Question about Fantom Vacums Lighting Canister Vacuum
How do i fix the suction of fantom fc285hw bagless vacuum
5 Suggested Answers
yeroc
  • 397 Answers
SOURCE: telescopic handle
sometimes the locking mechanism for the wand wears out, make sure u have it all the way in and look where it locks and see if it looks worn
Posted on Jan 21, 2008
defrankond
  • 65 Answers
SOURCE: fantom fury vacuum
HOW DO I CHANGE THE BELT ON THE FANTOM® THUNDER® AND FURY®? a.gif fantombeltchange1.jpg
  1. Unplug the machine.
  2. From the front of the machine, remove the collection bin.
  3. Facing the back of your vacuum, remove each of the Philips head screws located above each of the rear wheels. (Figure 1)
  4. To remove the base cover, place your thumbs in the two screw holes in the back of the machine. Push forward and up on the screw holes to disengage the 3 cover locking tabs. Put the cover off to one side, and go to the front of the machine. (Figure 2)
  5. Check the drive arm for any black streaks which indicate residual rubber from the last belt. The drive arm is located on the right side of the motor. The easiest way to remove any residual rubber is with some nail polish remover on a rag or with steel wool.
  6. To attach a new belt, remove the brush from the base of the machine by pulling up straight up with two hands.
  7. Take the new belt and hook it over the steel drive arm. Pull back on the belt slightly, to create some tension.
  8. Put the brush inside the belt loop so that the track for the belt is aligned with the belt itself.
  9. Replace the brush by aligning the metal end so the points face downward. (Figure 3)
  10. Rotate the brush by hand to check that the belt is running freely and easily in its designated space between the bristle.
  11. Replace the cover by placing the nose in first. Once in place fasten with the two cover screws and then replace the collection bin.
Posted on Nov 30, 2008
bigTkahuna
  • 4 Answers
SOURCE: Vacuum is whistling and there is no suction through the hose.
Sometimes mine "wand" has no suction too. . . Make sure the vacumn column is clicked into the "standing" position, don't have it at an angle. Also you may have to play with the settings on the bottom part AND the power button together. I think this vacumn sucks (pardon the pun) mine turns off after 10 minutes of use, then I let it sit for an hour and then it'll start again. POS!
Posted on Jun 29, 2009
  • 8404 Answers
SOURCE: vacuums normally but no suction through the wand
Keep cleaning ... there is a clog somewhere.
Thanks for your intrest in FixYa.com
Posted on Feb 19, 2010
Why is there NO Suction from brand new Fantom?
some brands have a small plastic piece that slides across the tube/handle and if it is in the wrong position there is no suction to the tube /handle .. Have you thought to call the manufacturer for tech support or warranty .
Jul 12, 2015 | Top Vacuums
Vac hose clipping collar : one clip piece broken off need new collar
thats going to be a tough find. fantom parts are pretty much obsolite your best bet would be to either find a used one somewhere or just get creative and find a way to fix it so it can be used
Jan 02, 2010 | Fantom Vacums FM741 Twister Bagless...
Fantom vacuum
sounds like a partly clogged filter
Mar 10, 2008 | Fantom Vacums FM741 Twister Bagless...
Fantom Twister
On my fantom cylone I use a 2 foot wire with small hook. Open bottom and push wire up the vacuum channels. There is also a channel that goes to the brush. Check for suction at hose. If none then your one of your channels going up are blocked. If you have suction at hose but none at floor brush then channel to floor brush is plugged.
Dec 09, 2007 | Fantom Vacums FM741 Twister Bagless...
Fantom Vacums Lighting Canister Vacuum Logo
75 people viewed this question
Top Fantom Vacums Vacuums Experts
Richard Agent
Charles T Nevin
Charles T Nevin
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
