Question about Dell Computers & Internet
Dell inspiron 526 desktop won't turn on. green light is onin the back so it is getting power.
Already tried replacing the power switch indicator assembly.
    Novelist:
  • 187 Answers
The light in the back could be the communications board getting power from the motherb but a number of causes are possible. boot files damaged, graphics card failed, all kinds of possibles. give more detail like from when you last used it up till you tried to turn it on? sounds, any other parts not working? sorry but just to many possibilities
Posted on Apr 21, 2014
SOURCE: no power to my dell dimension 4550
It might be a couple of things bad powersupply or power button incorrect ram module or hard drive settings ,if not then lastly have a bad motherboard which we all hate. you said you have a a green light on motherboard? Did you upgrade or install any new ram ,harddrives etc check make sure they are seated properly in their sockets and free from dust check connection on the ram module make sure it shinny brass color if not you can use an eraser to clean them. If you have upgraded check make sure the ram is compatible to your machine sometimes the wrong ram install can cause no power up problem. Do you have four green lights in the back of machine? Dell new desktop has 4 green light in back of the unit . if all four light are green then system is ok but one out of the four light are orange then you have a problem. You can go onto dell web sight for your machine to check out these lights codes. I hope this help you out some.
Posted on Feb 12, 2008
  • 79 Answers
SOURCE: my dell desktop is just making a ticking noise and won't turn on
So the computer will not post! Try these steps.
So basically you cannot get the pc to POST. Meaning you have just a black screen when you power on the pc, right?
First off, did you attempt to update BIOS before this happened. 90% of the time this is caused by a corrupt bios.
If you did not try to update BIOS before the problem started then try these troubleshooting steps.
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button.
Try to boot the pc.
2. Open the case and reseat the graphics card, hard drive, and RAM.
3. Take out one of the RAM sticks if there is 2 or more. Swap the RAM sticks in different RAM slots.
4. Set the Cmos jumper to clear. Power up the pc. Power down the PC. Set the Cmos jumper back to normal position, power up the PC.
5. Unplug and replug all the power supply cables.
6. Check the powersupply function. Either by a powersupply voltage checker, put the powersupply in a different pc, or try a different powersupply in the problem computer.
That covers almost everything,,
If still nothing then possibly bad Motherboard or CPU.
Brian
Posted on Jul 06, 2009
gewiz
  • 1271 Answers
SOURCE: Dell Inspiron 530. No power - replaced Power
hi,
Sadly that sounds like a dead motherboard.
Regards
Gewiz
Posted on Dec 05, 2009
Testimonial: "Very quick response, greatly appreciated. "
  • 1040 Answers
SOURCE: Dell inspiron 518 won't power
Hi..
Check out the RAM, whether it works properly or not...
Hope this has helped you.. Thanks...
Posted on Sep 15, 2010
SOURCE: Dell inspiron 518 will not turn on when power
I am having the same issue, did you resolve yours?
Posted on Dec 05, 2010
When i turn on my Dell Inspiron 2400 Desktop Computer why won`t it start.
Is the computer plugged in to a known good power source with a known good power cord? Also, make sure the power is fully seated on both ends. When you press the power button are you getting any indicator lights? The power button itself has an LED that will be either solid green, blinking green, solid amber, blinking amber, or off. Do you hear any beeps?
May 19, 2014 | Dell Inspiron 530s Desktop Computer...
Have dell Inspiron 546 minitower. Been acting up lately where it won't power up. The LED light on PSU below voltage switch is green. Light on MB is orange. No power or indication at all on front...
PSU's put out several different voltages if the 12Vs isn't working it won't power the motherboard. Some outputs may still be functioning therefore you may see some lights on and even some fans running. Replace the PSU.
Jun 29, 2013 | Computers & Internet
Dell Inspiron 1100 won't turn on
unplug, take out battery then hold power button for 30 seconds then plug back in and turn on
if the3 laptap gos on without the battery you need a new battery
Jun 14, 2013 | Dell Inspiron 1100 Notebook
Dell Inspiron Desktop 546MT, green light on the back, but no light on the front
Could be a faulty switch, switch wire connector loose from the motherboard, faulty power supply.
Jan 29, 2012 | Dell Inspiron 546 MT Desktop Computer
Will not turn on when power button is Dell Inspiron 518 will not turn on when power button is pressed. Green LED on back of powersupply lights and orange LED on motherboard turns on. No fan operation on...
Green LED on back of power supply indicates it's getting power. That does not mean that it's distributing the power voltages to the computer. You could have a bad power supply or a bad motherboard. Just to make surethat nothing else is causing the problem, remove any PCI cards like modem,video card, sound card, etc... Remove the memory modules and disconnect cablesto CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 13, 2011 | Dell Inspiron 518 Desktop Computer
Press power button. Green light turns on, fan
there is power buttom on the keyboard makes it wake up. try it
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Oct 02, 2009 | Dell Inspiron 530s Desktop Computer...
Computers & Internet Logo
29 people viewed this question
Alun Cox
