Question about Lincoln Welding Tools
How to remove the gas line from inside a invertec v205-t
I changed my fuel line on my bolens push lawn mower and now theres no gas in the line. I tried priming it.
I would remove the fuel tank and clogged line . Then drain the gas out of the tank. You probably need to clean out the fuel tank. Use clean gas that you KNOW is clean to flush it. When you pour the old gas out of the tank, install a coffee filter inside a funnel on the can you pour it in. It will show ALL the debris inside the tank. If you are sure gas line is good , you may have an airlock (I have seen it) in the line prohibiting fuel from flowing all the way to the carb, but this usually only happens with the installation of an online fuel filterl There is a small screen INSIDE the mower's fuel tank above the outlet that may be clogged. That is why I recommend flushing it. Any gas filtered by the coffee maker should be clean enough to reuse.
Sep 07, 2011 | Garden
Hi I have got a gilera runner 125. 4stroke and the petrol won't go to the carb don't no wot it could be it has been sitting for a year or so tho. Any ideas peeps
The float or float needle in the carb bowl is probably stuck closed. Just remove the float bowl and clean the inside of the carb. Pay special attention to the float pin. Before putting the bowl back on, check to see that the gas flows when the float is lowered and shuts off when the float is raised. If the gas still will not flow when the float is lowered, remove the fuel line. If gas runs out of the line then the float needle is still stuck or trash is blocking the fuel flow prior to the needle. If no gas comes from the fuel line, the gas valve or gas tank fuel valve filter ( usually inside the gas tank ), is probably plugged up with rust or trash. Remove the valve and clean out the trash. Please rate my answer. Thanks. tombones49_168.gif tombones49_170.gif
Jun 11, 2011 | 2007 Gilera Runner SC 125
Where is the gas filter
The gas filter is inside the gas tank. If you're wanting to change the filter, first remove all gas from the tank.
Next, remove cover and probably the air filter so you can see the fuel lines.
Use a needle nose pliers to grab the filter through the tank opening.
Some chain saws have 2 lines coming from the tank. Give a little tug on the gas filter to see which line it is attached to inside.
You will have to remove the line at the other end where it attaches to the pump or crankcase.
Pull the filter and line up and out of the tank. Put on a new filter and pull the line back to the nipple it was attached to.
Push down on the filter to seat it in the opening.
Depending on the make and model of your chainsaw, some have washers under the filter that seat against the inside of the fuel tank. Be sure to press this kind to seat it.
Hope this helps. If it does. I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
May 12, 2011 | Garden
Reinstall Gas Tank on 32CC Weed Wacker
The something loose in the gas tank is the weight that goes on the gas line to keep it at the 'bottom' regardless of the machine orientation.
Apr 19, 2010 | Garden
How do you replace a burner on a ducane gas grill
Hello : Here are two solutions , just look which one of them is the most helpful .
  1. Turn off the gas supply and bleed the lines leading to the grill. Remove the gas tank if possible.
  2. Open the grill and remove the grates. In some cases you will need to
    detach the hoses from under the grill using simple hand tools. Other grills may have simple "float in" style of burner. These styles look as if the tubes from the burner leading to the gas supply lines simply "float" into each other. Look for clamps of holders that may need to be removed.
  3. Remove the damaged burner and remove from grill. Take a moment to inspect the other burners and any other hoses in case you need to replace more than one piece. Place the burner in a plastic bag and take it to the home store so you can get the exact parts you need. This removes all guess work.
  4. Before replacing the burner/burners etc, take a moment to clean any material, grease etc from the bottom of the grill. Replace the burners and hoses as needed. Check the connections before reconnecting the gas supply. Turn the gas on and start to flow of gas to the burners without lighting the grill. Make sure the flow is working. Be sure to turn the gas off, let the fuel dissipate before lighting.
  5. With everything working, fire up the grill and enjoy.
Or try these help here :
  1. Turn off the gas supply valve on the tank. Remove the fuel line from the fuel tank by turning the connection nut counter-clockwise with your hand.
  2. Open the Char-Broil gas grill and remove the main cooking grate. You do not need to remove the upper warming racks to change the burners.
  3. Remove the lava rocks from the grill and pull the rock grate out. Unhook the flame spreader from each end where the spreader attaches to the inside body of the grill. The spreader is the angled piece that sits over the burner.
  4. Locate the cotter pin that secures the front of the burner to the grill body. Remove the cotter pin with a pair of needle nose pliers. Lift the burner up and pull the burner venturi tubes out of the gas valve.
  5. Set the new burner inside the grill with the venturi tubes inside the gas valve opening. Install the cotter pin to secure the burner to the grill body. Place the flame spreader back inside the grill and hook the ends to the grill body.
  6. Place the rock grate, lava rocks and cooking grate back inside the grill. Reattach the fuel line to the fuel tank.
Here you need Needle nose pliers.
Please report me which one helped the most .
good luck .
and rate if useful please !
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Feb 20, 2010 | Ducane 30400040 Stainless Steel Grill
Some one played a bad joke on me they put antifrezee in my gas tank and what to do to get out
Take to a garage and you will soon find out that "bad joke" is the wrong name for this. All gas must be removed and gas tank dropped and cleaned. you can only hope that that will fix it. Fuel pump, line and injectors may also need attention.
Nov 15, 2009 | 1996 Ford Taurus
How do you change the gas filter on a 2006 volvo s40
remove gas cap to release pressure. Then buy the cheap plastic removal tool that slips on the line and inside the filter to remove it from the fuel lines.
Jul 29, 2009 | 2006 Volvo S40
Termal overtemp LED light on, welder not working, not overheated
interconnecting ribbon cable between circuit boards was not properly seated in receptacle
Mar 30, 2009 | Lincoln Welding Tools
Stihl chainsaw
Hi
First remove the cover,air filter and the carburator.Then remove the gas tank cap and the fuel filter from inside of gas tank,at the end of fuel line.Take off the fuel line from the hole of the gas tank(at the top),replace the fuel line,put all back together and start the engine.
best regards savumihai71
Feb 13, 2009 | Husqvarna Chain Saw 20" Bar
Welding Tools Logo
44 people viewed this question
Top Lincoln Welding Tools Experts
joe2639
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
