How to reset my tv remote RL57S RL-57S
Tv model LC32SB25E the remote wont work with the tv the tv signal light flashes when i push a button on the remote but nothing happens
SOURCE: Power light on but no picture
I've got the same problem. No sound, no picture, just a green light. The light comes on when its plugged back in. No buttons work. Occasionally the light flashes off.
Posted on May 30, 2008
  • 257 Answers
SOURCE: wont turn on
The power supply board has been defected. Replace it with a new one.
Posted on Aug 18, 2009
SOURCE: Panasonic remote and volume/channel buttons do not work
My son put a penny in the SD card slot of my Pansonic flat screen tv. I finally got the penny out but now the volume and tv controls do not work. I can change the channels through my cable box but that is it. The volume does not work on my cable remote or the flatscreen. What do you suggest I do to fix this problem?? Thanks, Josh
Posted on Aug 23, 2009
tvtek
  • 1284 Answers
SOURCE: SSP-R4232 Plasma TV, blue light on, but tv wont turn on.
At this point it appears that your main board is probably bad. You most likely have a 5 volt scource going to the main board but its not powering up the set. The main board is part number BN94-00796A.
You might want to have a technician look at the TV to verify this as the issue before purchasing it. Please take a few moments to rate my answer. Thank you.
Posted on Nov 18, 2009
Testimonial: "I was extremely grateful to have a response in such a short amount of time, as soon as I replace the part that was suggested as bad to me, Ill post."
djchillsnyc
  • 152 Answers
SOURCE: tv wont turn on. power button blinks
if your tv is blinking you are still okay but your set needs service, maybe some board or circut is defective. this happens with panasonics, they have a blink timer. they blink a certain number of times. this blinking feature is called safety mode, you find the part that is fualty according to the number of blinks, you can find out what fualty part is cuasing the tv not to go on by downloading a service manual in pdf format or finding the blink codes, how many times does it blink count it carefully i may have a manual here and maybe can tell you what to replace.
Posted on Jun 03, 2010
Why won't my samsung smart tv emote wont change chanel
It needs to be Re-Paired to the TV.
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
  1. TV off
Within 3 feet of TV
PAIRING and RESET buttons:
Please rate if Helpful.
Good Luck !!
May 25, 2014 | Samsung TV Remote Control
Mitsubishi wd 65734
make sure the slide switch on the remote is in the TV position.
you can check to see if the remote is putting out a signal by using the camera in your wireless phone. While viewing camera point remote in to camera lens and push button on remote, you should see flashing light on camera display.
you could try resetting remote,
(1) Set the slide switch to TV position.
(2) Press and hold the POWER button
(2) until it flashes twice then release
(2) the button.
(3) Enter the code 0 0 9 3 5.
If remote still doesn't work you will need repair shop to look at it again, it's possible there is a plug inside that is not connected.
Mar 15, 2014 | Televison & Video
My tv wont work with the remote i can turn on by hand but remote wont do anything it has new batterys and the red light goes on
TV brand?
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera's Lens (Digital Camera can detect IR), you should see flashing light on the camera's screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
www.remotes.com
LG:
1) Test the remote:
2) If the remote checked out OK, then look at the back of the TV for the "REMOTE INPUT", use a mini-phone plug and insert the plug into the remote input jack in and out a couple times to clean the switch contacts that select between the front IR receiver of the TV or the rear panel IR input jacks.
Oct 30, 2011 | Televison & Video
Hi I have a vizio tv control with the key board and it all just stopped working so I thought it was the batteries changed them still not working ????? Help Please
Test ur tv remote control first see,if it is working,malfuctions or completely dead?U have a Digital Camer wright?Yes.Digital Camera can read Infer Red signal Output by the tv remote.Yes?Turn the Digital Camera on and take the tv remote point it at the Digital camer and pushes all the remote buttons the Infer Red signal will read all buttons Infer Red signal flashes u can see on Digital Camer viewing screen.Pushes all remote buttons see flashes of white lights.Mean the tv remote control it it good or not.Take some cottons ball soak it with some rubbing alchachol clean the tv Infered Red sensor on the tv frame near the power LED incation light.Might be dirty,Still not reading the Infer Red signal.If 100% it is the tv remote control is the cause,it CPU is dead.Try website like Remotes.com to buy another the tv original remote.
Jul 29, 2011 | Vizio VO47L 47 in. LCD TV
Thought remote was broke, so bought a new one, still cannot use remote for tv & it is the remote for this model
What is the make and model number of this TV? LG TV?
www.remotes.com
LG:
1) Test the remote:
Jun 03, 2011 | Televison & Video
The power light is blinking and the tv wont turn on
I have two 46" Sharp Aquos tvs,so i know this tv model well.Tv have Power and OPC LED lights flashes?Yes.Tries tv unplug,replug it back like about an hour later.The tv should be working again.This problems happen to Sharp tv alots,later on,should it happen again,just tries push the power switch on the remote again and wait the backlight will light up and tv will work again,some it will go back to Power and OPC LED lights flashes again,just push power switch again and wait,sometimes,u have to do this three or four tines to make the tv Tuner signal board to take to make the tv to work again.If u have to pushes power switches 10 or 11 times and wait and Power and OPC LED flashes lights again,it time to replace the tv Tuner signal board,that the board,where that take the tv incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Jan 29, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
MY Sharp LC46D62U wont turn on
Power and OPC LED lights flashes?Common on Sharp LCD tv.Tv is still useable.Tv have Tuner signal board problems.Every times Power and OPC LED lights flashes.Just push the remote power button again and wait.Sometimes Power and OPC LED light will flashes require push power again wait again Power and OPC will flashes two or three time push power button and wait.Must do this two or three time before the backlight will light up and tv work.
Jan 07, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Bush tv, buttons on tv work but remote dosnt, even though light on tv flashes
bush tv button wont work tv flashes when buttons are pushed but does nothing
Nov 17, 2010 | Televison & Video
My remote stopped working on my tv how do i fix it
www.remotes.com
Oct 29, 2010 | Proscan 26LB30QD 26 in. LCD HDTV
Timer light is flashing but tv wont turn on!
When the timer light stoped flashing the remote control would not turn on the TV. The next time the light quit flashing I held the power button in on the TV for about 5 seconds and it came on and has had no problems since then with the remote or the local TV power button.
Greg Allen
Aug 29, 2008 | Mitsubishi Televison & Video
Televison & Video Logo
Top Televison & Video Experts
