in. PLD2850 Built-in...
I have GE XL44 white gas oven and range I want to know if replacement parts available so I can replace the door and front knob panel with stainless steel parts
Jan 03, 2010 | GE Kitchen Ranges
Front left element is in run-away mode; it keeps cycling on and off when the knob is in the off position.
The knob (also called thermostatic control) is stuck/broken. The burner is going on and off just as it does when it's in normal use. Just can't turn it off. Will probably need to replace the thermostatic control -- not easily repaired.
Charlie
Aug 23, 2009 | Frigidaire FEF366EC 30" Freestanding...
Want to replace dishwasher panel with stainless steel
I'm not sure if that replacemetn part would work, but I know you can get cheap stainless panels and faux stainless options at applianceart.com. They have colors, textures, seasonal, designs, and stainless steel. You can choose between faux stainless (as seen on HGTV and the Today show) or regular stainless metal. check out www.applianceart.com
Jan 19, 2009 | Kenmore 13593 Stainless Steel Built-in...
GE Profile PB970 Electric Kitchen Range Logo
22 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
