Question about Haier HMV1630DBBB Microwave Oven
Won't do anything
0:06 am on the screen touch pad won't do anything
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 78 Answers
Did you try turning it off and on again? (unplugging it and replugging it/plugging it back in)
Posted on Feb 18, 2014
Touch pad doesn't work
Your touch pad is connected to your board with a ribbon wire, it has probably come loose. Unplug the unit and remove the face plate. Pull it back and you will see the wire, it looks like a ribbon, push it in tight, replace the face plate and it should work properly. I see this happen all the time.
Sep 12, 2017 | Maytag Microwave Ovens
My GE Microwave JES1344SK is showing the code -F3- on the digital screen and it beep three times every 30 second, the microwave won't start and any of the fuctions is working I need some help on t
An F3 code means that the touch pad has a short. The touch pad needs to be replaced. If you purchased the microwave new, get your receipt and the unit serial number and contact GE for the repair (1-800-GE-CARES). See http://repair.geappliances.com/ to find a repair center near you. There is a one-year parts and labor warranty on this part. You will need to get the unit to the GE Repair center at your own expense. (I'm assuming that the unit wasn't shorted by a lightning strike or other disaster.)
I hope this helps.
Jan 02, 2012 | GE JES1344SK Microwave Oven
Touch screen is lighted. No response to touch.
The touch pads are a common fault on microwave ovens they go out for a variety of reasons but mostly due to moisture getting inside the pad. These can be replaced pretty reasonable and are not that hard to do. You can google your make and model and find a touch pad or get one from your local parts supplier. Whn you replace it make sure you never use any liquid or spray on the front of the oven, it will slip through the cracks and ruin things. You might also take the unit aprt and look for a fuse, some models have them and others don't. If there is one it will be inside the door next to the touch pad.
Jul 02, 2011 | GE JVM2070 Microwave Oven
Touchpad will not work after boiling water underneath it for 12 minutes without fan humidity cause touch pad to stop working , I have a GE mdv 2040 with green display touch pad
you can change the touchpad to help with this but whenever you have a microwave over a range you are going to have issues with this. you have to make sure you use the vent on high whenever broiling anything to prevent the moisture from getting in the touch pad because all your touchpad consists of is two stickers and some flat wire so moisture can easily getting into it cause it to stop working for a period of time. but changing it is the best thing you can do
Jun 02, 2010 | GE JVM1860 Microwave Oven
What does loc mean on my screen, and how do I fix it
To cancel lock;
Touch and hold the cancel/off pad for 5 seconds and the locked should disappear.
Same to lock.
I can't find anything about the LOC, so maybe the rest of the word is just missing.
Try this and see if it works. You can always post back and ask again
if I am wrong.
Feb 11, 2010 | Magic Chef CMV1000B Microwave Oven
Microwave beeps
HI. the touch pad is defective at this point. you will need to replace this damaged touch pad board asap. this will fix your issue.
Aug 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker XL1400
Key panel (touch pad) shorted.
This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jul 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Dacor Touch Screen is flickering and doesn't respond to touch
You can get that repaired for $39.95 in most cases (details here) or order a control / display unit here.
Mar 31, 2009 | Dacor DMT2420SS Microwave Oven
Haier HMV1630DBBB Microwave Oven Logo
63 people viewed this question
Top Haier Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you a Haier Microwave Oven Expert? Answer questions, earn points and help others
