Question about Dell Inspiron 530 Desktop Computer
Dv051 bios version a04
A03 checkpoint
Make sure that there is no power failure during bios update and you have a power back up of atleast 10-15 minutes. Download the update from Dell's website and double click on the .exe program. Wait for program to finish the job.
Nov 26, 2013 | Dell Dimension 3100 PC Desktop
So if i have a dell dv051, and i go in to the F2 setup utilities how do i set everything up?
Why are you in BIOS setup? Is their a problem? If you are in the BIOS setup and don't know, just leave it alone. If you alter the BIOS you may be opening Pandora Box.
Feb 04, 2013 | Computers & Internet
Hi my dimension 3100, just after the boot the screen stay on the progression bar and no more! I just can read Dell DV051 Series Bios Revision A03 and in the lower corner the logo Intel Inside pentium...
are you saying you are stuck on the screen that says dell on it as soon as it turns on, and that f2 to enter bios does not work? if so, the issue can be related to a bad hard drive or bad motherboard. i have come across this issue alot, normally on desktops, and those are the 2 fixes that are usually the problem.
Jul 08, 2011 | Dell Latitude D600 Notebook
Cod. error a04 on the display
Appliances fault A04 has different meanings depending on the type of appliance. Please see below for further detauls:
Also see our video section for help.
Error: A04,
Machine: Dishwasher,
Type: EV02 Module,
Fault: The selected temperature was not reached within a given time.Check thermistor and heater
Error: A04,
Type: Standard Module + FDW70 + FDW75,
Fault: Heating fault.Check thermistor and associated wiring
Hope helps.
May 02, 2011 | Dishwashers
Dell Inspiron 2310 (all in one PC) does not have physical button for brighness control hance i upgraded the BIOS from A01 TO A04. However I am experiencing booting problem frequently. When i run diagnosis...
You may already know this, but make sure you go into your BIOS and set it to all 'default settings' from the main page, for starters. I'll check back later to see if this helped you. Hope so!
Feb 24, 2011 | Computers & Internet
Hi, When I try to start my Dimemsion 5150C in Windows XP computer, I received one of the following error messages "Floppy diskette seek failure Strike the F1 key to continue, F2 to run the setup...
The "floppy" disk-drive (3.5-inch diskette) on your computer is broken.
Press F1 to ignore the error, and to boot from your C: drive.
Or, press F2 to enter BIOS SETUP, and then navigate through those "setup" screens to tell the computer to "disable floppy seek", or change the setting from "3.5 1.44Mb drive" to "none".
Or, take the computer to a technician, and buy a replacement disk-drive, and get it installed.
Sep 12, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
How do i change my picture size
hi
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
  1. 1
jQuery(document).ready(function(){ jQuery('#jsArticleStep1 span.image a:first').attr('href','http://i.ehow.com/images/a04/qo/52/change-image-size-paint-1.1-800X800.jpg'); }); Open Microsoft Paint. Paint is usually found under "Start," "Programs" and "Accessories."
  1. 2
jQuery(document).ready(function(){ jQuery('#jsArticleStep2 span.image a:first').attr('href','http://i.ehow.com/images/a04/qo/52/change-image-size-paint-1.2-800X800.jpg'); }); Click on the "Image" menu, and choose "Attributes." This will open the "Attributes" box.
  1. 3
jQuery(document).ready(function(){ jQuery('#jsArticleStep3 span.image a:first').attr('href','http://i.ehow.com/images/a04/qo/52/change-image-size-paint-1.3-800X800.jpg'); }); Choose which "Units" you would like to resize your image in. The options are "Inches, "Centimeters" and "Pixels."
  1. 4
jQuery(document).ready(function(){ jQuery('#jsArticleStep4 span.image a:first').attr('href','http://i.ehow.com/images/a04/qo/52/change-image-size-paint-1.4-800X800.jpg'); }); Enter the "Width" you would like the image to be.
  1. 5
jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a04/qo/52/change-image-size-paint-1.5-800X800.jpg'); }); Enter the "Height" you would like the image to be.
  1. 6
jQuery(document).ready(function(){ jQuery('#jsArticleStep6 span.image a:first').attr('href','http://i.ehow.com/images/a04/qo/52/change-image-size-paint-1.6-800X800.jpg'); }); Click "OK." Your image should now be the appropriate size.
Aug 14, 2010 | Lexmark X2500 All-In-One Printer
I can't get into BIOS anymore. It just sails right by when I press F2 and starts up Windows. I've tried DEL and F1 but that doesn't work either. The problem started shortly after I updated the BIOS from...
remove the cmos battery from your motherboard and return it again after 5 seconds, that will restart your BIOS, or you look for the BIOS reset pin on your motherboard just consult your manual as guide.
Jan 11, 2010 | Dell OptiPlex GX280 PC Desktop
Phoenix p4xfcu
try this site:
http://www.opendrivers.com/freedownload/230983/jetway-pm8mp-bios-a04-download.html
Jun 17, 2009 | Computers & Internet
Dell Inspiron 530 Desktop Computer   Logo
24 people viewed this question
Alun Cox
