Question about Dell E153FP 15" LCD Monitor
Dell E172FPb 17" LCD Monitor Problem
My dell monitor screen keeps going black after being on for a few seconds. If I turn it on and off the picture is there for about 5 seconds then the monitor goes black. It is definitly a monitor issue, I've put a different monitor on the computer and its working fine, also tested the flat panel on my laptop and had the same issues. I looked for a reset button cant find one anywhere or how you even get the back off of the monitor.It is now out of warrenty and I am not sure how to go about fixing this problem.
  • 15 more comments
  • slash56mt Nov 17, 2007
  • dvarella Nov 25, 2007
    i have a problemwith my nonitor E172FPB once i turn it on the i get theimagethen it goes off again but thepower light remains on..what should i do?
  • Anonymous Dec 21, 2007
    I have the same problem! Help!
  • hiemmer Jan 05, 2008
    First my monitor came on for 1 sec then started flashing. The green power button and the screen both flashed about once every second. I replaced two transistors and now the screen comes on for a couple of seconds then goes off and power light stays lit. Which capacitor did you replace retiredroger? I cannot find a cap with that rating.
  • Allison4 Jan 22, 2008
    My Dell monitor will display info for a few seconds when I start up my computer before going blank. How can I fix it?
  • Mees Goldstein Mar 15, 2008
    i have got the same problem but than with the e153fp monitor!
  • boilerup Mar 15, 2008
    I have the same problem. I turn on the monitor and after 2 seconds it goes black, but the power button remains on. Help.
  • Yanto62 Mar 21, 2008
    Ditto exactly the same problem on my E173FPc - have replaced the monitor with a 20" samsung but would love to fix it to use as a second monitor to extend desktop
  • Anonymous Mar 24, 2008
    i have a problam to open for mantanas
  • d2008 Apr 01, 2008
    My moniter turns on then it would turn off. i press the button on the screen and it say in power save mode. i checked the wire when i took it off it comes on and a screen saver shows up so i plugged the cord in the desktop and it shuts right of with the same message . what do i need to do?
  • Anonymous Jun 07, 2008
    My Dell E153FP monitor will only stay on for about 5 seconds after booting up and then goes black. Power light is still on. I thought this may have to do with the OSD lock and unlock feature or maybe the factory reset feature. I've done both. If I can get it to unlock (while looking at the black screen) then the monitor will stay on until I shut down and boot up the next day & then it's the same thing all over again. Isn't there a way to keep the OSD setting unlocked at all times? Could it be something else? The monitor is a couple years old & this just started happening. Thanks!
  • domonique908 Jan 07, 2009
    my monitor has a lock that i didnt put there. i got it like this i see no picture what do i do
    domonique90808@yahoo.com
  • Anonymous Apr 03, 2009
    I also have a Dell Monitor, Ultra Sharp, not sure what modle, 17" which intermittenly goes black. It seems to go black each time I click on my mouse ( may be a coincidence). Can you help?
  • Anonymous Apr 26, 2009
    lock/unlock flashing padlock
  • BERNICESMITH Nov 29, 2009
    have a dell monitor, never had problems with it, checked the power going to it, seems fine, but the screen is black and the indictor light is constant yellow, like sleep mode, took whole system down and re booted, same the, if I pull power cord to mointor the start up log go comes up and then goes black....what is wrong???
  • kasb Dec 06, 2009
    my monitor goes black after a few seconds.. HELP
  • Ivan Mar 12, 2012
    Try to connect ccfl with external inverter and take a look does all of them works
    LCD monitor backlight problem
  • 46 Answers
Your inverter power supply has gone bad. You will need to replace the whole board or replace the the 2sc5707 transistors in the inverter area. Check out this link for installation videos and how to for that model
http://www.lcdrepair.us/Installation.html
They also sell the whole board as well as repair kits
Posted on Jun 21, 2008
C2? 1000uF 50vdc Electrolytic, worked for me, identical problem.
Posted on Jan 05, 2008
  • 981 Answers
If your E153FPe comes up for a few seconds then blanks -but left the LED green- it is a case of the inverter board going bad as indicated; I just pulled the power board and I see C922 (1000uF, 16v, 64 degrees C) has bulged out a bit. Perhaps replacing it will work...ah, should've trimmed the leads after soldering. Cool, that was nonfatal. Still gotta remember to plug in the data cable to the panel...aaand, success.
Posted on May 16, 2009
Admin48 u r genius it worked thanks
Posted on Apr 11, 2009
My monitor boots up then straight into power saver mode how do i get it out of power saver mode
Posted on Dec 25, 2008
Troubleshooting DELL E173FPB LCD Monitor with power blink symptom is quite easy if you know the right procedure to test it. There are two sections in the monitor that can cause power to blink. It is either primary or secondary section or even sometimes both sections can be faulty. So to isolate as which section is giving problem. I used an automobile 12 volt light bulb (brake light) and connect it between the 12 volt supply line and cold ground with the fuse removed. If the bulb still blink chances is very high the power primary section have problem.
Do not overlook the other voltages line as well such as the 3.3 and 5 volts. If any components shorted that gets the supply from the 5 and 3.3 volts, the power also may blink. If the 12 volts bulb lights up we can assume that the power supply is working fine and something shorted further down the line that makes the power supply to blink. If the bulb lights and you continue to check the power section, it will be going to waste your time. You should now concentrate on the secondary section circuit such as the four transistors C5707 that drive the high voltage transformer in the inverter board.
Just think these transistors like horizontal output transistor (HOT) in the CRT monitor that drive the flyback transformer where it worked so hard and chances for it to breakdown is very high. Checking the four transistors off board found one of them have a shorted reading with an ohmmeter.. This transistor can get faulty by itself or it could be some others components that caused it to develop a short circuit such as a defective high voltage transformer but all of the four high voltage transformers checked to be okay with ringer and ohmmeter test.
Now, here is the secret that I’m going to reveal. If you just replace the defective transistor only, chances is very high the transistor or another C5707 transistor will breakdown again. Usually what a technician does is to test the other transistors with either an analog or digital meter. If you use both meters to test the transistors then you have missed out on the faulty transistor because both meters won’t reveal to you the hfe reading of the transistors. Only some digital meters have the hfe checking feature. In other words, you have to use test the hfe reading of a transistor. Although you can replace the other three transistors directly, why not we do some detective work to find the cause of the problem?
Using the Peak electronic atlas component analyzer, I could clearly see the different between a good and a bad transistor. A good C5707 transistor has hfe reading from 320 to about 390 but the bad one reads 467! The other two C5707 transistors have reading about 350. In the above case only two C5707 transistors were replaced and you save the other two. I had burn in test this LCD monitor for many days and it worked perfectly fine.
Conclusion- Whether you repair the DELL E173FPB LCD Monitor or any other model such as the E172FPB or E171FPB, basically the testing method is the same. You could also use this testing procedure on other brand of LCD Monitor too.
Jestine Yong is a electronic repairer and a writer, for more lcd monitor repair information, please visit his website at http://www.electronicrepairguide.com/lcd-monitor-repair.html now.
Article Source: http://EzineArticles.com/?expert=Jestine_Yong
Posted on Jan 16, 2008
3 Suggested Answers
  • 4 Answers
SOURCE: Daewoo L700C 17 in. Flat Panel LCD Monitor
www.dtforum.net search here
Posted on Feb 10, 2009
budmrtn
  • 11361 Answers
SOURCE: Dell E172FPt 17" TFT LCD Flat Panel Monitor powers
It will need parts or board repalcement.
Board is only $30, http://www.lcdrepair.us/e172fpt-inverter-power.html
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Replacement board: http://www.lcdrepair.us
Posted on Jan 17, 2011
Monitor cuts out after a few minutes
Sounds to me like a power inverter. Fix it yourself with the parts found on Ebay at a cheap cost to yourself. The entire Dell E173FP 17" power inverter is selling for $29.99 plus shipping.
The fix can be found at: http://syscon.wordpress.com/2007/07/13/dell-dell-e172fpb-lcd-backlight-repair/
Cheers and good luck!!
Nov 05, 2010 | Dell E173FP 17" LCD Monitor
The DELL E172FPb LCD Monitor (switch light flicks green)scr black
hi, extremely common problem for dell 17 in monitors. the capacitors and transistors on the power board internally have gone bad. to get repaired, it may cost 40-50 at a shop. i have repaired these in the past and they always come out well for at least 3 more years. may want to find another monitor though. if you would like steps on how to repair, let me know and i will find my old repair threads to give to you.
May 12, 2010 | Dell E173FP 17" LCD Monitor
You need to open it up and inspect the componente inside, look at the fuse and the transistors in the inverter circuits first, also look for sign of over heating on the board, see pictures here for the guide: http://s807.photobucket.com/home/budm/allalbums
Mar 20, 2010 | Dell E173FP 17" LCD Monitor
When I turn it on the screen stays black with an
it sounds like it could be something called the inverter. not too serious a repair to replace it but you have to dismantle the monitor to do it. If unsure about doing this let your local shop do it.
Jan 04, 2010 | Dell E173FP 17" LCD Monitor
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
My Dell E172FPb flickers & has straight, thin
#1 Connect monitor to another system, make sure the issue is the Monitor, not the video card.
#2 Try a different VGA or DVI cable
If the issue is isolated to the monitor, it is cheaper to replace it than to repair it (Refurb 17" LCDs are $69 on Dell's Outlet
Jul 02, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Dell E172FPb screen blinking
If you've tested turning the monitor on without the VGA cable and it's still blinking I'd say there's a problem with one of the capacitors on the power supply card on your screen, when you're able to check it would you mind telling me the brand / reference of it ?
Nov 04, 2008 | Dell E173FP 17" LCD Monitor
Dell flat screen
REPLACE 2SC5707 IN POWER INVERTER BOARD.
This parts is used to fix Some dell and hp lcd monitor.
DELL E172FPb, E173FPb. HP Pavilion F1703, Pavilion F1503. If you can't get this item to work let me know, I can help I have fixed a lot of these monitor with no problem.
May 01, 2008 | Dell E173FPb 17" TFT LCD Monitor
Monitor
i had a similar issue with my dell E172FPB, I have never seen a E173FP but this link might help you
Oct 21, 2007 | Dell E173FP 17" LCD Monitor
Dell E153FP 15" LCD Monitor Logo
9,689 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
