Question about Asko D5893XXLHS 24" Built In Dishwasher in Stainless Steel with Towel
Asko d5893 control panel is dead
Will not start
  • Drew Rees
    Drew Rees Jun 06, 2014
    Mine too! :( Did you get yours fixed? If so what was the problem?
Front top panel broken on ASKO model 1375 where can i get a replacement
Parts of that type might be hard to get for this model.
Try this site and select the part based on your dishwasher finish.
http://www.repairclinic.com/Shop-For-Parts/a9b126d610738/Model-1375-Asko-Dishwasher-Parts
Apr 01, 2014 | Asko 1375 Dishwasher
Can't choose just one option like "Rinse & hold" on the control panel.
try this
turn the machine on at the wall select what you want then press the start button
it is possible that you are trying to change the program after it is started and that is causing conflict
Mar 25, 2017 | Asko D1796FI Built-in Dishwasher
My ASko washer machine will not start up, all I hear is a short humm when I press the start button. I took the cover off and noticed the control board has a burned chip on it. There is also a resistor with...
Sounds like the control board is fried. If you have gotten it open here is a link for a new board:
http://www.superiorapplianceparts.com/shop/asko-washer-control-board/?q=/shop/category/washer/asko/
Good luck! And make sure the thing is unplugged before you work on it!
Joseph
Apr 04, 2011 | Asko W6021 Front Load Washer
Our Asko dishwasher will not shut off when we open it. I have tried to hold the start button down to restart but nothing happens...what should I do?
Welcome to fixya. Based on your description and trusting it is indeed an Asko 1796, I'd suspect you have a door switch "accuator" sticking ( control pin as identified by Asko. pin part #80 575 42, switch part # 80 554 73 ). This has been a random occurrence with Asko dishwasher's since they went to this design around 1994 or so. If the dishwasher doesn't stop when you open the door as you stated, here's a possible remedy you can try on your own. Make sure the unit is off first. **Turn the breaker off at your home service panel before attempting any service suggested here on 'fixya"...safety first" This procedure I'm going to suggest can be done easiest and more accurately by removing the control panel for better access as well as to visually inspect other component. It can also be done without removing the panels by identifying the small round "pin" in the the door latch channel ( where the latch goes into the door when closed )...i.e. 94bd9a4.jpg ...with the aid of a small screwdriver, tooth-pick, ear swab etc. add some vasiline or grease to the top of the pin working it in via pushing the pin up & down...I recommend removing the panels though. To do this... Open the door and along the top you'll see "T20" torx head screws. Remove just the screws for the console/control panel, you must also be careful as the edges of these panels are sharp ( auto-mechanics protective gloves are good for this ). Once off you can see the micro-switch and the small "pin" I was referring to earlier much easier. cd7bb1b.jpg Tilt the entire panel towards you slightly, just enough to work with ( careful not to undo any wires, or take pictures as you go ). Apply some grease or silicone lube to the shaft of the pin/accuator and work it in really thoroughly. I find it easier to remove the plastic cover & micro-switch out of it`s bractket to allow a little room to work i.e. e09a335.jpg ...careful not to let the plastic pin fall out. Where I pointed my finger in the image below is where to apply the lubricant. 03cb0a9.jpg Re-attach the control panel and you can test it before itstalling all the screws. Let me know if you require further assistance. Thanks for coming to fixya, please take a moment to rate the help you received. Good luck. Regards, Macmarkus :)
Nov 01, 2010 | Asko D1796FI Built-in Dishwasher
Di9shwasher will not go througt whole cycle
Step1:
Check if there is water on the bottom pan. Remove the panel down on the backside of the machine and look. If it's water there, wipe it well up with a towel or so.
Step2:
If ur dishwasher doesn't starts then first check the usual suspects. Make sure the circuit breaker isn’t tripped and that the wires at dishwasher’s power junction box aren’t burnt. If all that checks out, then go right to the control panel area.
Step3:
Asko dishwashers have problems with the wiring in the control panel area burning or melting– very messy. While your problem may not be as dramatic as that, the problem may still be visible. You may find burnt or discolored wire terminals or the spades on the start button switch may be burnt– anything burnt or discolored has to be replaced.
You can buy any replacement parts you need right here.
Apr 03, 2010 | Asko 24 in. D3120 Dishwasher
Can't get my Asko D3232 to start
Try flipping the breaker off and on. If that does work it maybe the control panel.
Sep 25, 2017 | Asko TouchProof D3232XL Stainless Steel...
Asko Drier T741, Panel powers up, Press start Trips House Circuit
yes time for a full service take to your nearest electrical service place
Feb 22, 2009 | Asko T741 Dryers
Asko Dishwasher Model D1716B Does not fill
Have an Asko 1325 that experienced similar scenario. Removed the unit from the kitchen to the outside to do a thorough exploration. After all a dead machine is a good one to learn on. With the unit electrically disconnected, I explored within the lower guts of the machine. Found some foreign plastic debris within the turbine. Then wigled and removed each electrical connector and reconnected back. There may be corrosion within the contacts. After this procedure I test ran the machine on the outside and it worked.
BTW a common defect with the Asko is the electrical wiring leading up the main door panel, from below the machine. The wires are typically too short and the metal edges of the unit are razor sharp. You guessed it, wires become cut and cause an electrical short at best, or a fire at worst. See the photo for proof by practice. This is why an Asko can be a fiasco. b84ee89.jpg8bbfcfc.jpg
Oct 08, 2008 | Asko 24 in. D3450 Dishwasher
ASKO Washing Machine WM220(ASKO 20605)-Control Panel
IS 2 looks like a MOSFET on my machine
I'm not sure on the Manufacturer - Their logo appears to be a large streaked "I"
The numbers on my mosfet read:-
H542
TOP200YAI (this last digit could also be a 1)
PC0288
Cheers from a fellow busted ASKO consumer.. :(
Mine appears to be motor or motor controller related, so if you don't fix yours, I'd be happy to take a few parts off your hands. ;)
Nov 06, 2007 | Televison & Video
Asko D5893XXLHS 24" Built In Dishwasher in Stainless Steel with Towel Logo
126 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
