Question about Water Heaters
Reliance 501 electric water heater
The "Box store" elements will not screw into the bottom threaded hole of my 40 gal reliance 501, seem smaller is there a difference?
  • Water Heaters Master
  • 5,245 Answers
Reliance-Rheem may have changed away from generic parts so you have to buy special order parts from them.
I have not heard of this before for elements... but Rheem does that for other parts.
Avoid Rheem products.
Rheem also makes a 1-3/4" element to fit Marathon water heaters, instead of standard 1-1/2"
Actual thread size for standard water heater is same as 1" pipe, except straight thread instead tapered pipe thread.
See if 1" pipe will thread into water heater element opening.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Gene Haynes
Posted on Feb 15, 2014
5 Suggested Answers
  • 252 Answers
SOURCE: I installed a now 40
How they work. First you need to know that cold water goes into the tank near the bottom (because of the "dip tube" inside the tank) and hot water is taken out at the top. Also hot water naturally rises.
so... when the tank is full of cold water the top element will come on and heat up the top 1/3 of the water then the bottom element will come on and finish heating the rest of the tank.
Posted on Apr 20, 2009
  • 9 Answers
SOURCE: 50 gal. Reliance electric hot water w/bottom element problems
Willard when you say it throws the reset button,do you mean the breaker on your fuse box of your home?
If you mean that then yes it could be a bad element.The bottom element takes all the abuse on a electric hot water heater. They can short out,and need to be replaced.
Posted on Dec 01, 2009
SOURCE: I have Reliance electric water
Your water heater has two 4500 watt elements so water heater is 240Volts, and water heater is rated 4500 watts. Both elements are not ON at same time, and this is called non-simultaneous operation.
The element might have been smaller in length, but it will work fine.
Why is it smaller. I don't know. Elements are different from manufacturer to manufacturer.
The 501 does not use a special element.
Local box stores and hardware stores sell elements in water heater department.
The wattage of element is printed on end of each element.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 20, 2011
  • 5245 Answers
SOURCE: Reliance 501 Hot Water Heating element for 30 gal tank, where to purchase
You do not need special parts.
Wattage is printed on end of each element.
Buy generic elements at hardware store.
Posted on May 22, 2012
No hot water
It is probably the thermostat. I would suggest replacing that next.
Feb 24, 2014 | Reliance & 40 Gal Electric Mobile Home...
Apr 21, 2012 | RELIANCE ELECTRIC WATER HEATER
I have Reliance electric water heater 501: 40 gallon, 2x4500w. Where do I buy the bottom heating element? I went to the plumbing store and get one but it is a little smaller than the old one. why? I am...
Upvote the help.
May 20, 2011 | RELIANCE ELECTRIC WATER HEATER
The two elements on my 40 gal. Reliance electric water heater are frozen tight. The unit is fairly new, Model 501 w/ two 4500 amp coils. Using the provided socket and then going out and buying a 1...
WATER HEATER EXPERT HERE
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 19, 2011 | RELIANCE ELECTRIC WATER HEATER
Reliance electric water heater - A 95 [1995] Model 5 40 / 3500 W Max. - 240 AC Volts. Checked upper element and thermostat [fine]. Lower element and thermostat have lot of corrosion due to...
The salesman at the hardware store should be able to confirm my answer.
Match up the voltage, wattage and thread size and you should be good.
My element burned out two years ago and aside from draining the water, the job only took a few minutes and I was back in service.
Gary
Dec 15, 2010 | RELIANCE ELECTRIC WATER HEATER
1992 Reliance electric water heater model 501 has two 4500 watt heating elements , there is no hot water.
Check the breaker and top thermostat and make sure they are not tripped. Move onto replacing elements if above is not the problem.
Turn water and power off to heater and attach a water hose to bottom of heater to drain down tank. May have to open hot side on a facuet to get it to drain.
Once drained remove elements with 1 1/2" found at local hardware stores. once elements removed and new ones in place. Turn water on and get the air out of the system. Once water is flowing from the hot side from all of facuet's in house.
Once all air is out now yaou are resady to turn power onto heater.
Oct 09, 2010 | RELIANCE ELECTRIC WATER HEATER
Dec 01, 2009 | Reliance & 50gal Electric Water Heater
Water Heaters Logo
100 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
