Question about Samsung 4.5 Cu Ft VRT White Top Load Washer - WA456DRHDWR
We have a samsung top load washer. The washer would stop with a 3E error code. We have tried putting it in the service mode and now we have a U6 and IE error code. What does this mean?
3E error code now we have a u6 and IE. Only 14 months old.
  • 1122 Answers
SOURCE: won't spin heavy loads
YOUR PC MOTOR CONTROL BOARD THAT TURNS THE MOTOR FROM WASH TO HIGH SPEED SPIN HAS FAILED,YOU CAN GO TO SEARS .COM CLICK ON PARTS PUT YOUR MODEL NUMBER IN AND YOU BUY AND SEE ALL PARTS AND WHERE THEY GO ON YOUR WASHER,LET ME KNOW HOW YOU DO-MIKE
Posted on Oct 22, 2008
  • 410 Answers
SOURCE: washer fills up with way too much water.
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the washer ID doesn't mean
anything to me. It's been about 55 years since I had experience with front load washers. However I can refer you to www.applianceaid.com where they have very good and complete trouble shooting and repair information on front loaders. I think you'll find what you need there. Don't worry about the timer, they hardly ever go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Posted on Nov 25, 2009
  • 298 Answers
SOURCE: dear sir, I bought top loading fully automatic
you can contact appliancerepairplanet.vstore.ca for help in this matter
Posted on Dec 08, 2010
TheMobilian
  • 8220 Answers
SOURCE: i have a samsung washer...
Must be usin too much soap.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Feb 03, 2011
cool78259
  • 228 Answers
SOURCE: Washer fault code 3E what
during washing and rinsing when a motor restriction is sensed, the motor stops and then proceeds
to the next waterflow action. if the motor stops working and this happens in one direction 10 times,
the error code 3e will be displayed.you should be able to clear the error code by turning your washer
off and on. or powering it down and then powering it back up. good luck!
Posted on Feb 22, 2011
My Samsung washing machine, front load, showing E3 error, can you help? Thank you
Samsung Washing Machine Error Code 3E = Motor Drive Error or Hall Sensor ErrorWhen your Samsung Washing Machine shows the error code 3e, the most common reason is because of a "wire harness or wiring connection is loose, not connected, or wiring is damaged". Checking the wire harnesses on the motor, hall sensor, stator, control board etc, will usually result in finding a faulty wiring connection or bad wire hareness. Reconnecting or replacing the wire harness or wiring will fix the washer and clear the 3E error. See more troubleshooting info below...
how to fix error code 3e on samsung washing machine Google Search
Mar 23, 2018 | Samsung Washing Machines
My machine leader stoped it give me a number 3E WHAT THAT MEAN
This video will help you diagnose the fault on your samsung 3e error codes and the video will help you solve the problem
Mar 08, 2013 | Washing Machines
What's your problem? I am getting a 3E code during wash and the machine stops
3E == overcurrent detected at the motor.
Open the control panel, there should be a tech sheet in there that explains how to put the machine into service mode (press chime and extra rinse keys for three seconds) and what to do while in service mode to track this down. Once on service mode, you can cycle through and retrieve all diagnostic codes... and lots of other stuff that'll help you track this down.
You can also go ahead and check out the windings on the motor. Unplug harness connector and test from wire insertion side.
Pin #1 and Pin #2 of CN9 == 11.6 ohms
Pin #1 and Pin #3 of CN9 == 11.6 ohms
Pin #2 and Pin #3 of CN9 == 11.6 ohms
Nov 13, 2012 | Maytag Neptune MAH5500B Front Load Washer
Samsung front loader washer Model: WF306LAW
The "3E" error code indicates that a high current is detected.
A "3E" error in a Samsung washer indicates that there is an issue with the motor. Restarting the cycle may clear the error, but a service technician should be consulted if the error code appears again.
Oct 17, 2012 | Washing Machines
As soon as the machine is on an error message of 3E appears and the machine stops
3E - MOTOR RESTRICTION ERROR
Hall Senior is sensed every 5OOms. 1 second after motor starts to work.
If data of hall sensor is less than 2 (2RPM), the Washing motor will stop at once.
During Washing and Rinsing when a motor restriction is sensed, the motor stops and then proceeds to the next water -flow action. If the motor stops working and this happens in one direction ten times, "3E" Error is displayed.
During dehydrating. when a motor restriction is sensed. the motor stops working and then returns to the initial stage of the dehydration unbalance sensing cycle. After ten times, "3E" Error is displayed, When the motor Is told to stop because of an operating function. no error is shown.
Power 81W OFF can clear the motor restriction error.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 14, 2010 | Samsung WF337AA Front Load Washer
Samsung error code 3E?
Aug 12, 2010 | Samsung WF328AAW Front Load Washer
Cycle stops 3E code appears
Well the error code 3E means that the overcurrent is detected at the moter.
Please check it if you have some overcurrent problem!
Thanks!
mannu_rakesh
Sep 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer 3e fault code
Open the control panel, there you will find a tech sheet that explains how to put the machine into service mode and what to do while in service mode to track this down. Once on service mode, you can cycle through and retrieve all diagnostic codes. You will also find serveral other diagnostic service notes. Read them and follow the instructions to test the motor, motor control, and main control board.
Jan 14, 2008 | Maytag MAH6500 Neptune Front Loading...
Samsung 4.5 Cu Ft VRT White Top Load Washer - WA456DRHDWR Logo
20 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
