Question about Samsung CLX-3175FN Color Laser All-in-One Printer
Samsung clx 3175w horizontal lines
All supplies are o.e.m. i can wipe off the transfer belt and get rid of the problem for maybe one page then they are back black and yellow across the page. the drum looks good and does not have the bars on it
    Habit-Forming:
  • Samsung Expert
  • 150 Answers
TRANSFER BELT UNIT COMPLAINT REPLACE TRANSFER BELT OR TRANSFER BELT WIPER BLADE
Posted on May 08, 2014
  • 1003 Answers
SOURCE: Black lines across page
are black lines appearing on paper after printing from computer or when a fax is sent or recieved or both?
Posted on Jan 15, 2008
  • 670 Answers
SOURCE: Samsung CLX-3160FN Vertical lines when printing black
This is a very common problem with Samsung CLX-3160 and CLP-300 printers. The real problem is that the developer blades get dirty with the toner. Buying a new imaging unit will only fix the problem for a short period of time then it starts to get buildup on the developer blades.
You need to clean the developer blades. If there are streaking on any color, then also needs to be cleaned.
To clean the developer blades, look to this link. http://losingambition.com/clp300imagefix/ It describes how to clean them. It only takes a few minutes to do once you get the developers out of the unit. Just be careful when you clean the edge of the blades. You need to make sure that the residue is completely removed from the edge. Also be sure that when you reinstall the blade that the little foam does not get trapped below the blade. Otherwise when you print the side where the blade is not properly installed will have too much color.
If you are afraid of messing your printer up, then you need to buy a new imaging unit. They go around $100.
Posted on Dec 24, 2009
picipolman
  • 9 Answers
SOURCE: replacement transfer belt on my Samsung CLX-2160 not recognised?
enter tech mode by pressing menu>idcopy>left>right>menu>back>menu ,then in data setup clear all memory and clear count
Posted on Jul 28, 2010
  • 1456 Answers
SOURCE: I have a Samsung CLX-2160
Hello
Perform a head cleaning by opening up your printer in "Devices and Printers." Click on the start menu, and then click on the "Devices and Printers" option located in the bottom right corner of the start menu panel. Right-click on the printer that is giving you trouble to bring up the printer properties.
Click "Troubleshoot" on the pop-up menu to start up Windows automatic troubleshooting. The troubleshooting program wizard will run and ask you a couple of questions about your problem. Complete the troubleshooter, and then print another page and check it to see if any lines appear.
Check your task bar for any printing software that will show you the ink levels. Check the indicators on the printer as well to make sure the ink isn't running low. If the ink is running low, replace the ink cartridges based on the user manual provided with the printer.
Clean the print head of the cartridge by removing the ink cartridge and taking a corner of the cloth and dabbing it in alcohol. Run the cloth over the ink deposit point found in the lower bottom region of the print cartridge. Allow the cartridge to air dry before reinserting it into the printer.
Check the printer for any paper jams, and run a nozzle check and cleaning from the printer. The printer has menu buttons and features with which you can manually perform much of the maintenance that is required to keep it running at top-notch levels.
Posted on Nov 22, 2010
SOURCE: samsung clx 3175 problems. some horixontal and
Hi Harish and others,
I didn't see all of the thread but:
I have a clx3175fw which for now 3 months only have printed with smears, lines, and ghost-images from preceeding pages.
shortly before trashing the printer because just getting a quote on fixing the printer in shipping whould be close to usd 150. Actual fixing price would probably be higher. If it hadn't been for the fact that I have a stash of toner and the usual consumables for the next 5 years of private use I would have trashed the printer!
BUT: a guy called Michael Ionita (Austrian I think) posted this fix which I finally found via google. And it just worked like a charm. I think it took me less than 8 minutes to fix the printer. And now I know the drill I'd be able to do it en 3 minutes next time. My only comment to his instructions is as follows: where he states "Use a small white paper and try to stick it into the top - like shown": make sure you follow the angle of the glossy plastic from the back of the printer and upwards - AND: "trying" is not enough, you have to push it firmly to squeeze it up to where the toner residuance should be removed. No violance needed - just try harder until you see the paper is picking up toner - and you should be home free.
Br, Jens K from Copenhagen.
http://www.ifixit.com/Guide/Repairing+Samsung+clx-3175+Colour+Laser+Printer+Fix+black+vertical+lines/9183/1
Posted on Mar 13, 2013
Installing samsung clx6220 image unit
See page 103 of http://downloadcenter.samsung.com/content/UM/201112/20111205134621713/EN/English.pdf. It looks like the clx6220 uses a transfer belt to transfer all the different toner powders to the paper.
see
http://www.genuinetonercartridges.com.au/genuine-samsung-clp-620nd-clp-670nd-clx-6220fx-clx-6250fx-page-image-unit-transfer-belt.html
The transfer belt unit is refered to also as the image unit !
Also each toner cartridge contains the OPC drum and is replaced when you replace a toner cartridge by the look of it.
You need a transfer belt to transfer the image to the paper and this is why they call it an image unit.
I am guessing that the transfer belt needs replacement !
Sep 08, 2014 | Samsung CLX6220FX AllInOne Laser Printer
Horizontal black and yellow lines across pages any mode
I have the same issue. It would be great if someone had an idea how to address, as Samsung has no idea.
Feb 15, 2014 | Samsung CLX-3175FN Color Laser All-in-One...
Scan/copy issue: horizontal lines and bulb red
It's the scanner fluorescent lamp faulty, replace the scanner will solve the problem
Jul 15, 2017 | Samsung CLX-3175FN Color Laser All-in-One...
I have a Xerox Phaser 6100. I just replaced the imaging unit and the transfer belt. Now my copies are coming out with lines across the whole page. one page that I printed came out wiht all colored lines...
Try doing a "stop test." Stop the print process at various stages, and see if which component creates the defect.
For instance, if a print takes 20 seconds, during the first 10 seconds, the drum is generating the image to transfer to the belt. If the image is bad on the drum, then that is your culprit. If not, then see which unit creates the problem.
Also, what color is the line?
After the unit gets to the transfer belt, you should check the transfer roller and fuser.
Whit www.iteminconline.com
Jun 07, 2011 | Samsung CLX-3175FN Printer
White line down the middle of page on samsung clx-3160n
You need to replace the drum unit or the transfer belt. Both are high-yield consumables with an expected life of 15,000 pages. However, it is common that these parts fail before the expected life.
Apr 15, 2010 | Samsung CLX 3160fn All-In-One Printer
I have a samsung clx-3160 fn printer, approx 1.5 yrs old. Has worked well, however now the right side of each page is slightly faded compared to the left side. I have cleaned out what I can and replaced...
I'm not sure if it is a similar problem but I have a CLX-3170FN and it has started to run a strange line down the page, and part of the page was smudged. I cleaned it all out and looked at the drum etc and it was all fine. Then I spotted there is a plastic belt that must run like a conveyor belt behind the drum and there is a split running along it - Found out it is called the transfer belt. It was difficult to see which I why I am suggesting it to you. Now I just have to find how I can replace mine. :)
Feb 22, 2010 | Samsung CLX-3160 All-In-One Laser Printer
I have a line going down the center of the paper
Hi, I have a CLX-3170FN and it has a line down the centre. I've looked, cleaned everything out etc. I found a plastic belt running like a conveyor belt behind the drum, it has a split running down it which lines up with the line on the page. Not sure if it is replaceable but apparently it is called a transfer belt. Hope this helps others.
Jan 28, 2010 | Samsung CLX-3160 All-In-One Laser Printer
Samsung CLX-3175FN Color Laser All-in-One Printer Logo
563 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
