Question about Vizio M550NV 55 in LCD HDTV
Picture on Vizio is distorted with striations and lines across screen
The picture is mostly red and slow moving. The picture is completely distorted. Even when I select menu, you can only see it very faintly in the background. I've unplugged the unit and gone thru the steps of holding the power button while unplugged. Nothing helps. It seems to be getting worse. The LED lights are showing thru the holes on the back at the top of the TV. This just started today with a blank screen and sound then the picture slowly started showing up completely distorted. It first had vertical lines then those went away leaving a weird slowing moving picture. This TV is only 2 years old and I bought it new.
  • Michele Murray Feb 15, 2014
    I've attached a picture of what the picture distortion looks like.
SOURCE: No Sound, No Picture
I had the same issue on my Vizio and fortunately it was still covered by the Costco extended warranty from where I purchased my tv. The service tech came out yesterday with a power supply and main board which is what I understand is usually the issue with your and my symptoms. He replaced both boards although he felt the issue was in the main board 3647-0072-0150 and not the power supply. Tv is working just fine now and actually may be even a little clearer after the board switch. I understand you can purchase the boards and from what I've seen the tech do, it is no more difficult to replace than if you were building a computer if you are comfortable with that. The most time consuming part of the repair was removing and replacing the screws.
Posted on May 17, 2009
  • 10 Answers
SOURCE: Vizio screen went off but power light is still on
may be a mainboard problem. If you can see the orange light it usualy means that there is power running through the TV... usually inverter boards are a problem when you do not see any backlight at all.
Posted on May 23, 2009
  • 20 Answers
SOURCE: Vizio picture blank but lights up
you need to call a repair tech and have them check for blown capacitors in the power supply and the x & y sus (the circuits that light up your screen) for defective capacitors. they are very obvious to see-normally the top a a capacitor is flat, but in this case if bad they will be bowed out -rounded on the top.
Posted on Apr 21, 2010
  • 111 Answers
SOURCE: Flickering screen and lining-out on top inch at first
This sounds like tiling. are you using a cable box?
Posted on May 07, 2010
  • 88 Answers
SOURCE: tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
Posted on May 17, 2010
I have some distored blue color across the screen
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 15, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Line of distorion (or picture shift) on screen
Same thing happened to me but it was my cox hdtv/dvr box, I exchanged it and it resolved the problem.
Jan 04, 2010 | Televison & Video
Seeing red, blue,geen wavy lines across screen which distorts picture while viewing.
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
*Screen Looks 3-D
*Colors wont align
Jan 02, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
I have Diagonal lines moving across the screen.
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 15, 2009 | Toshiba 51H83 51" Rear Projection...
Wavy lines appear across the screen
*Screen Looks 3-D
*Colors wont align
May 01, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Viewing problems
*Screen Looks 3-D
*Colors wont align
Nov 01, 2008 | Samsung HCL5515W 55" Rear Projection...
Red and green fuzzy waves across the screen
my screen just became distorted (red picturer to the upper right & green picture to the bottem left ? can you help me ? wuzuphippie55@yahoo
Sep 08, 2008 | Philips Magnavox 9P6034C 60" Rear...
Picture Greatly distorted all of a sudden by many yellow lines
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
Jul 07, 2008 | Zenith D61W25 61" Rear Projection...
Sony 65 inch screen tv
The lines you saw, i;m sure they are the ones called retrace lines but know the failure could be located on the red CRT board. Most likely the video amplifier is defective and not necessarily the CRT.
What is the model number of your TV?
Jun 17, 2008 | Televison & Video
Vizio M550NV 55 in LCD HDTV Logo
60 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
