Question about Frigidaire Ovens
Oven element Put new Oven elemnt but wont heat up
  • Frigidaire Master
  • 5,323 Answers
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
Posted on Apr 17, 2015
  • 87 Answers
SOURCE: oven heats up very slowly and does not get very hot
Check your power to the oven at the terminals where the power cord connects.Should be 220 volts. Also check the terminals of the bake element for loose connections or a burnt wire.
Posted on Jun 08, 2007
SOURCE: oven not heating up properly
You could very well have an electrical problem. You may not be getting the full 220 volts needed to make the oven function correctly. Call a local appliance technician or electrician for service.
Posted on Sep 27, 2007
  • 20 Answers
SOURCE: Element in top oven not heating up all the way.
Yes needs a new element.they burn out. easily.you know this because they sell them seperately.its there way to make money off of you.anytime they sell you something and the parts are readily available especially sold seperately you know its going to need to be replaced eventually..If you replace 1 replace them all to avoid furthur issues.
Posted on May 29, 2009
barkencoa
  • 3463 Answers
SOURCE: bottom oven not working have put new element in
You need to determine that you are getting power to the element, you will need a meter to test with.
If no power, then could be faulty thermostat or regulator switch.
If you have power, then element faulty.
trust this helps you.
Thanks.
Posted on Dec 05, 2009
mraleomile
  • 6 Answers
SOURCE: oven problem- grill works but the fan assist wont heat up
possibility is that the wire that link the oven element and that of grill is loose or burnt
Posted on Jan 08, 2010
Lower oven bake element not working
go to sears and take the serial numbers off your appliance and they will get you a new element for it and you can take the old one out and the new one in. Ask them at sears how to do it and they will tell you.
Dec 11, 2011 | Ovens
HOW DO YOU GET THE HEATING ELEMENT OUT OF THE BOTTOM OVEN TO TEST
Sorry i havent got back to you , first of all can you see that the element is bad ? it will have damage on it somewhere , it depents on how old this oven is ost have two screws near where the elemnt goes into the back of the oven you should see them to the left and the right of the element , first unplug the oven then remove the two screws pull the element towards you you will see two wires connected to it. Be careful removing the wires due to the brake off easy , his i very easy to replace and you will not have any problems , always look forward never look back
Nov 24, 2011 | Maytag Ovens
Hi I have a Hotpoint Double Oven Model 6181. The Main Oven has suddenly stopped heating up and I suspect the Element has gone. But how do you get the element out? - I can't pull it out and there are no...
Hi.
All you need to do is to remove the screws securing the cover at the rear of the oven compartment.
There you will see the cicular eloement, just undo the fixing screws, and ease the element forward, transfer wires onto new elemnt, , refit, and job done.
Mar 25, 2011 | Hotpoint DY46 Style Line Stainless Steel...
We have a 2 and a half yr. old Frigadare oven and the element went out. we bought a new one (gave them the model number) and the new element is so skinny than the original one. I turned the oven on to 375...
When you replace an oven element you must replace it with an element of the same rating. Say the original was a 2400 watt element. You could probably get away with a 2200 watt replacement element. You would not put an 1800 watt element in as a replacement. It wont heat up as much, particularly if it is a big oven. I would check both ratings first.
Feb 28, 2011 | Ovens
Wont heat up but fan seems to make noise that its working
If the fan is working o/k, then it is safe to say that the oven elemnt is faulty, and needs to be replaced.
This should be located at the rear of the oven compartment behind a removeable cover.
Nov 19, 2010 | Ovens
Fire Mondel # PLEB30T9FC
very possible hat the element is no good, does it look physically burned???? if so replacing the elemnt is the only option,2 screws and 2 wiredis all, simple to replace, unplug/disconnect power first,,, the wires are always live to the elemnt!!!!!!!
Dec 21, 2008 | Frigidaire GLEB30T8A Electric Double Oven
We need to install the lower heating element in the upper oven
ill aasumme that yo can see the elemnet in question, and its not a "hidden bake" elemnet located under the oven floor.. should be an easyrepair, with a little bit of patience. don trush shoudl only take 10 min anyway. TURN OFF POWER> LIVE WIRES TO ELEMENT AT ALL TIMES. REGARDLESS OF UNIT ON OR NOT!!! ther ewill be 2 screws along the bottom of the element holding the elemnt in the unit. after emoving carfully slide the old elemnt out a few inches, slowly pull out, for the wires are still attached to the back of elemnt and you want them to stay there you dont want them to disconnect and fall behind unit, (you will then need to remove the unit form the wall to access htem). so pull slowly espescially if you feel resistance in the wiring. after you getit out far enough simply unplug and plug in the new one reinstalll and you shoud be fine
Nov 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Wierd problem with ge eletric oven / no heat
check the electrial connection at the back of the range, also check the breaker
Mar 31, 2008 | GE JKP15 Electric Single Oven
Hooking up new bake element
shouldnt make a difference your elemnt has only 2 terminals 1 wire to each
Mar 19, 2008 | GE JRS06SKSS Electric Single Oven
Oven heats up very slowly and does not get very hot
Dec 28, 2006 | Frigidaire FEB30S5D Electric Single Oven
Ovens Logo
65 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
