Question about Samsung Microwave Ovens
It want do anything
We plug into outlet and it will not do anything. The light will not come on or anything.
    Champion:
  • 203 Answers
Check the fuse and replace it with one the same and see if that helps sometimes the basic things work first
Posted on Feb 17, 2014
The control panel of microwave dead. No lights on the panel. There is power to the outlet
If it worked after unplugging and reinserting, it is possible that there is a wiring problem with the plug and wiggling the wires "re-made" a connection. Try plugging in to another outlet to eliminate a dodgy outlet problem.
Mar 26, 2015 | GE Microwave Ovens
I have a built-in AEG Microwave code MC166(0E?) My son unfortunately used the microwave as a timer so it was on for 30mins without anything in it. It now won't turn "on"; no light/clock...
What fuse did you change? The fuse on the wiring that leads to the microwave needs to be intact, then the fuse in the Microwave itself needs to be checked. Usually there is a plug where the microwave is plugged in, in the cabinet above the microwave, you can take another small appliance or a power tester to make sure power is available in the outlet where the microwave is plugged in. If the power is on at the outlet then you'll know that it is the microwave itself that has turned itself off for some reason. You can get manuals for these ovens at this website
May 11, 2011 | Microwave Ovens
I just bought a GE 1150 watt microwave. It worked fine in the store, but when we plugged it in at home, there is no power. The outlet works because I plugged a night light in and it lit up. Could the...
Hi, try the microwave in another outlet, if it works there then the first outlet is bad but if the microwave does not work in another outlet then the microwave is faulty and you need to take it back to the store and get another one as a replacement...
May 07, 2011 | GE JE2160 Microwave Oven
Cant plug in microwave. Everytime i do it trips GFI outlet. Same story for all outlets in kitchen. Plug in anything else and it works fine.
Hi
It sounds there is current leakage within the oven, causing your safety switch to trip.
It would be best to have a professional check your oven.
Isaac
Jan 30, 2011 | Microwave Ovens
When i plog it in it eother does nothing, or
I just bought the same microwave, and mine is doing the same thing. Did you ever figure out if it was the oven or the outlet? My old microwave works just fine.
Nov 26, 2009 | Bosch HMV9305 Microwave Oven
The microwave stopped working
Ck your gfci breaker in your wash room or bath room. If this dosn't fix it it may be an internal fuse. If this is the case you will need to find what caused breaker to blow or it will happen again.
Aug 21, 2009 | Microwave Ovens
I pluged the microwave in it was working and when I pushed it back and when I looked at it it waqs not working any moren mdl # is 87449 kenmore counter top microwave
Check the outlet it is plugged into. Remove the microwave plug. If you don't have a voltage meter handly to test the voltage at the outlet or the continuity of the microwave plug, I would suggest you plug in a lamp from your living room into the outlet. If it doesn't work, either the outlet is a tripped (GFIC) Ground Fault Interuption Circuit outlet or the circuit breaker tripped in your electrical panel box or the microwave cord is damaged and caused a short and blew the fuse. To check these I would try plugging the light in and press the red reset button located on the wall outlet or flip tripped circuit breaker in panel. If it's a damaged cord or fuse, you can visit this web site for Sears parts www.searspartsdirect.com If you found any of these suggestions helpful, please rate my solutions. Thanks D. Lange
Apr 23, 2009 | Microwave Ovens
Triping breaker as soon as it is plugged in. can anyone tell me what usually is the cause of this problem when as soon as i plug the power cable in to the outlet, it would trip the breaker? no power to the...
try pluging it in on another outlet with an extension cord must be a diffent cerciut breaker if it happens again the microwave has a short. if not its that breaker or outlet.
Mar 31, 2009 | KitchenAid KCMC155J Convection/Microwave...
Loud pop with smoke
Don't know why just plugging it into a new outlet would cause that unless you have a problem with that outlet. Sounds like it may have burned out the low voltage circuitry. I would advise having the outlet checked and certified safe before plugging anything else into it. Also, it sounds like the oven is toast, (Sorry!)
You can get parts on-line from AppliancePartsPros.com/Parts
May 23, 2008 | Emerson MW8107WA Microwave Oven
Microwave Ovens Logo
47 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
