Question about Canon SELPHY CP720 Printer
I'm trying to get my printer to work without using the tray
MY Epson WF-3520 will not print from the rear paper feed.
Try reloading the drivers for you printer for XP, un-install the windows 7 driver and install xp. check the Epson web site for xp drivers if available.
Apr 06, 2015 | Epson WorkForce Office Equipment &...
My Canon MP470 was working fine, but then it sat for a few months without being used. I put in some new ink cartridges and tried to use it, but it keeps giving me a paper tray error. Telling me to loa
No. There are not normally rubber bands in printers. There may be a rubber belt but they are a little more difficult to remove than just falling out. They normally have a tread on the inside of the belt and a smooth exterior.
As for paper tray errors. If it is not picking up that there is paper in the tray then there may be something else stuck in the paper feed system.
Aug 28, 2014 | Canon PIXMA MP470 All-in-One Printer
Printer shifts from normal paper tray to mp try
Change the tray select from Auto to Tray1 in printer properties.
Hope that solves
Apr 28, 2010 | Office Equipment & Supplies
One of the paper tray hinges is broken
Contact Canon or order through your Canon dealer:
http://www.usa.canon.com/opd/controller?act=OPDWhereToBuyAct
Mar 28, 2010 | Canon PIXMA MX310 All-In-One Printer
When I try to print docs from the web, the printer feed the paper but it get stuck after pulling eigth of the page. Copies are OK to print without problem
Clean the paper feed tray
and adjust the tray
Clean the paper feed tray with damp cl;oth
reset the printer to factory default settings if still does not work
....Go thru the manuals how take printer back to factory default settings
Sep 15, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Duplex tray is broken. Where can I order one?
You can purchase it from Brother and the part number is LJ7661001
DX FEED ASSY. The small "wheels" can also be purchased if you don't want to buy the whole unit, but I am not sure which ones you are talking about as there are several in the unit. The printer may print fine as long as you don't print Duplex.
Mar 10, 2009 | Brother HL 5150D Laser Printer
HP PSC 1315 Problem
Glad to know that your problem is solved.
Thank you for using fixya..
Jun 23, 2008 | HP PSC 1315 All-In-One InkJet Printer
Dell 3100cn
check the tray for a special piece of plastic that, when rotated or adjusted some other way, confirms the tray is holding what paper size and orientation. I know HP used this on older lasers.
Jun 04, 2007 | Dell 3100cn Laser Printer
Info print 1140
when you go to the menu of the printer is the paper TYPE set correctly?
tray 2 should be letter ( if using plain paper)
tray 3 legal, label etc...
and tray 1 should be any
May 18, 2007 | IBM Infoprint 1140 Laser Printer
Envelope printing
Got a 3100CN and had the same problem but found that a) Changing paper size from the web doesn't work but b) Go to the printer control panel on the printer and use the menu to set the paper size for the MPF tray for FREE. Now your application under windows will overide the whatever the printer thinks and will print. Envelope via Word all work without problem. Suggestion . Configure two printers one B&W using tray one and one colour using MPF and you can now quickly select whether to use colour or b&w. Regards John N - N2UYI/G7LTQ
May 01, 2007 | Dell 3100cn Laser Printer
Canon SELPHY  CP720 Printer Logo
16 people viewed this question
old marine
old marine
