Question about Greenworks 1500 PSI 1.3 GPM Electric Pressure Washer 51142
Remove cover Want to remove green cover what is the trick to it.
    New Friend:
  • 4 Answers
What make and model is it. Normally you would see torx heads that need removing.
Posted on Feb 16, 2014
  • Tim Casey
    Tim Casey Feb 17, 2014
    Screws are reg Phillips, I found screws near wheels so I was able to remove the cover with ease.
How to remove back cover of viewsonic VT2430
Download the service manual from here:
http://elektrotanya.com/viewsonic_vt2430-1m_vs12335-1m.pdf/download.html
Apr 28, 2015 | ViewSonic VT2430 24"" LCD TV"
How do remove the oven bulb cover in a maytag precision touch control 800?
the trick is to push the metal ring IN at the same time as turning the bulb cover counter clockwise
Feb 01, 2013 | Ovens
IS THERE A TRICK TO INSTALLING THE PCU ON THE CL3500N? IT SEEMS AS THOUGH IT SHOULD BE A SIMPLE PROCESS HOWEVER IT IS NOT LOCKING INTO PLACE. THANK YOU
Photo Conductor Unit Color
A Turn off the power, and then unplug the power cable.
B Open the right cover.
C Pull out the green levers on the left and right that are securing the inner
cover.Replacing
D Lift the inner cover until it stays up.
E Remove the photo conductor unit.
F Pinch the
green lever to unlock the unit.
G Pull out the photo conductor unit carefully.
H Pinch the green lever to unlock the unit.
I Pull out the photo conductor unit carefully until it stops.
J Pinch the green part to release the unit
.K Pull out the photo conductor unit carefully. Be sure to hold the unit with both hands, and pull it out carefully.
L Take out the new photo conductor unit.
M Remove the cap attached to the photo conductor unit. The cap is no longer needed and can be disposed of.
N Remove the tape from around Photo Conductor Unit by peeling it down-ward, and then remove the unit
Mar 11, 2011 | Ricoh Aficio CL3500N Laser Printer
How do I remove protective cover over inside trunk light to replace bulb ? Does it just snap off and is there a trick to removing cover ?i
Removal and Installation
  1. Remove the pin-type retainer.use a pair of needle nose pliers to get behind and remove
  2. Position aside the luggage compartment side trim panel.
  3. Remove both rear lamp assembly nuts.
  4. Disconnect the electrical connectors.
  5. Remove the rear lamp assembly.
  6. To install, reverse the removal procedure.
Dec 26, 2010 | 2005 Ford Thunderbird
89 buick park ave has no fuel does this car have a fuel pump relay?
Yes it does,on the firewall there is a long cover starting on the right side to the middle of the car,it has three turn type retainers,remove this cover,and there are a row of relays all the same part number,just swap them around to see if it does the trick.Fuel pump,fan relays,ac clutch relays,I can not tell you exactley witch one it is,on line.There are a couple with green wires it is one of them.
Apr 11, 2010 | 1989 Buick Park Avenue
How do I fix the burned out light in the refer?
remove the light cover first. depens on the serial number of the unit new subz. the cover is really simple to remove. oldr subz a remove big cover litltle trick
Mar 14, 2010 | Sub-Zero 690 Side by Side Refrigerator
How do you reach the switches.
there is no trick just remove the cover under steering and use right size wrench and remove
Aug 06, 2009 | 2004 Nissan Frontier
Should be simple pass. side headlight bulb replacement.
JUST REMOVE THE AIR BOX INTAKE TUBE . THE BULB REMOVES FROM THE BACK OF THE LIGHT ASSY. .
Mar 14, 2009 | 2001 Dodge Dakota
Destorted picture on my tv
the fl231 problem requires a soldering iron. to remove it from the circit board. I would not recomend this for someone who has never soldered before. and consult the fl231 problem under the tips and tricks section
Dec 26, 2008 | RCA HD52W59 HDTV Projection Television
Greenworks 1500 PSI 1.3 GPM Electric Pressure Washer 51142 Logo
225 people viewed this question
Top Greenworks Garden Experts
richie46
Josh Van Nostrand
Steve
Steve
Are you a Greenworks Garden Expert? Answer questions, earn points and help others
