Question about Panasonic PV-C2061 20 in. TV/VCR Combo
TV/VCR PV-M2023-R or PU-M2023-R 1995
My Tv/VCR &remote wont hold channel programing and must be reset each time the machine is turned on. It will only turn on by inserting a tape in the VCR
If u stick ur bowo in it then it should do the job
Posted on Feb 25, 2008
What is the TV remote controller code for a Panasonic Model # PV-C1320?
Hello
Universal remote codes for Panasonic TV/VCR combo are:-
0374 0381
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Mar 04, 2011 | Panasonic PV-C1320 13 in. TV/VCR Combo
Where can I find a book on the different UVerse Remot tv codes for a new tv?
Hello
Universal remote code for Panasonic TV/VCR/DVD combo is
0437
Direct Code Entry
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Dec 19, 2010 | Panasonic PV-DM2792 Triple Play 27 in....
What is the tv//dvd/vhs remote code for pv-m2799 treple play como unit?
Hello
Four digit universal remote code for tv/vcr/dvd combo is
0437
Direct Code Entry
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand. OK.
Dec 09, 2010 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
I lost my remote control for my tv/vhs panasonic omnivision
how do you access the menu without the remote panasonic omnivision tv vcr combo
Mar 31, 2009 | Panasonic PV-C2010 20 in. TV/VCR Combo
My Panasonic Omnivision TV won't change channels...
just press Stop/Eject Rew/<< buttons (Action) to get setup menu
Sep 01, 2008 | Televison & Video
No remote
The only thing that you are able to program without the remote is the language, channels, and time by pressing and holding the play and FF button for five seconds until the tv turns off, turn it on again and you will get what i just mentioned...
May 21, 2008 | Panasonic PV-C1320 13 in. TV/VCR Combo
Jumbo Universal TV Remote (Sharper Image-Innovage)
sharper image jumbo remote can't get it to program my philips/magnavox tv.
Dec 25, 2007 | One For All URC-9910 LCD Remote Control
Panasonic TV/VCR Remote Problem
Hold down the play/repeat button on the TV itself for 5 seconds. That toggles in and out of demo mode. ;)
Nov 17, 2007 | Panasonic PV-M2048 20 in. Combo
Manual code to program remove for panasonic pv m2023
The remote control for Panosonic model 2023 does not work from a distance. But it works close by
Can you help?
Soundar
Nov 15, 2007 | Panasonic PV-C2061 20 in. TV/VCR Combo
Panasonic pv-v4021 VCR
Actually George, You should read the supplied Operations manual. In that you will find a chapter for using the Remote as a Universal remote, and a list of codes will be give. Check out the code for Misubishi TVs and feed that.
Mar 10, 2007 | Panasonic PV-V4021 S-VHS VCR
Panasonic PV-C2061 20 in. TV/VCR Combo Logo
198 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
