Question about Vehicle Parts & Accessories
2000 polaris 4 wheel drive goes in and out alot doesnt stay engaged
    Top Expert:
  • 2,044 Answers
If this is a Mechanical Actuator, then you need to find the Actuator Rod and adjust the throw to ensure it stays engaged.
Electrical Motor, you are getting a loose connection that is lacking a signal and then engages when the loose wire is causing the problem.
Posted on Mar 01, 2014
Wont go in 2 wheel drive but switch works light come on dash ?
2004 Sportsman 700 AWD not working..... - Polaris ATV Forum
www.polarisatvforums.com > ... > ATV Repair and Maintenance
Feb 18, 2013 - Go Back · Polaris ATV Forum > Polaris ATV Technical Discussions > ATV ... AWD wont engage. 2. The instrument / speedo works. 3. The AWD switch is ...Polaris ATV Junkie! .... four wheel drive not working polaris sportsman. Won't go into 4 wheel drive
Feb 1, 2013
4 wheel drive not working
Nov 13, 2011
2004 700, 4WD engages by itself
Oct 28, 2011
4wd is stuck on
Dec 3, 2009
More results from www.polarisatvforums.c
Nov 29, 2015 | Polaris 2004 Sportsman 700 Twin
How to test my 4 wheel drive electricals
On my 4 wheeler if I raise the front wheels off the ground and with the 4 wheel drive engaged you should not be able to turn the front tires two revolutions. You need to be more specific as to what you are trying to do because there are other electrical things that can be checked. Like if the 4 wheel drive will not engage. Previous test is only to see if the front end is engaged in 4 wheel drive.
Oct 30, 2014 | Polaris 2009 Sportsman 400 H.O
Why doesn't my 4 wheel drive work
it could be, polaris uses an electronically controlled lock in hub. broken wires or bad switch also.
Apr 06, 2013 | Polaris 2004 Scrambler 500
I have a 2001 Polaris Scrambler. One of the front wheels stays engaged when the machine is switched into 2-wheel drive. Any ideas?
check the wires that come out of the hubs and make sure they did not get snaged on somthing and torn apart
Dec 28, 2010 | Polaris ATV
4 WHEEL DRIVE DOESNT WORK ON A 1996 POLARIS MAGNUM 425 4X4 DOESNT EVEN TRY TO ENGAGE HAS A NEW BATTERY AND VOLTAGE REGULATOR
an ohm test on the hub coil wires will identify whether or not it is a bad magnet. test between the brown and grey wires and thisd should be aruond 27 ohms. then test brown to ground this should be open. you can also test 12volt power to the coil between thos two wires
Feb 18, 2010 | Polaris ATV
The 4-wheel drive will not engage on my 2005 sportsman
jack up again and with it running in park or neutral move switch in and out of 4 wheel and listen 4 the actuator to move if it sounds like its binding or humming or does nothing if binding un bolt from front end possible and check if actuator rod is bent or needs lube alot of times the actuator needs to be cleaned and lubed if their is nothing no sound or movement test actuator if shorted damaged repair or replace as necessary
Jan 25, 2010 | Polaris 800 Twin Sportsman Ride on Toy
4-wheel drive will not engage on my 1997 polaris sportsman 500
check wiring in the pod also check fluid in the front hub
Aug 09, 2009 | Polaris ATV
2002 Polaris Sportsman 700: AWD Not Engaging
ok i have a 335 that had a similiar problem 4 wheel drive would not engage and speedometer acted like it was a tach when started in an idol..... i replaced the battery and believe the condition was caused by low voltage if your battery is is not very good your machine wont generate enough voltage for your 4 wheel drive to engage....try it maybe this will help...
Aug 08, 2009 | Polaris ATV
4 wheel drive goes on and off
you ever change the hub fluid?
Jul 17, 2017 | Polaris ATV
Vehicle Parts & Accessories Logo
27 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
