Question about Conair Lighted Mirror
What can i try after replaced bulb but still wont work
Its an auto light mirror model BE 84 appx 3 years old
Place a little bit of foil between the bottom of the new globe and the connection. Sometimes this works.
Posted on Mar 17, 2014
I have a rear projection Toshiba model 62hm95. I have a rear projection Toshiba model 62hm95. I have a rear projection Toshiba model 62h
There is no bulb to replace on a rear projection set. It uses 3 separate picture tunes 1 red 1 Blu and 1 green coupled to magnification lenses that focus onto the mirror which the directs the image thru the screen. Access is usually by removing the trim ring and screen from the front. Access from the back only gains access to the circuit boards. Be very careful as each tube has its own high voltage transformer which can have from 50000 to 150000 volts.
Oct 07, 2016 | Toshiba 62HM95 62" DLP HDTV
1986 gmc c2500 tail light wont work replaced fuse and light bulbs still dont work ? I do have break light but when I turn on light the break lights wont work
you have either the wrong bulb or the bulb installed backwards.
the reason the bulb is not working right, is because the driving light is lighting brighter than the brake that's why it looks like is not working.
Dec 28, 2014 | AM Auto Parts 1986 GMC C2500 Truck Heater...
Have a 2010 2500 dodge the under mirror lights and the passger front marker and the passger reverse light wont work ?
Replace the bulb in the front lens to get the mirror and marker to work. Replace the the bulb for the reverse light also. Both are on seperate circuuits.
Mar 19, 2014 | Dodge Ram 2500 Cars & Trucks
I have auto light mirror model BE84 appx 4 yrs old. replaced bulb, but still wont turn on
Take globe out and put back in again. If that doesnt work place a little bit of foil between the bottom on the globe and the connection. Fingers crossed it works
Feb 15, 2014 | Conair Lighted Mirror
Flasher blinks fast and then blew out and so did the headlight in my 2002 oldsmobile intrigue
The problems are probably related in some way. Let's reason this out...If there is an intermittent short in the wiring somewhere it could blow bulbs. If you have poor grounds on the MANY ground wires in the car and in the engine compartment, sudden surges could be taking out fuses and bulbs. If you really want to find the solution(s), you will need a wiring diagram of the complete car. You can get one by going to the auto parts store and requesting a Haynes auto book for a 2002 Oldsmobile Intrigue. In it you may find some hints like I gave you. Try to trace the worst problems first so that you can keep the car on the road (pass inspections)...
Jan 13, 2013 | Oldsmobile Intrigue Cars & Trucks
How to replace light bulbs in a Jerdon Tri-fold makeup mirror
In order to replace bulbs, look at the back of the mirror. There will be four white circle coverings hiding the screw heads, and these must be drilled open in order to access the screws that hold the two halves of the mirror together (these coverings will not have to be replaced). Once these screws are located and unscrewed, flip the mirror back over and remove the top half. Carefully, replace the bulbs.
Oct 25, 2011 | Cars & Trucks
How do i change a parking light
gain access to the burned out parking light...
Remove the old bulb...
Go to Auto Zone and get a replacement bulb ( $2.50each!!)
Replace bulb and close up... all of which depends on what year make and model car we are talking ...
Sep 30, 2010 | Chevrolet Venture Cars & Trucks
Can I use a different model year door mirror on a 98 chevy lumina
Door mirrors on chevrolets tend to be model and year specific. the auto recycler can tell you for sure since most carry a book which shows what parts will interchange with what car.
Nov 17, 2009 | 1998 Chevrolet Lumina
How to dismantle mirror to replace indicator bulb to vw passatt
We need more info on the car. Year, make model. All that good stuff. What is it exactly that your trying to do. Sounds like you should just replace the mirror.
Sep 27, 2009 | 2003 Volkswagen Passat
Conair Lighted Mirror Logo
160 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Julia Tatspaugh
Level 1 Expert
Danny Kuhlmann
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
