Asus x58l bluetooth
Does this model have Bluetooth? I cant seem to find anything on the computer to enable connection.
    Brigadier General:
  • 3,400 Answers
5 Suggested Answers
  • 8 Answers
SOURCE: How do I connect my
You probably need the driver for your headphones, i had the same problem. Try this link and download and install the driver. This should fix your problem. http://www.broadcom.com/support/bluetooth/update.php
Posted on Mar 28, 2011
bronk50
  • 27725 Answers
SOURCE: How to transfer files from
you might need to install a mobile phone suite which is a program that will let you install a mobile phone to a computer this will have to be specific to your phone there are a number of phone suites nokia Samsung sony ericson to name a few here is a phone suite link hope this helps
http://global.mobileaction.com/product/product_USB.jsp#bottomContent
Posted on Apr 13, 2011
davidmamian
  • 543 Answers
SOURCE: Hi, I cant connect my Asus
Scan your Pc with strong antivirus. I think on PC working script.
Posted on May 28, 2011
joecoolvette
  • 5660 Answers
SOURCE: i have a asus x58l and it has a black screen. cant see anything
http://www.asus.com/Notebooks_Ultrabooks/X58L/#support_Knowledge
Don't know why I did that.
Asus Support. Those two words don't even belong in the same sentence. (Neither does Toshiba Support, or Acer Support)
Notice the large statement?
NEED SERVICE?
(In otherwords GOT MONEY?)
Rant over.
Janet,
The problem will be;
1) Graphics chipset
or,
2) Video Cable,
or,
3) screen Inverter,
or,
4) LCD screen
I'm betting it's the economical, and easy to replace - screen Inverter.
Laptop on, shine a bright flashlight at the LCD screen of the laptop; and shine at various angles.
See faint images?
Backlight is out, or screen Inverter is out.
90 percent of the time the fault is the screen Inverter.
Moving on........
A) Graphics chipset:
Laptop OFF, monitor OFF, connect a VGA monitor to the laptop.
The VGA port is on the Back of the laptop.
This is a General example of a VGA port (Connector), and VGA Cable,
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down a little for VGA Cable example.
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings, the display should show on the external VGA monitor.
IF not;
There are at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Hold the Fn key down, and at the SAME time; tap once on the F8 key.
The F8 key is the Display Toggle-Over key.
(User Manual indicates not all laptops, may use the same Function keys.
Whatever Asus.
The Display Toggle-Over key has LCD on it, surrounded by a rectangular line. Has a small monitor icon to the right of it )
Display on external VGA monitor? No?
Hold the Fn key down again, and tap once more on the F8 key.
No display on external VGA monitor, indicates a problem with the graphics chipset.
Display ON external monitor, indicates a problem with the;
1) Video Cable,
or
2) screen Inverter,
or
3) LCD screen
Perform the 'flashlight test'. No faint images go on to the external VGA monitor test.
Post back in a Comment.
We'll go from there.
Regards,
joecoolvette
(There are NO service manuals available, to the public.
Thank Asus for that. To procede though can be done.
This will require a partial disassembly of the laptop, to include removing the Keyboard, and Palm Rest Cover.
Together we can accomplish this if needed.
May do something I never do, and that is because of no Service Manual available. May ask you to buy a replacement screen Inverter, and replace it.
Need other information above FIRST.
Average cost is around $25 to $30.
The plastic frame in front of the LCD screen is the Display Bezel.
The screen Inverter is located behind the Display Bezel, and mounted to the bottom of the LCD screen assembly.
(Clip or a Philips head screw)
Average example,
http://www.ebay.com/itm/100-Genuine-NEW-Original-Asus-X58L-laptop-Series-LCD-Inverter-08G21VJ10107-/290873311574?pt=LH_DefaultDomain_0&hash=item43b9668156
Doesn't require removing Keyboard, and Palm Rest Cover.
DOES require removing all power. AC adapter (Charger), and Battery.
Posted on Mar 25, 2013
I have alcatel z221 cant download pictures to computer
You can transfer pictures from your phone to your computer in 2 ways.
Bluetooth
1. Enable Bluetooth
- From idle mode, select Menu > Settings > Connections > Bluetooth.
- Press the OK Key to set Bluetooth to On.
2. Pair your phone to your Bluetooth enabled computer. If your phone does not have a built-in Bluetooth module, you can buy a Bluetooth dongle from your local electronics store.
- From idle mode, select Menu > Settings > Connections > Bluetooth > My devices.
- Press the OK Key to search for available Bluetooth devices.
- Highlight a device from the list and press the OK Key.
3. Select your desired file, and select Left Soft Key [Options] > Send > Via Bluetooth.
4. Select the target device from the device list, and press the OK Key to send.
Email
1. Select your desired file, and select Left Soft Key [Options] > Send > Via Message
2. Enter your email address. press the OK Key to send.
3. You can now download the file from your computer.
Aug 31, 2015 | Alcatel Cell Phones
It says Bluetooth streaming .. what is that? i cant seem to find my speaker on bluetooth
It may go under another name..some actually show up has headphones..check the manufacturer. Do you have the speaker in discover mode? If not your source cannot see it. It must be not only paired but connected in order to communicate with it's source..If it is steaming and you can't hear anything...sometimes you must pair and connect the speaker before you launch the source... good luck!
Mar 11, 2015 | JBL Charge Wireless Portable Speaker for...
How do I enable bluetooth on my gateway NE56R10U laptop?
It doesn't have built in bluetooth. Buy an external USB dongle.
Dec 24, 2014 | Gateway NE56R10u Laptop Intel Celeron...
Asus laptop how do you get no wifi
Turn on your computer and locate the Wi-Fi icon.
This could be located on the upper row on a laptop it will have the radiation look (((·)))
Make sure its pressed on.
When you turn on an Asus laptop's Bluetooth function, you allow cell phones, headsets and any other Bluetooth device to be synced with or found on the laptop.
You can use Bluetooth on a laptop to listen to music on a headset or to sync and transfer files from the computer to the device.
If the Asus laptop has Bluetooth wireless technology preinstalled, you can enable Bluetooth access by changing the settings in the control panel.
Click the "Start" menu and open "Control Panel."
Select "Hardware and Sound" and "Bluetooth Devices."
If the "Bluetooth Devices" option doesn't appear, your laptop does not have Bluetooth capability.
Open "Bluetooth Settings."
Click the "Allow Bluetooth devices to find this computer" checkbox in the "Options" tab.
Click "Apply" to save your settings. Click "OK" to close the window.
Change settings for a Bluetooth enabled device
http://windows.microsoft.com/en-US/windows7/Change-settings-for-a-Bluetooth-enabled-device
Jun 10, 2013 | Acer Computers & Internet
My philips sbh6017 cant connect to my bluetooth enabled laptop?
Try checking if your bluetooth driver is updated. You can use RadarSync to scan your computer. The software will show you which ones are outdated and it will show you the available updates. You can either Google the updates or buy the license of RadarSync to let it install all automatically.
David
Mar 05, 2013 | Computers & Internet
Acer Aspire 3618AWLCi bluetooth
Activate the Bluetooth features of your Acer Aspire to unlock your laptop's wireless function.
Bluetooth technology allows your computer to control and share data with external devices without having to use a connection cable or download drivers. In order to establish the connection with other enabled devices, you must first enable the Bluetooth antenna so other devices can locate your computer.
Press the "Bluetooth" button found just above the keyboard. The LED above the button should illuminate. Click "Start," "Control Panel" and "Add a Device." Your Acer scans for other Bluetooth devices in the area. Click the name of the device in the window that appears, and click "Next" to establish a connection with the external device.
Feb 03, 2013 | Acer Aspire Computers & Internet
How to activate bluetooth on asus k55a
Asus manufactures computers, notebooks, motherboards and other PC components. Some of their machines have Bluetooth capability. You can use prompts in Windows to make sure that your Asus's Bluetooth capability is up and running.
Open Bluetooth Settings
In the task bar, right-click the Bluetooth symbol, then select "Open Bluetooth Settings." If there is no Bluetooth icon in the task bar, go to "Start," then "Run" and type in "bthprops.cpl." Click "OK" to open the Bluetooth Settings window. b> View Options b> Click on the "Options" tab, and select the "Turn discovery on" check box. Click "Apply." b> Allow Devices b> In the "Connections" section, select the check box for "Allow Bluetooth devices to connect to this computer" so that Bluetooth devices can connect to your Asus. Click "OK." b> Testing for Bluetooth b> If you are unsure whether your Asus is Bluetooth capable, try typing in the "bthprops.cpl" command in the "Run" box. If it's unsuccessful, your machine isn't Bluetooth capable. Hope this helps.
Dec 08, 2012 | Computers & Internet
How do i connect the bluetooth?
depending on your device usually there will be a bluetooth connection on the device which plugs into a usb port on your computer
you will have to make both your computer and the device enable bluetooth connection(make it discoverable) you might need to download some bluetooth drivers or software to activate your blutooth device
http://download.cnet.com/%7Bvalue=http://www.download.com/bluetooth-driver-ver-5/3000-2110_4-149801.html
to suit multiple usb devices
· Operating system: Windows 95/98/2000/XP/2003/NT/XP 32-bit/AMD 64-bit/2003 32-bit/AMD 64-bit
hope this helps
Aug 24, 2011 | ASUS Computers & Internet
Hi every time i turn on mu vaio pc a message tell me that "BTWUIEXT.exe has stopped working" and because of this i cant use my peripheral blutooth devices like cellphone and etc. also another...
To Fix this you can try the following below:
Method 1:
Check to see if the Bluetooth services are enabled. To do so, follow these steps.
a. Click on Start
b. Type "services.msc" (without quotes) and press enter.
c. In the list find Bluetooth support services and double click on that.
d. Ensure that the service is both set to automatic and started.
Method 2:Check to if these are the settings you have. You can set several options for how your computer finds (or is found by) Bluetooth enabled devices.
a. Open Control Panel by clicking the Start button and then clicking Control Panel.
b. In the Control Panel search box, type Bluetooth, and then click Change Bluetooth settings.
c. In the Bluetooth Settings dialog box, click the Options tab and do any of the following:
o To make your computer discoverable to Bluetooth enabled devices, select the check box for "Allow Bluetooth devices to find this computer."
o To allow you to add Bluetooth enabled devices to your computer, select the check box for "Allow Bluetooth devices to connect to this computer."
o To be notified when a Bluetooth enabled device is trying to connect to your computer, select the check box for "Alert me when a new Bluetooth device wants to connect."
Alternatively you can go to the device manager and make sure all drivers are installed for the driver.
Nov 23, 2017 | Computers & Internet
My Laptop specifications are, ASUS F80Q, dual core, 3 gb ram, Windows 7 ultimate. when i first installed windows 7 (long time ago) it detected my bluetooth device, but now in the middle suddenly it...
Seems like your Bluetooth and Wifi settings are disabled from BIOS.
On laptops usually there is a setting in BIOS where you can disable/Enable Wifi+Bluetooth. Shutdown computer Turn on computer and press "F2" to go to BIOS settings Find settings for Wifi+Bluetooth and set it to default.
Save settings and restart computer You will be able to see your Bluetooth and Wifi.
Hope this works
Jun 29, 2011 | ASUS F80Q-X2AM Notebook
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
