Question about Razzi 2011 Chevy HHR ABS Plastic Side Skirts 187-200-3 Razzi
HHR tailgate interior panel - Razzi 2011 Chevy HHR ABS Plastic Side Skirts 187-200-3 Razzi
    Top Expert:
  • 51,482 Answers
Yep it has one
Posted on Sep 26, 2016
Rear hatch on my 2001 explorer will not open, rear window will but tailgate hatch will not. how do i open it with out the unlock button, no manual release that i can see...
I had a clip break when I tried to open my tailgate. I had to remove my inside hatch panel and find my way to the handle assembly. A little plastic clip (shaped like a T) had finally worn out, which wouldn't hold the locking arms, and I had to go to a Ford dealership for a $3 part; tailgate has worked fine since then!
Sep 01, 2011 | 2001 Ford Explorer Sport
The rear tailgate windshield washer tubing is loose in the tailgate so when the sprayer button is pressed fluid is squarted inside the tailgate. How do you repair this? I think the interior panel on the...
if you don't find any screws then it is held in place by push pins. Make sure you check for cover caps near any interior release handles. These push pins are plastic and typically are spaced 8 to 10 inches apart all the way around the outer edge. You have to pry these up carefully and make sure they come our of the metal and not out of the panel itself. They are replaceable and available at Auto Zone and Advance Auto in the generic section.
Apr 30, 2011 | 2007 Chevrolet TrailBlazer SS
Where is the fuse for the rear hatch on a 1993 chevrolet blazer? My rear hatch will not open at all. I can hear it ttrying to unlatch the rear windoiw but nothing happens.
If you can hear it then you don't have a fuze problem. More than likely it can be fixed by adjusting the catch in the tailgate. Open you hatch with the key and lower the tailgate. Remove the tailgate interior panel/cover and you'll see the catch for the window. Adjust the catch a little, tighten it up, raise the tailgate and close the hatch. Try your release on the dash again and see if this fixes the problem. You may have to repeat this a couple of times until you get it adjusted to where it needs to be. If this works, then reinstall the tailgate interior panel and you're all done.
Feb 17, 2011 | 1993 Chevrolet S-10 Blazer
How to remove interior panel from tailgate?
Remove the liftgate pull handle. Refer to Liftgate Inside Pull Handle Replacement .
DO NOT attempt to remove the liftgate trim panel if there is a failure of the electric latch. Refer to Opening the Liftgate Without Electrical Power .
Liftgate Trim Finish Panel
Liftgate Trim Finish Retainer Clips (Qty: 2)
Liftgate Lower Trim Finish Panel
Liftgate Trim Finish Retainer Clips (Qty: 14)
Nov 22, 2010 | 2009 Chevrolet HHR
Tailgate won't open, broken latch. how to fix? 2000 Ford Explorer sport.
If you can find a used one it is much cheaper (obviously).You need to pull off the tailgate interior panel covering.Also you may not.There may be access to it from underneath.I have pulled apart windows,doors but have never had a truck or SUV.There may be some screws holding down the interior cover in a few spots.If you have to pull apart the interior panel,look for screws that may be capped with those little plastic covers,they like to hide the screws for appearance.Then you will have to gently pry at the seams between the cover and the tailgate.There are usually little pop in pins holding it on.Please do it carefully because they can break.Once you get past the interior cover,there should be access to the latch.It's usually only held on by a couple of medium size bolts,maybe 10mm-12mm.(Everything seems metric these days anyhow).Good luck and let me know if you need further help or have any questions.
Jul 30, 2010 | 2001 Ford Explorer Sport
Where is the battery located on a 2006 chevy hhr
NO it is NOT under the hood or the fender IT IS in the back under the plastic cover that covers the spare tire. Open your tailgate, lift the cover that hides your spare tire. The battery is between the spare tire and the back bumper. If the battery is dead you can not open the tailgate, You need to open the side door and climb into the back. Who ever thought about putting the battery back there and having an electric tailgate is a nut! Good work GM
Jan 02, 2010 | 2006 Chevrolet HHR
Tailgate won't open
jg-demedina- 2 solutions 1. remove all screws including 2 screws mounting interior pull handle, then remove the interior panel by steadily pulling away the panel. You will hear the panel clips popping as you pull away the panel. Some of the clips will break...but not to worry...50 cents a clip at the Chrysler dealer. This panel comes away from the interior of the door just like every other panel does on every other car! 2. Do not take the advice of this person you are calling a mechanic.
May 09, 2009 | 1999 Jeep Cherokee
1996 Isuzu Rodeo stuck tail gate
Remove the interior trim panel which will not be easy since the gate is up ---- you can then access the lock mechanism and will probably find a bent linkage rod or a broken plastic retainer clip.
Apr 22, 2009 | 1996 Isuzu Rodeo
2003 Ford Explorer back door latch will not open
Mine just did the exact same thing. The latch may be moving freely because it is not hooked to the latching mechanism anymore. In my case, the handle had broken where the handle hooks to the rod that operates the mechanism. Go to the Ford dealer and buy a new handle. Here in S.C. it was $24. You can't get this at the parts houses. Start by removing the plastic "Ford" cover that is over the liscense plate lights. You then have to remove the aluminum rivets that hold the handle to the tailgate from the outside and remove the broken latch. Remove the pull handle loop on the interior side of the tailgate (2 screws), unsnap the inside plastic tailgate interior panel, and pull down the black plastic sheeting that is underneath the panel to make access to the mechanism inside of the tailgate. There is also a hard plastic cover that you will see that needs to be pulled loose to open another access hole. Install the new tailgate latch handle by sliding back into the mounting holes and attach with two 10-32 screws and nuts. The new handle will come with a new yellow rod attachment piece on the handle. You will see inside of the tailgate a small rod hanging down, most likeky it will have the same rod attachment piece as the one on the new handle. Note the position of the yellow piece on the rod, as you will connect the new piece in the same place. Once the rod is hooked up, relubricate the metal mechanism with a light machine oil, replace the black plastic cover, replace the black plastic sheeting, (secure with a small amount of duct tape), replace the tailgate interior panel, replace the pull handle loop, shut tailgate, replace "Ford" cover over lights, and you're done!
Mar 23, 2009 | 2003 Ford Explorer Sport
Chevrolet HHR fusils
The interior fuse box is on the passenger side of the center console. There is a panel that just pulls off. There is also a panel nder the hood for engine, PCM and relays. Also, you may want to check the under hood fuses and relays, it has been reported that these come unseated, causing many electrical problems.
Dec 23, 2008 | 2006 Chevrolet HHR
Razzi 2011 Chevy HHR ABS Plastic Side Skirts 187-200-3 Razzi Logo
22 people viewed this question
Top Razzi Home Experts
john h
Tom Chichester
Are you a Razzi Home Expert? Answer questions, earn points and help others
