Question about Sewing Machines
Manual for e & r classic - Sewing Machines
Looking for a free manual for simplicity quilters classic model sw240
Search the internet for:
Manufacturer + Model + the word "Manual"
Sometimes you can find downloads from the manufacturer's web site.
Oct 05, 2015 | Simplicity Quilter's Classic SW240...
Machine skips stitches on bulky items
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Aug 19, 2013 | Simplicity Quilter's Classic SW240...
Use 1 step automatic buttonhole on simplicity quilters choice
if your sewing machine has a button hole lever, then the button hole
function will not work until the lever is pulled down.
it to the right of needle
I'm including a link for a manual hard copy or download, they cost
different prices
http://www.sewingpartsonline.com/instruction-manual-simplicity-sw240.aspx
http://www.sewingpartsonline.com/instruction-manual-simplicity-quilter-s-classic-sw240-download.aspx
Sep 07, 2012 | Simplicity Quilter's Classic SW240...
My bottom thread is making large loops, is the tension to tight or slack
it's to slack, try a 3 or 4 setting on the tension
& if you use your machine alot,, clean under the needle plate & bobbin area for loose threads & lint
using a can of air is helpful
Aug 07, 2011 | Simplicity Quilter's Classic SW240...
I need an owners manual for a White Classic 312.
When I called 800-446-2333 I was told that I needed to go to the Singer website (www.singerco.com), mouse over Customer Support, click on Instruction Manuals. In the search box, put in the first letter of the manufacturer plus the model number. In my case I was looking for the manual for the White Classic 312, so I typed in W312. The manual is a free PDFdownload.
Nov 17, 2009 | White Sewing 312 FS
User manual for e&r classic steam press sp06
Hi
get the manual from Elna
http://www.elna.com/
Feb 13, 2009 | Elna 1010
Sewing Machines Logo
10 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
