Daewoo DWD f1221 keeps getting stuck at the end of the drain cycle
My DWD F1221 keeps getting stuck at the end of every drain cycle where it empties the water from the machine. Whatever programme I am using just sticks at that point and the pump runs continuously until I pause and restart the programme using the button on the front of the machine. The programme will then resume up to the point where it next encounters a drain cycle and the it sticks again until the pause / restart is performed again. Any ideas how to sovle this gratefully received! Thanks :)
3 Suggested Answers
  • 3 Answers
SOURCE: E8 code when washer fills on front loader daewoo
E3 CODE WHAT MEANS
Posted on Apr 09, 2010
Jahn27
  • 1554 Answers
SOURCE: Need a manual for a
Here's the link to the Instruction Manual for your Daewoo DWD-FD1221 Front-Load Washing Machine.
Posted on Nov 12, 2010
My dwd m 12c6 daewoo washing machine will not spin
Blocked drain pump and or drain outlet hose. Check the inside of the pump as well. Daewoo are common to get coins etc stuck in the tub to pump hose and foreign material stuck around the impellor in the pump. If it cant pump out, it wont spin.
Jan 05, 2015 | Daewoo Washing Machines
My Daewoo does not want to spin, any suggestions?
first does all of the water pump out when wash cycle is done? if not then check your drain lines and see if pump is coming on. if it is not then it wont let the washer spin,
Jun 03, 2014 | Daewoo Washing Machines
My front loader fills with water but then does nothing. The drum doesn't turn. Can hear clicking sound from the control panel as though it's moving through the cycle. Checked the belt and is in good c
Does it spin if you turn to spin cycle?
Try this:
Jam lid switch with something plastic or wood.
Put on spin cycle.
Spin the tub by hand.
If the bowl then starts spinning properly, your problem is the motor starting capacitor.
May 21, 2014 | Daewoo Washing Machines
How to clean drain hose
Drain hose very rarely plug up. you can remove the hose and check it but I would bet the relay that opens the drain on the washer is not working correctly. If you have have a bit of tool skills they are relatively easy to replace but check the hose first.
Apr 09, 2014 | Daewoo DWD-WD1353WC 4.5 Cu. Ft Capacity...
WASHER DOOR STUCK
Not all that uncommon on some front loaders. Yes, it is trying to lock and unlock. You can try two different things that might work. 1) Unplug the unit and let it set for 5 minutes and see if it then unlocks itself. Some units have a bi-metal timing that can take from 2-4 min. to release after the spin stops. 2) Wake up unit by pressing start or any button that starts the lock clicking. Have your hands on the door with some gentle pressure because if it unlocks you can pull the door open. Sometimes these things get mixed up and lock, unlock, and lock again. Once you get it open it usually clears up and does not happen very often.
May 17, 2012 | Daewoo DWD-WD3011WW 4.0 cu. ft. Capacity...
Hi i have a 6.5 dwd f1221 and the drum has droped down a bit and is makeing a hell of a sound. Can you help
sounds like it slipped off it's mount, STOP USING IT. take the front cover off the machine, usually there will be 2 or 3 clips, use a flathead screwdriver to lift the clips while pulling the cover forward. Be careful not to damage the enamel. use pry bars or an auto scissorjack with some pieces of 2x4 tolift drum and set back on centre.
Apr 13, 2012 | Daewoo Washing Machines
Daewoo DWCLD1013 washer & dryer The cycle keeps getting stuck on spin at around 10minutes, at which time it keeps going round and round with no actual fast spinning, until it stops about 20 minutes...
The cycle that the machine is stuck in is in fact the empty cycle, just before the spin kicks in. It is staying there because it has a problem evacuating all the water. The machine won't go into spin until all the water is gone and after a set time ( 20 minutes is unusually long, most machines stop after about 10,, but I'm not familiar with Daewoo), the attempt to empty is aborted and the machine stops.
Your problem therefore is either:
The filter for the empty pump is clogged with debris (far and away the most likely) you will need to locate and clean the filter
The EXIT to the drain is blocked, check the empty pipe is not blocked
The empty pump has failed (you would usually expect to hear the pump rumming, but it may not be a noise that you are familiar with).
First and second items are easy to fix, the 3rd is a pump replacement, which isn't that hard, but depends on your level of DIY skill
Jun 23, 2011 | Washing Machines
Daewoo DWD-F1011 PFE error code
I hd zs problem before,no problems in z water outlet,z pump
Nov 16, 2009 | Daewoo Washing Machines
Error code E8
Most likely a control or motor issue. Probably should call service.
Sep 15, 2017 | Daewoo Washing Machines
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
