Question about Husqvarna Lily 540 and 550
Don't ask me how but I have managed to get some thread around the hand wheel and it is stuck. It is the Lily 550 which I love. Is there anyway I can remove the wheel to get at the thread.
The machine is 12 years old and still sews quite well. I am really hoping that I can clear this up myself as I am retired and can't afford to take it into the shop.
    Champion:
  • 276 Answers
If your machine has a free motion knob there should be a small screw visible. This is the knob stop screw, undo this and the knob can be fully unscrewed and then the wheel can be slid off
Posted on Feb 22, 2014
  • 192 Answers
SOURCE: Needle Sticks - Huskystar E10
When it feels like the needle is jammed, open the bobbin cover and release the two black retaining levers, one on either side of the bobbin case. The hook cover that is visible will be released. If the machine turns by hand smoothly, you may have a piece of the broken needle, or just a piece of thread stuck behind the hook or hook cover causing the bind. This problem will sometime make you swear that the needle is stuck in something because it will usually bind while the needle is down in the fabric.
Posted on Apr 08, 2008
  • 22 Answers
SOURCE: thread keeps wrapping around bobbin
frustrating huh?  it happens!  even to us that have been sewing for 50+ years, but the solution is very simple.  Top thread tension is the culprit.  pull the spool all the way off and rethread the top, follow the threading path precisely and make sure the thread goes down into the tension discs.
one more thing - when that happens often times the piece has to be removed from the machine by cutting those annoying loops on the bottom.  if this is the case, make sure you have removed all the thread clippings from in and around the bobbin case.  sometimes one little piece of thread will make you want to use swear words.
good luck and happy stitching.
Posted on Jan 17, 2009
kent581
  • 87 Answers
SOURCE: Viking Lily - free motion quilting - thread loops on underside.
I need more info.
>Where is your presser fooot pressure set(1-9) it should be around 4?
>How fast are you free motioning (faster is better? from 1-10 10 being full speed.
>Is your bobbin threaded correctly (I need to cover the basics.)?
>Never never use a needle smaller than a 90/14 for free motion (I know everyone's an expert...but trust me)
After all this, it's OK to tighten your tension up on top a little when free motioning and getting eyelashes/spider webs on bottom. around 6 should do it though.
Posted on Mar 19, 2009
SOURCE: I have a Husqvarna 5710 Electronic Control sewing
you might check your needle to see if it's bent
try rethreading the machine, some machines do that when the top thread comes off the thread take up lever
make sure the bobbin is wound correctly & inserted in bobbin case correctly
also make sure the bobbin is not warped
Posted on Sep 30, 2010
  • 484 Answers
SOURCE: When piecing a quilt top,
You need to give it a helping hand over the thick seams. There is a gadget called a jean-a-ma-jig which could help.
Or sew up to the seam, leave the needle in the thread, lift the pressure foot, then insert a thick piece of card from behind to make the foot level with the seam, lower the pressure foot then sew.
The idea is to make a level surface instead of a bump to sew over. Improvise any way you can.
Posted on Dec 20, 2010
How to get the hand look quilting stitch on the Lily 540?
Hello Joyce Smith
Please refer to page 45 in the instruction manual which can be downloaded for free at this link
http://manuals.husqvarnaviking.com/
Instead of using invisible nylon, if at all possible use invisible polyester thread. It behaves better and does not break during prolonged stitching. Use a "Quilting" needle size 80/12.
Happy Sewing
Sewingirl/
Oct 19, 2015 | Husqvarna Lily 540 and 550
Hello Joyce Smith
Happy Sewing
Sewingirl/
How to remove top cover of lily 550
Make sure the presser foot is in the up position. This will open up the tension disks. It takes a lot of patience to remove imbedded thread. Use tweezers to grab the thread. Rock the handwheel backwards and forwards to help release the thread. If all that fails, have it cleaned by an authorized Husqvarna Viking dealer. You can find your nearest dealer at the viking website - http://www.huqvarnaviking.com/us
Jul 12, 2014 | Husqvarna Lily 540 and 550
Wound thread around the hand wheel
You should be able to pull the cover of the hand wheel off. Just firmly grab the hand wheel and pull straight back.
Feb 24, 2014 | Husqvarna Lily 540 and 550
Thread around wheel
If it were my machine I would pull the back cover for better access to the rotating shaft and remove the remaining thread. If the thread works its way into the shaft bearings you will have a real mess.
How do I thread the Lily 540 for twin needle sewing?
You need to have the auxiliry spool pin threaded, a twin needle of course, and the threading is the same exept when you go through the tension. You have to make sure you have one thread on each side of the center tension disk. And that's it. Make sure you only sew straight, or small zig zags. Or else you can break a needle.
May 06, 2011 | Husqvarna Lily 540 and 550
When piecing a quilt top, my Husqvarna 550 lily Sewing Machine will not plow through seams or double thick fabric. It gets stuck. Help
Dec 20, 2010 | Husqvarna Lily 540 and 550
Bobbin stuck on winder
Sounds like you need to remove some thread off the bobbin to get the pressure off. Sometimes if you wind too fast or you have a poor quality thread, the thread will stretch as it winds and causes to bobbin to compress onto the winder shaft.
Good Luck!
Jun 15, 2010 | Husqvarna Lily 540 and 550
Husqvarna lily 540
bobbin wound too tight. remove thread first then pull off bobbin.
Jun 02, 2008 | Husqvarna Lily 540 and 550
Sewing Machines Logo
71 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
