Question about Panasonic Palmcorder PV-DV102 Mini DV Digital Camcorder
Won't work with tape installed
Seems like the camer functions normally unless I pop a DV tape in it, then the Power LED blinks and it shuts off! Also, after downloading and installing all the necessary software on my pc, it won't recognize the camera. If I try to open Drive E it says INSERT DISC!
  • krg12267 Dec 08, 2007
    Camcorder was working fine until recently none of the controls will work, the power light flashes then the shuts off after a few minutes. This has been a great comcorder up until now....Help!
I had this same problem. At my wedding, and didn't get to record it because of it. When I got home I put a new tape in and worked fine. It was just a bad tape.
Posted on Nov 03, 2008
Red light blinking won't accept tape
If a tape "hung" up and it won't accept one you have a loading issue.
The unit may use a belt to drive the tray or a geared mechanism.
In any case someone needs to open the unit up to "see" what is happening. Most of these a tape can be inserted with power off and manually cycled into the unit to see the issue---we usually use a old cassette with the tape inside removed to avoid issues.
If you cannot do that consider looking for a shop who will (some no longer work on this type of equipment.)
Dec 05, 2012 | JVC BR-DV3000U DV/Mini DV VCR
Mini DV Tapes Won't Play
Please give the model and the make
Apr 16, 2008 | Sony DSR-11 DV / Mini DV VCR
Computer won't turn on
try removing the battery and see if it runs on mains power, if so you need a new battery. another possibility is that the system has overheated, although you would normally expect it to start up once it has cooled down, unless it has done irrepairable damage!
Mar 08, 2012 | HP Mini 1000 Netbook
Quantum Tape
Describe the installation applicationSmall business large business ?Also the drive model ?
Dec 04, 2011 | Computers & Internet
Unit power LED blinks then shuts down
Blew out the cassette mechanism and cleaned also. Disassembled and re-seated all connectors and ribbon cables. Blew out lens assembly.
Dec 30, 2008 | Panasonic NV-DS65 Mini DV Digital...
No record or playback
had the same problem, it seems to do fine without a tape in it :so I took the tape in and out a few times and I guess the alighnment was better so it works for Now..So Give it a try
Dec 12, 2008 | Panasonic Palmcorder PV-DV203 Mini DV...
Error Message Reconect Power even if power is connected
It sounds like the tape door is out of alignment, causing stress on the tape and the inside mechanical system.  Requires a visit to the service shop.
Jan 28, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
CST.IN Light
Put a tape in and eject it. It will then work. Just had this problem. CST IN means the VCR thinks it has a tape in. Trust me... Very fixable.
Jan 19, 2008 | Hitachi DV-PF2U DVD Player/VCR
Panasonic DV-Camcorder tape problems.
i used to service quite a few older camcorders, many of them had some sort of rubber band pulley mechanism and the band itself would go limp (corroded) and not providing enough torsion to drive the mechanics of the camcorder
(imagine a slipping fan belt).
you'll have a real hard time getting an exact replacement, and at great expense.... i've had success splicing a normal rubber band, simply razor cut the ends to meet and use the tiniest dot of superglue to make a band of your length... an untreated rubber band would maybe last about a year unless you wipe it with a coating of silicone which extends it's useful life by 10 times (i have a diy treated rubber band in an older cassette deck still running strong after 12 years)...
good luck with the fix.
Jan 01, 2018 | Panasonic PV-DV702 Mini DV Digital...
Panasonic Palmcorder PV-DV102 Mini DV Digital Camcorder Logo
97 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
