Question about Samsung Televison & Video
Samsung la40D550 screen starts flashing after 45 minutes switching on the tv. The picture are little bit hazy and captions and figures are shown one under one like double image. what would the problem.
Coldcut
  • 1554 Answers
SOURCE: Image cut off of Samsung LCD TV picture
if you have a time warner remote press the # to zoom
cox has another button . don't know it. ask them.
Posted on Mar 08, 2008
SOURCE: Picture Flashing
I had this problem too, fortunately I have a sky engineer friend who told me it is a known compatibility issue, all you need to force the latest firmware upgrade down to your sky box and hey presto, it will fix it. It depends on the type of box you have as to how to force the firmware download, but just google it and you'll find the combination of keys to press that will put the sky box into receiving a new firmware upgrade from sky.
Hope it helps you, it did me cos it was driving me crazy
Posted on Jun 10, 2008
crlee3
SOURCE: Closed Caption
Yeah, I'm now believing it's the tv. The captions on the other tv in the house work great. My samsung is only 2 yrs old. This model was 1080 i...Kinda of costly. Still no solution???? CR. LEE
Posted on Sep 08, 2008
SOURCE: Problems with the picture mode on my samsung 46''
Your TV is in DEMO-STORE MODE.
Go to menu, find Plug & Play option, start it, and when asked, select Home Mode, than Enter and than just Exit.
Enjoy Your TV!
Posted on Jan 22, 2009
  • 304 Answers
SOURCE: Pink and green lines and double picture.
Replace the main bd. Have a trained Samsung tech troubleshoot to confirm.
Posted on Jul 17, 2009
Hi my samsung tv model la40d550 has a horizontal line through lower 3rd of screen, what is the cause of this and how can i fix it?
This appears to be what is referred to as delamination, and the only way to fix it is replace the panel, which would probably cost more than a new TV. Sorry. Unless it's still under warranty...
Feb 13, 2015 | Samsung Televison & Video
After 45 min, Screen gets hazy and with green artifacts on the right of objects
These are two variable resistors has some glue on it for protection, means NOT to adjust it as already adjusted in factory.
now regarding pulling two wires, one thick wire can be pulled ( not in all cases) as shown in below picture. Push it and rotate it. If this not works, don't pull it force ly. just go to other end of this wire and try this method.
LOL, my drawing isn't good :P
Oct 02, 2008 | Samsung HCM5525W 55" Rear Projection...
When I switch on my Samsung 40 in LCD TV, half of the pcicture comes inverted and after a minute or so, it straightens. Initially the picture is hazy and then the picture turns normal. Sometimes, the...
This problems could be also causes by the board the call the T-CON docoders board,it sit in at middle of the bottom of the LCD screen panel.Because this board decoders incomming pictture signal before it go into the LCD screen panel to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoderd board for the replacement.
Apr 16, 2011 | Samsung LA40A450 40 in. LCD TV
No color on samsung lcd tv even after factory reset
hi if you bring the menu up and it's clear then you have a tcon board fault, if the menu is the same as the picture then you have a mainboard problem, thanks
shaun
Mar 09, 2017 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Hazy crt tv picture for the first 15 minutes after turn on.
yes,, while heating up,, some transisters are failing.. have to check the circuit board,,
Sep 29, 2009 | Televison & Video
Enjoy Your TV!
Jan 09, 2009 | Samsung LN46A550 LCD TV
Blacked out screen in middle of tv
The text mode in the closed caption is turned on.Turn off the closed caption. I don't have the schematic in front of me, so, I will wing it. There may be a button on the remote that says CC, if so then use that button to turn it off, if not then go to the service menu and you may have to search a bit. Either way it's an easy fix and you can do it yourself. If you can't find it, then, reply and I will give better instructions when I get into my shop next week.
Sep 09, 2007 | Olevia LT32HVM 32 in. LCD Television
Screen problem
check captions on your menu settings it has caption 1 and 2 if it is not set on caption it could be on text which cause the black box to come on the screen turn off every thing on the caption menu.if that does not work then take you set to a tech to have it reset then it could be your eprom or your video circuit.good luck.
Aug 28, 2006 | Samsung TXK2754 27" TV
Televison & Video Logo
91 people viewed this question
Henry  Thomas
Henry Thomas
