Question about Samsung YP-K5 MP3 Player
Samsung K5 trouble shooting
Heyy my Samsung K5 won't turn on. It was chargin fine  this mornin, aftger it completed charging I took it off and i tried turning it on but nothing happens. I slide the button hol it and nothing still happens. Then i tried reseting it and nothing happens.
  • 8 more comments
  • crystalwall Nov 07, 2007
    I have the exact same problem... ) :
    I plugged it into the back of my computer, and left it to charge, when I figured it was done, I unplugged, it but it wont go on anymore, Also I noticed my actual speakers for my computer don't work anymore either! lol
    please help!
  • kazekage
    kazekage Nov 17, 2007
    I was charging mys amsung mp3 player and all of a sudden it wont turn on and when i connect it to my pc it says RTC or RCT error what do i do
  • kazekage
    help my samsung S5 wont come on i tried charging it and pressing the reset button and still wont work what do i do?
  • kamaron Nov 22, 2007
    it wont turn on its been charging all night and shows its fully charge, but when i try to turn it on after i disconnect it from the usb cable it wont turn on. ive tried reset my samsung to see if this would work and it still wont turn on
  • Anonymous Dec 04, 2007
    my k5 was fine tis aftrnn..i switched it off as i was out wit frens...when i wanted to on it back..nothing.....how ah?
  • Anonymous Dec 06, 2007
    I had the same problem. My K5 just wouldn't start up in the morning. I pushed the reset button on the underside of the player (between the player and the speakers) and it started right up again with my songs intact.
  • Anonymous Jan 05, 2008
    yeah same - mine won't turn on even with the reset button
  • meatballdood Feb 03, 2008
    mine wont turn on or charge using the outlet adapter thingy. im just wondering if u press the reset button to fix it will it erase all the data?
  • Anonymous Feb 25, 2008
    the same here...when connected to a pc, it's says fully charged...but when i tried to turn it on it doesn't work....nothing happened....worked fine a few seconds before and then i turned it of....wish i hadn't :( it was a gift, so no receipt ;(
  • thorauthor91 Mar 28, 2009
    My samsung K5 says fully charged when plugged into computer. When I try to turn it on, nothing happens. I tried turning iut on with teh speakers open and sometimes i hear a crackling sound. I've read other fix it things and pushed the rest button but nothing changes. No turn on and still occasional crackling from speakers.
When you deinstall the driver for the k5 in the hardware manager and then reconnect the k5 with your pc, he will charge. When he is charged you can turn him on. Sometime he shows that he is fully charged but this doesnt matter he charge and charge and charge... after that you can turn him on the usually way. This must be a MTP driver problem. No better solution found
sorry for my bad english, hope that will work and help a few people.
Posted on Nov 20, 2008
I had a different problem before... mine turned on, but lagged with the "Samsung" logo for more than 5 minutes. Then I pushed the Reset button at the back, and it turned off. When I tried to open it again, it just lagged once more. I then realized that I recently put a playlist I made with Windows Media Player, which turned out to make it NOT work (and probably caused the lag for some reason), so I deleted the playlist, and it wwnt back to normal again. What a relief.
I just shared this for future uses. xD
Posted on Mar 27, 2008
Thank you guys... I was desperate when I found my mp3 player dead, good thing the reset button works... thank you so much. fiuh...
Posted on Nov 07, 2008
Thank you so much! mine worked fine one day and was dead the next. i thought the reset didn't work, but once i plugged it in to charge afterwards it came on fine!
Posted on May 19, 2008
My samsung does this all the time. Randomly it just turns off. But everytime I press the reset button its back to normal. The only thing it resets is the time on the player. It doesnt delete the songs.
Ive had mine for about a year and a half and I pressed the reset button so much that I think I broke it.
Now sadly it got water damaged so the screen doesn't work but the touch buttons do.
Posted on Apr 17, 2008
I had this problem also ( at it all started after a firmware upgrade)..Samsung made a big mistake, but as always, they know nothing.
I let somebody put the firmware on it again (didn't help) and after that I just was toying with it ( take it off the cable, reset, put it on again / reset while charging or connected to PC ) When doing these (useless?) things with it and after being on the cable for a few hours, it suddenly WORKED again.. ( still little errors, for example it sometimes it says fully charged, while still being empty)....
So my advice (If u cannot return it to samsung, as in my case) would be just to mess around with it en hopefully it will work for you also..
Good luck!! ( i hate samsung, but love the K5...)
BTW NEVER BUY THE S5 (succesor) it sucks! only the P2 is cool...
Posted on Mar 31, 2008
Thanks SO much. Mine did the exact same thing- wouldn't turn on and was dead. I try reseting it and it worked! Thanks guys.
Posted on Dec 30, 2007
There a reset button on the back try holding it untill it start up again......
my didnt start up and i try to change it but it didnt do anything then i flip it open and saw the reset button and try it bam it work . sry for my english.
Posted on Nov 08, 2007
I tried resetting it and everything and still nothing any advice?
Posted on Jan 28, 2008
I replaced my battery this week on my 99 Yukon. Truck started fine for several days. Now it won't turn over, at all. All the equipment inside works, so the battery is not dead - it just wont ever try...
Check for power at the small wire at the starter with the key inthe crank position. If there is power than the starter is bad or the connections at the battery are not good. If there is no power put the trans in neutral and check for power again. If there is still no power let me know and I will get you some more info on trouble shooting the ignition switch and the PRNDL switch.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
May 23, 2011 | 1999 GMC Yukon
The mp3 player wont charge. plug into computer and it shows charging but as soon as it is disconnected it shuts off and wont turn on.
Some mp3's don't expressly charge on the computer, that why when you connect it, the computer only sees it as a flash but is not actually charging it all this while and the battery is completely down. So try and get an external charger for it, the battery may be completely dead.Or probably you need to change the battery. Hope that puts a smile on your face.
Feb 04, 2010 | Samsung YP-K5 MP3 Player
Just a question, is there a button that has to be in a certain position while charging? I had a similar problem with my daughters ipod of a different company. I am not sure if this will help or not. I hope it does.
May 26, 2009 | Samsung YP-K5 MP3 Player
Samsung yp-k5 battery
hi i have the same problem i have done everything tried everything
Mar 11, 2009 | Samsung YP-S5JAB MP3 Player
Samsung yp-k5 MP3 not turning on
I reset my mp3..well actually my mum did :)
Nov 07, 2008 | Samsung YP-K5 MP3 Player
Samsung YP-K5 won't work
Get the latest firmware upgrade from Samsung website, or call 1-800-SAMSUNG
Jul 06, 2008 | Samsung YP-K5JAB MP3 Player
Won`t charge
I had the same problem. First disconnect the mp3 player from your computer. Then go into the control panel, select the system icon, go to the device manager tab, and then find the Samsung K5 driver. Right click on it and select uninstall. Now reconnect your mp3 player. That should do the trick. Somehow the driver file got corrupted and wasn't letting the k5 charge.
Jul 02, 2008 | Samsung YP-K5 MP3 Player
Samsung p2 won't turn on
HEYY. okay. mine did the exact same thing but i took a toothpick and pressed the "reset" button on the back of the player. after i hit it once or twice, i tried turning it on and it worked.
Mar 18, 2008 | Samsung Yepp YP-P2 Digital Media Player
Broke
before i had the same problem, when i thought my k5 runs out of battery i plug it in to charge, but it said charge complete and when i unplug it, it still wont turn on. but then i tried switching to a different usb plug on my computer and it worked. so i guess the problem is that some of your usb slot on your computer isnt working properly, try using a different slot.
Jan 20, 2008 | Samsung YP-K5 MP3 Player
Samsung YP-K5 MP3 Player Logo
734 people viewed this question
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
