Question about Garden
How do a start a Kawasaki tg25 trimmer? - Garden
Why does my kawaski khs750b hedge cutter start easily but stop when tilted in a certain position
Answered your own question : generally the fuel supply to the motor is through a small hole at the base of the tank , at full you could probably tilt more aggressively and the line is getting fuel , however as the fuel runs down the fuel is on one side of the tank and is essentially not getting fed to the motor , you'll notice tilting it from horizontal to left you will get cut off , tilt to right it'll keep running depends on the locations of fuel line however , cars pre fuel pump days had similar problems
Sep 19, 2014 | Kawasaki Outdoor New kawasaki Hedge...
In need of manual kawasaki hedge cutter
try the piratebay
its a utorrent thing. type in like kawasaki hedge cutter kht600d manual
Mar 13, 2012 | kawasaki Kht600d Gas Hedge Clipper Trimmer
Kawasaki khd 600A hedge trimmer just wont start.it runs for a second and stops
Bit late to help the owner of this question and yes it could be a carbie issue but also check the idle speed. If it has dropped out of calibration and is idling too low it will start then stop. Try starting with some throttle, keep it running if you can until it warms up then let the throttle go back to idle. If it stops check to see if opening the idle screw solves it.
Sep 24, 2010 | kawasaki Garden
We have a Kawasaki Hedge Trimmer TF22. I need to know the ratio of gasoline and oil to put in it
The oil ratio for the trimmer is 50 to 1.
Good luck and please rate 4 thumbs uf for the free answer
Jun 26, 2010 | kawasaki Garden
Need manual for kawasaki Model FC-150V 6.75 engine for DR TRIMMER/MOWER
You did not specify what manual you needed. But Kawasaki has a website, www.kawpowr.com. You go to it, look under engines; parts catalog; 4 stroke engines; and put in your model and it will come up with a parts catalog for you. Hope that helps.
Good day.
Oct 17, 2009 | Garden
Kawasaki KHT600S hedge trimmer cranks but won't throttle up
need a carb kit and a new fuel filter in the gastank
Aug 10, 2009 | Garden
My Kawasaki Trimmer is running bad. It will run
Check the throttle cable. You probably need to tighten it up. You will find it on the left hand side of the engine that is mounted it the top of the trimmer, thats where it normally is, but with the japanese you wouldn't know!! Have a look for it, won't be hard to find anyway. Also check the finger throttle. probably slack too.
Once you found the throttle cable at the top, find a optimum idling value and then tighten the cord at that point. (there should be an adjustable screw there.)
Hope it help's.
Hughie.
Jun 16, 2009 | Troy Bilt Tb70ss Gas Trimmer
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
