Question about LG lfc25770st french door 25 cu.ft refrigerator factory refurbished f
LFC25770ST not cooling. Hearing clicking noise
The unit stopped cooling. Top and bottom. While plugged in we hear clicking noise.
2 Suggested Answers
  • 30 Answers
SOURCE: WHEN I TURNED ON TV LG MODEL 32FS4D-TE . I HEARING
the internal power supply is not starting up and needs to be replaced
Posted on Nov 28, 2010
The freezer not working , it make a noise for about 10 secs and then stop , im at your mercy , if you know of any solution. thanks
if the noise is that short sounds like maybe it is possible the compressor relay is bad... if your hearing a click at the end of the noise then most likely you either have a bad compressor relay or the compressor itself has failed.... this unit is common for having this problem and your short post i would say by the description that is what it would be... access the rear of refrigerator and plug it in again after it has been off for at least a hour or so ..there will be a cover at the bottom that can be removed to access the compressor area... plug unit in and place your hand on the compressor and listen if the noise is coming from there then you will need to replace the relay on it....good luck to you..
Feb 14, 2011 | Maytag MSD2434GE Side by Side Refrigerator
9059cs stopped cooling after some strange noises. Is it worth repairing?
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 27, 2011 | Amana ARB9059CS Bottom Freezer...
FREEZER AND REFRIGERATOR NOT COOLING HEARING CLICKING NOISE
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 25, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer stopped working top refrigerator is fine. Making a noise like it is trying to start but doesn't.
heatman101
Oct 19, 2010 | Amana ARB1905C Bottom Freezer Refrigerator
Compressor seems really hot. Had clicking sounds in my unit, but it was still cooling. Last week it stopped. I replaced the motherboard and it worked great for 2 days. Now it stopped cooling well. ...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
It sounds like you have a small leak in the refrigeration system and that your unit is low on freon...
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 12, 2010 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
Problems with GE GSL25JFPBS Side by Side Refrigerator IS THAT THE FAN RUNS BUT IT IS NOT COOLING AT ALL, KEEPING HEARING THIS CLICKING SOUND AND THERE IS NO SOUND FRON THE COMPRESSORS.
Hi, I have done commercial refrigeration for many, many, years and no about residential units also. What you need to do is to roll this unit out to get behind it with room to work. There will be a fiber like panel that has to come off. The clicking noise you are hearing is on and off every so many minutes give or take, Like, click pause click, a few minutes same thing. Anyway, remove this panel. You should see a small fan motor, a coil, and the compressor. Make sure the unit is plugged in and the thermostat control inside is set at its coldest setting. If it has been on for sometime and clicking, carefully place your hand on top of the compressor as it should be HOT! The clicking noise you will be able to here at the small cover on the face of the compressor covering the terminals and wires to start it. It also has a klixon relay wired in the common wire that when the compressor gets overloaded, it will click and keep the compressor from starting. It will continue to do this until it finally wears out. So, hearing this click and your compressor is hot to the touch, more then likely, you are loosing the compressor. Depending on the age of this unit and the cost of a tech changing it out, may or may not be worth it. Try this, unplug it. The small fan and coil, try and clean the front of the coil with a brush to remove all the dirt and dust buidup. Let the unit cool completely down. I have wet cold rags in the field and put on the compressor to speed this up, but be careful not to get water in the electrical connections. UNPLUG IT FIRST. After it is nice and cool, try to turn it on. If it starts, thats good and I cant say how long it will run. If it does not, the compressor is dead and locked up. A repairman may put a hard start kit on it to try and break it free, we do try this first, but it may be to far gone. Check the coil like I said and let it cool down. Hopefully it will run, but probably not. I hope this has given you some direction to follow.
Sincerely,
Shastalaker7
Dec 28, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Fridge keeps making "clicking" noise and will not get very cold
the clicking noise is probably the unit trying to start but it cant because its too overheated,try turning it off for about 30 minutes to cool the compressor down,then put the thermostat at 3 for the fridge and not the coldest for the freezer and leave it there for a few hours to stabalize the temperature and see what happens.
May 09, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Fridge and Freezer losing cooling
thermostat control to deice the freezer is malfunctioning need a service tech to replace it so it doesn't keep the deicer on . Its exactly that, a warmer to deice the coils.
May 27, 2008 | Fisher and Paykel Active Smart E522B...
GE model GTST2BPLWW
they all have fans the freezer does all the cooling for the whole unit there is nothing in the bottom unit that cools the freezer fan blowes air from the freezer down to the bottom and draws air to the top if you dont hear the freezer fan running and there would be no doubt in your mind if it was then pull the fan cover and see why and let my know hold my rating till we are done please
Feb 11, 2008 | GE (GTS16BCS) Top Freezer Refrigerator
LG lfc25770st french door 25 cu.ft refrigerator factory refurbished f Logo
47 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
