Question about Harman Kardon AVR 40
Shuts on and off
I have a avr40 , I When turning reciever on it will shut back off , I looked at the fuses they don't appear to be blown , I have disconnected all speakers and unit will still tiurn on and then back off, any assistance would be great ,
    New Friend:
  • 30 Answers
It's going into safe mode check resistors after power supply at least two have gone but when you find them replace all four
Posted on Feb 15, 2014
Reciever shuts off after turning the volume up
You will have to change the volume controller and its circuit board.
F150 Accessories
Aug 12, 2012 | Audio Players & Recorders
Evet time i hook my 1200 watt power acoustik and turn it up it cuts off
Usally When something like this occurs its because the amp cant handle the reciever. Meaning the reciever is pushing out more than what the amp can handle. As a safty feature to save you from blowing your amp or speakers the amp will shut it self down to minimum as you described. This also occurs when the amp over heats or doesnt have enough ventalation and once again as a safty feature to save your amp it shuts down. My first suggestion is to turn the "Loud ON" mode off on your reciever. As this feature can blow your speakers and can also cause this problem. Also do not use any factory settings on your reciever. It is almost always the bass in any given system that causes this so turn the bass down some on your reciever or on your amp turn it down and then adjust up and down from the reciever. Im sure you probably like the bump bump bump, I do to but your going to have to eiather buy an amp that can handle what your reciever is pushing, or turn it down a bit. You should also check the fuses for not only your amp but for the system under the hood near the battery. My own personal experience I have blown fuses when the system shuts down. Hope this helps
Oct 24, 2011 | Car Audio & Video
I turn My nintendo DS lite on and it shuts off instantly.
This sounds like the fuses on the logicboard have blown, you will have to take the back cover off to to have a look at the logicboard, the fuses are very small, you will need good soldering skills to replace them. here is a diagram of the logicboard and where the fuses are situated, they are marked F1 and F2:f898906.gif
Could you post back and tell me if the screens come on at all, if they do it might be your battery.
Feb 02, 2010 | Nintendo DS Lite
HTR-5280 Receiver Fuse Blown
the fuse rating should be printed at the back near the fuse holder itself. If it opens the fuse again and again probably you have a circuit loading problem in the receiver...either one of the amps is failing.
Aug 10, 2009 | Yamaha HTR-5280 Receiver
System shuts off when the volume is moderate to high, now the system shut off and will not turn back on.
unplug the reciever for at least 15 minutes. then replug in all of your speakers making sure there is no bare wire showing. if the reciever doesnt ower on replace the fuse inside(make sure unplugged from wall)
May 17, 2009 | Yamaha RX-V661 Receiver
Power will not stay on
Activated protection circuitry means that the amplifier is seeing conditions it does not like and is shutting down the power to prevent further damage.
Either you have a short in your speaker wires, in your speakers, or a blown amplifier.
Disconnect both speakers and turn on the amplifier. Does it still give the error message? If it does, your amp is blown. If it does not, carefully inspect your speaker wires and their connection. Make sure all looks good and reconnect the speakers and try it again. Still get the error message? You likely have a problem in your speaker cabinet(s).
Apr 21, 2009 | Onkyo HTR500 Receiver
Tv shuts off but power light continues to flash
Unit is telling you something is wrong with circuit. LED pilot flashes when malfunction is detected. Power supply shuts unit down to prevent further damage and/or fire. Leave off and seek pro/tech check out
Nov 30, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Kenmore dryer error
Based on my brief internet research on this issue, after recieving the same error code, it appears to result from a communication issue between the electronic systems of the machine. Personally, I'm returning mine. Too many posts about this error.
Jun 30, 2007 | Kenmore Elite HE4 Electric Dryer
95 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
