Question about Poulan Pro PP5020AV 50 cc Gas Powered 20-in Chain Saw with Case
Chainsaw rattles when it stops
I bought a Poulan pro chainsaw recently. It starts very well. When I stop using it, it makes a metal rattling noise inside the saw engine. It has been doing that for a few uses. Now after operation for a while it will seize up. I can free it up by taking the carbeurator cover, rotating and cleaning everything and sprinkling bar and chain oil over the entire chain. It has gas mix and bar and chain oil in the saw as well.
  • 30 Answers
Personally too much hassle prefer Stihl Chainsaw more reliable Seizing is caused by lack of lubrication, First check all level has oil pump seized or is it sump type when running oil circulates all way round, Still there has to be a oil reservoir if this is bone dry theres your problem the rattling is metal on metal with no protection and the damage is seizing caused by lack of oil I have two chainsaws both have oil sumps and are kept full, please check hope this helps
Posted on Feb 18, 2014
5 Suggested Answers
dennisgladx
  • 52 Answers
SOURCE: poulan Super 1800 16" chainsaw .
Hi dortfran,
My name is Dennis and I hope to be of assistance.
This sounds like a kink in the chain and I would try a new chain because this can be a very small kink and very difficult to find and straighten out. If you must put the chain saw in a vise by clamping the bar and run the chain back and forth from the sprocket to the bar grove under operating tension and locate the misalignment at the bargrove. Now you have located the problem but the fix is still sweat away, and with some luck you may be able to spring the chain straight and have the link flexable to opporate without a hitch.
Glad to be of assistance. Please rate the solution because i can learn from your rating.
Thank you
Dennis
Posted on Nov 09, 2008
SOURCE: I have a Poulan Pro PP3516AVX chain saw. I used it
Their not the best saws but make sure the nuts holding the bar and cover on are tight after adjusting chain sometimes improper cutting will continue to kick chain off bar.
Posted on Mar 15, 2009
  • 15 Answers
SOURCE: Poulan 2 cycle gas chainsaw 18 inch. Was real
no bar oil should just hurt your chain and bar. remove them and try to start saw. if it still won't start you have other problems you may have to buy a new bar and chain
Posted on Feb 09, 2010
  • 4088 Answers
SOURCE: Poulan Pro Chainsaw(PP4218AV) worked for a while now won't start
It's possible that the carburetor diaphragm in the lower chamber has hardened or cracked. Does the primer bulb fill with fuel after several pumps? If not, try moving the line that comes up from the fuel filter to the carburetor over to the primer port that normally connects to the other carburetor connection. Try to pump fuel again--if successful, then there is blockage within the carburetor which should be cleaned with spray carburetor cleaner inside and out. There is a small filter screen inside the main body that can be easily plugged with stale fuel. Hope this helps!
Posted on Jul 11, 2010
2003 ford explorer with a loud metal rattling noise sometimes it will vibrate too
Could be cam chain rattle. Famous for sloppy chains and inferior tensioners. Starts about 100k and downhill from there. Could try an engine flush as tensioners may be sludged. I have a 4.0L with a rattle at start up but stops after 5 seconds. Chain is shot.
Feb 26, 2013 | 2003 Ford Explorer
My 1998 sebring 6cyl makes a metal on metal noise on the side of my engine by the belts i tried greaseing all the pullys and i used belt noise sparay but it becomes lower and then it becomes higher ???...
sounds to me from the brief description like you have either a water pump rattling, or a timing chain coming slack. Is the noise coming from the alternator? Never grease pulleys, ever. also the stop squeak spray is bad for your belts. Don't know why they even sell it. If you listen carefully you may be able to pin point the rattle. Is this a tick tick tick, or a rattle rattle rattle? Does sound like a water pump rattle or timing chain slap though. Hope this helps
Jan 14, 2013 | Cars & Trucks
Rattling/clinging when car is cold. Stops soon after.
not the water pump as the noise will remain constant hot or cold
you leave very important details like make . model , year and engine type petrol or diesel so answering becomes a hit and miss affair
if the engine has a timing chain it indicates that the hydraulic adjuster is loose until oil pressure is built up which equates to a badly worn chain
next if an incorrect oil filter was used , the oil will drain back over night and , chains, rockers, hydraulic lifters will all rattle until pressure is built up
incorrect oil viscosity will drain down quickly and will take time to build up pressure as well
you may have to find an accredited service shop and leave it there over night so that the diagnosis can be made in the same conditions for them as for you and then get a quote
Jul 27, 2017 | Cars & Trucks
Hard starting,but when started runs good,then put it down on ground it shuts off,always ran good before just recently had this problem.
The choke isnt rattling its way back to cold start position is it? Had the same problem but with my backpack blower. Keep an eye on the choke while its on the ground. Also, check the priming pump, that little button you push to prime it, make sure there isnt a leak coming from there.
Jun 06, 2010 | Poulan 18" Wild Thing Chainsaw
I have a 2001 Ford ranger supercab that makes rattling noises. It has a 4.0L SOHC. It makes a very fast and loud metallic rattle wich softens anfter about a second or so when I first start it for the day....
4.0l's are notorious for valve rattle on cold start-up. There is really nothing you can do to make it go away short of completely replacing the valve train in the top end, and that isn't a permanent fix. It's is an top end oiling issue from the factory. Just don't race your engine on cold start-up until the rattle stops.
The rattle in the transmission sounds to me to be more of a loose dust shield/heat shield around the transmission or exhaust than a mechanical issue.
Oct 20, 2009 | 2000 Ford Ranger SuperCab
My new Kenmore window unit 76081 makes loud rattle
If it does not make the noise when the fan is ruunin you may ahve abroken sping in the compressor. Make sure you Window unit is level. If not the compressor will knock on the inside. Rusty
Jun 12, 2009 | Kenmore 76081 Wall/Window Air Conditioner
Mar 15, 2009 | Poulan Pro Chain Saw 46cc 20"
Kenmore dryer making rattling noise
If the panel's clamps are broken it will rattle,for a quick fix i would use duck tape on both sides.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 16, 2009 | Kenmore 63942 Dryer
Rattling sound when accelerating on 2007 Forester
On mine, I got under there and there are rocks rattling in the heat shield. There are factory made holes in it, and the rocks sit in there like eggs in a carton and rattle when the engine hits a certain vibration frequency which is basically when it is at a stop light or idling. The repair shop wanted to charge to cut them off but I think I am going to drill bigger holes so the rocks fall out, as they are pretty tiny.
Dec 07, 2008 | 2007 Subaru Forester 2.5X L.L. Bean...
Poulan Pro PP5020AV 50 cc Gas Powered 20-in Chain Saw with Case Logo
87 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
