Fisher 8 in 1 code list - Televison & Video
Error code 130
IF a Fisher and Paykel, see this link:
http://ths.gardenweb.com/discussions/2427379/fisher-and-paykel-gwl11-error-code-130
You need to list brand (if not also model number) when you post white goods questions. Codes are specific to a manufacturer.
Mar 04, 2015 | Washing Machines
Tip
Decoding Fisher & Paykel Electronic Washing Machine Fault Codes
The Fisher & Paykel Smart Drive and EcoSmart electronic washing machines are equipped with fault detecting software to help easily determine the cause whenever a problem occurs. Not like other electronic washing machines, these ones do not have displays to flash the code, but rather use the eight (8) light-emitting diodes (LED) of the Wash Progress indicators to indicate the fault code. The eight (8) LEDs stand as an 8-bit binary number (zeroes and ones) that must be decoded and then converted to the decimal number system to get the fault code.
The fault code can be decoded by determining which Wash Progress LEDs are lit. Once determined which of the LEDs are lit, write down the 8-bit binary code; 1 for lit LEDs and 0 for the off ones. For example; the final wash, rinse, and spin LEDs are lit; the binary code is 00001101. This in turn can be converted to the decimal number system by multiplying each digit with its corresponding place value then adding up the result. From left to right, the place values are 128, 64, 32, 16, 8, 4, 2, and 1 respectively. Therefore, the decimal equivalent of 00001101 is 128(0) + 64(0) + 32(0) + 16(0) + 8(1) + 4(1) + 2(0) + 1(1) = 8 + 4 + 1 = 13; the fault code is 13 which is a pump fault.
Once the code is determined, search the web for the meaning and indicate it when requesting for an online assistance to facilitate a quick and precise response.
on Apr 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel MW512. Error Code can't be determined. Light 8 flashes as does lid lock light
exactly which lights are flashing?
http://www.fisherpaykel.com/vault/pdfs//pdf_usecares/420983_Smartdrive_UC_UD1.pdf
Mar 22, 2014 | Fisher and Paykel Washing Machines
What code for remote model RCR504BR to Fisher TV
020,025,022,029. Try these codes. If you wish to get more, try the following links. Both the sites linked have set-up code list & set-up procedure to many popular brand remote controls.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Jan 24, 2014 | Televison & Video
I need a code for a fisher t.v.
0493,0499,0418,0431. Try these codes. If you wish to get more codes and other details check: http://electrohelponline.blogspot.com/ & http://electro-medical.blogspot.com/ Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Jan 05, 2014 | Fisher Televison & Video
Fisher Paykel GWL15 error code 49
The 1.6amp fuse on the board would be blown along with the mosfet's that drive the water valves, not an easy task to replace mosfet's.
Best to get a new motor controller board,
Quote the 6 digit part number under the bar code to get the right part.
Mar 30, 2013 | Fisher Paykel EcoSmart GWL15
Programar un control
URC 4080 has setup codes for Fisher. Check this link to download its code list.
Dec 18, 2012 | Fisher Televison & Video
Have Fisher & Paykel top loader. Error code
fault code 56 is a real code : bowl invalid check clutch in centre of bowl and pressure tube is not kinked,can also mean pressure tranducer on motor control board could be faulty, note check for obstruction between inner and outer bowl( missing a sock perhaps.?)
May 07, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
