Question about KitchenAid KUDS30IXBL Builtin Dishwasher
Kitchenaid KUDS30IXBL will not finish cycle - KitchenAid KUDS30IXBL Builtin Dishwasher
When I press buttons to start dishwasher nothing happens
could be the door switch has failed and not seeing dor is closed properly torun .
Jul 03, 2016 | KitchenAid Superba Series 24" Built-In...
My dishwasher would not dream now the panel lights do not come on
washers that don't m/t out first id have a look at the food particle filter too see how dirty it is , next id have a look at the pump impeller under the bottom spraybar too see how worn down it is
Sep 03, 2015 | KitchenAid KUDS30IXBL Builtin Dishwasher
Our cancel/drain light is on and will not go off (Even tried turning off and on the circuit breaker) We cannot get any other buttons to work with the light constantly on.
Called a stuck key on the keypad under the door the is panel behind this panel should be service sheet if this is a newer model should show procedure to test for a stuck key
Apr 06, 2015 | KitchenAid KUDS30IXBL Builtin Dishwasher
My model KUDS30IXBL will wash and clean the dishes, but then stops and all lights are off. It doesn't complete the heated drying process and the light doesn't come on that the cycle is completed, just...
I would guess it "thinks" it has finished drying because the temperature is high enough. Could be a sensor or control problem. What happens if you switch to air dry? That may be a temporary solution.
Mar 04, 2015 | KitchenAid Dishwashers
WHERE IS THE FUSE ON THE POWER SUPPLY
There is a thermal fuse on the main control board. Turn off power. Remove screws securing the console. On this model you may have to remove the door panel also. Install thermal fuse kit, W10402110. Follow the instructions in the kit. If you don't replace the wires along with the fuse, it will fail.
Aug 04, 2014 | KitchenAid KUDS30IXBL Builtin Dishwasher
KinchenAide dishwasher blanket
where is this insulator being used?
top over the body of the dishwasher?
in the bottom?
what is your model number
Apr 18, 2014 | KitchenAid KUDS30IXBL Builtin Dishwasher
Kitchenaid dishwasher KUDS30IXBL door locked open, will not close
There should be a type of hook inside the hole where the door latches to the machine. Hold the handle up and rotate the hook latch so the open side is pointing towards the machine. The click you heard was the latch that holds the door closed moving to the closed position when the door was open, and it needs to be in the release position.
Jan 28, 2013 | KitchenAid KUDS30IXBL Builtin Dishwasher
My kitchenAid clothes washer won't always agitate but the timer will finish the cycle
Possible that the timer is not switching the circuit to the designed cycles and so it does not go to the spin mode. It can be due to loss in mechanical contact due to worn out points or dirt accumulation. Use a cleaner, WD40 , could be good to try on the timer before you can estimate the cost of a timer.
Jan 20, 2013 | Washing Machines
Less that 2 yrs old..door wont latch. As a consequence machine won't start.
It is possible the door latch is faulty or the springs at base of dishwasher are soft and need adjusting. the springs keep the door in position. refer this site for parts.
Dec 31, 2012 | KitchenAid KUDS30IXBL Builtin Dishwasher
Motor does not stop running
problem may be final rinse cycle not happening.
1)check the boiler heater problem.(thermostat trip)
Jan 07, 2010 | KitchenAid Dishwashers
KitchenAid KUDS30IXBL Builtin Dishwasher Logo
77 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
