Question about Dishwashers
Kenmore quiet guard model 587.1526 not draining water
IFIXALL
  • 868 Answers
SOURCE: water sitting in bottom of dishwasher
Are you in Canada, I can't find the info you need if you are. Although I'll try with Whirlpool in the morning for you.
Posted on Jul 15, 2008
SOURCE: Where is the filter on a Kenmore Quiet Guard 2 dishwasher?
not a dumb question,
is the bottom dishes coming out clean? there is a chopper that breaks and will trap food and not clean the top rack.it is not easy to replace.but not impossible.
Posted on Oct 31, 2008
  • 9 Answers
I have a Quiet Guard 4. Same problem so will describe my solution.
1. Remove bottom basket. Remove top basket.
2. Remove bottom washing arm. Unscrew (Gently but firmly) the centre post. Lift arm assembly up and out.
3. Remove overhead conduit. One screw at back, one at top (Philips #2 bit). Rotate whole assembly 45 deg right (Clockwise) and lift off of centre post.
4. Remove centre post (Pull straight up). Remove 4 screws (Star T-20 bit). Lift whole assembly out. Pop off screen and clean.
5. Remove cap over cutter/chopper. There is a single screw at front left (under assembly removed in 4). Remove screw (Star T-15 bit) and cap (Needs some wiggling to free it up). Remove cutter and filter. It is on a spring loaded pin. Pull the cutter blade foreward and then the filter disc straight up. Clean thoroughly as it may be the cause of your problems.
Reassimble. Good luck!
Posted on Jan 02, 2009
SOURCE: Kenmore Ultrawash Quiet Guard 5 making buzzing/grinding noise
I have a very similar dishwasher, with a very similar problem. I fixed it by removing debris from the water evacuator pump located towards the front of the bottom of the machine (the last motor before the drain hose. In my case, grape stems had clogged it up. Once emptied, it purrs once again. NOTE: don't disassemble the motor, just flush it out, there is an o-ring gasket that is a bear to re-install.
Posted on Sep 04, 2009
  • 127 Answers
SOURCE: kenmore dishwasher ultra was quiet guard 3 model
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
Use the Lock On to prevent unintended use of the dishwasher
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
hope this helps,
best of luck,
ttfn
Posted on Oct 25, 2009
Kenmore quiet guard
see the video and proceed yourself.God bless you
Jul 06, 2013 | Dishwashers
I have a Kenmore quiet guard 3 model: 665.74364k2 and serie F55202295. It is not draining properly. It works fine and cleans the dishes but when it goes to drain it leaks in my basement ceiling and vents.
if you have an air gap vent in the kitchen sink plumbing then make sure it is clear. Also looks like the kitchen drain end is blocked. Pour some caustic soda into the sink drain, wait 10 minutes and run water into the sink.
If you are using insinkerator (garbage disposer) in sink, make sure it is run before you start the dishwasher.
Jan 10, 2011 | Kenmore 24 in. 15932 Built-in Dishwasher
My kenmorre quiet guard 2 dishwasher is not draining completely and is leaving dishes with a soapy residue.P,ease help.thank you.
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Nov 11, 2010 | Kenmore 24 in. 15932 Built-in Dishwasher
I have a Kenmore Dishwasher Quiet Guard 1 Model Number 665.1784440. It will not fill up with water, but it will drain if I pour water into it. Help
start simple, make sure water supply is ok. if this ok i would be lookin at the inlet valve, its solinoid could be faulty. located inside dishwasher where water hose screws on.
also on dishwashers a broken wire inside the door skin where wires loop into bottom would be fairly common.
Sep 25, 2010 | Dishwashers
I have a Kenmore Quiet Guard and it has stopped draining. The drain line is not clogged.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
heatman101
Aug 30, 2010 | Kenmore Dishwashers
My Kenmore quiet guard standard model 587-15152400 is not getting the dishes clean AT ALL. It has hot water, water is draining, have not changed soap. Don't know why?
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
http://www.fixya.com/support/r4817172-dishwasher_spray_arms_not_spinning
heatman101
Aug 22, 2010 | Kenmore Dishwashers
Jun 22, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Water keeps coming back into dishwasher after cycle is done
sounds like maybe one of your check valve is not working right.
Jun 03, 2009 | Dishwashers
I have the Kenmore Plus Quiet Guard, just wondering about filters as the water is not draining?? Anyone know?
It sounds more like a failed pump.
Does it circulate the water while washing dishes?
You might check the junction where the dishwasher connects to your drain under the sink. Often, they empty into the garbage disposal.  The inside of that junction has a tendency to clog with food (especially grease) and the pump of the dishwasher doesn't produce much pressure, it is more designed for volume.
Jan 08, 2009 | Kenmore 24 in. 17602 / 17604 / 17609...
Dishwashers Logo
21 people viewed this question
Top Dishwashers Experts
