Hi there. My Techwood tv turned off lastnight suddenly when I was playing my Xbox. So there is no standby light on when its plugged in anymore and there is no sound or anything coming from the tv. I took the fuse out and used it in my Playstation and it worked fine, so the problem is not the fuse. I can't find any real details on this brand of tv so it must not be that popular. It's only a year old aswell so I'm hoping something can be done. Thanks for any help.
SOURCE: 42 inch techwood plasma no picture
the most common cause for this is the capacitor (1uf 630vdc)located at c19 on the main power board.the cost for this component is around 90p
SOURCE: plasma tv techwood 4210
hi the most common fault on this tv is what you describe .i fixed mine by replacing the capacitor (1uf 630vdc) at location c19 on the power board .. cost for this component less than 90p
SOURCE: Techwood 32'' LCD, screen is black, no sound.
the light you see is the backlight, you have either a bad signal board or tcon board which is part of the screen usually.
only cheap solution may be if the capacitors on the power supply, if you want you can do a visual of the power board caps will appear swollen on top and are easy to solder in cost about $1
try reseating the thick cable running to the panel (Tcon board) top center inside the set
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
SOURCE: hi have a techwood tv 32722hd no sound or a
Same problem here, only white noise... have contacted TV repair people and will let you know what the outcome is!
