Shredder keeps running
Om99729
Shredders have a small lever that is near the cutters that is depressed by the paper that is being shredded, when the paper clears the lever, the shredder shuts off. If it keeps running, paper is sticking in the lever area, holding it down so the shredder cannot turn off. Unplug the shredder and clear the area untill the lever or little arm can move freely, and the problem is solved.
Posted on Feb 27, 2014
4 Suggested Answers
kd6rhd56
  • 400 Answers
SOURCE: Need repair parts schematic or manual for OM99729
closest I could come up with is a Fellowes C14 maunal at www.fellowes.com
Posted on Jul 11, 2009
SOURCE: OfficeMax OM99729 Shredder with bad gear
If it happened within a year, you should have just had the warranty replace it. We had it happen after nearly 11 months, it was replaced within two days.
Posted on Oct 19, 2009
SOURCE: I have an office max
I have the same unit witht he same gear off the motor that has a couple of teeth srtipped. Anyone out there know where to get a replacement gear?
Thanks...
Posted on Jan 16, 2011
How do I oil my executive machines eps-1501x paper shredder
Oil the shredder blades. Refer to this article: http://lifehacker.com/5875771/oil-your-paper-shredder-with-canola-oil-to-keep-it-running-in-top-shape
Mar 02, 2015 | Shredder Office Equipment & Supplies
My office max shredder OM99729 light says it's on but it does nothing and it has another light that says attention but nothing! ANY ideas?
it means your "Trigger" for a Jammed piece of paper is stopping it from running, sounds like something is Wedging it from turning, unplug and look into it for jammed up paper or a staple.
Jul 19, 2014 | OfficeMax Office Equipment & Supplies
Om99729
In the middle of feed opening there is a sensor which in your case will be pushed in and stuck. Try clearing using tweezers or soak it up with WD-40 and still using tweezers try to release the sensor
Jun 21, 2013 | OfficeMax 0M96431 Shredder
I have an office max shredder OM99729 that quit working. the motor runs but it won't pull the paper into the shredder. I opened the cover and found the gear is stripped that runs directly off the motor....
Thanks...
Dec 22, 2010 | OfficeMax 0M96431 Shredder
Shredder keeps running when no paper is inserted and previous shredding job is complete
Some shredders have a switch to run continuous if desired. Check for that first.
Another problem is that during a jam, the paper sensing switch can get bent causing the shredder to run continuous.
Jan 09, 2010 | Royal Office Equipment & Supplies
How do I remove excess EXCESS oil from my shredder? It won't shred.
Asking why you should keep your shredder lubricated is no different than asking why you should change the oil in your car every 3,000 miles. Not only is proper maintenance a requirement to maintain an active warranty, but all mechanical parts need a little oil to help them turn smoothly and to keep them clean. Applying shredder oil to the cutting heads inside a shredder lubricates them so that they efficiently destroy documents sheet after sheet. Fortunately, you will find that taking good care of your shredder is less expensive, faster and easier than caring for your car.
Every time you shred a sheet of paper a fine dust made of tiny paper particles is produced. This dust collects in the cutting assembly of a paper shredder. If allowed to build up, this dust will compact until it completely blocks the smooth turning of the cutting head. Shredder oil will actually break up the compacted dust lodged in the cutting assembly, allowing the parts to move and push out the softened dust.
Shredder oil is specially formulated to eliminate oil residue on the cutting head. Other oils, like WD-40, will attract dust, further clogging the cutters. When lubricating your paper shredder, only use oil specifically designated for shredder use or risk voiding your warranty and further clogging your shredder.
The frequency with which you should oil your shredder depends on several factors: frequency of use, shredder capacity, cut size and type of paper. Your shredder will need more oil the more you use it, the more paper you shred at once and the thicker the paper is that you shred. Also, shredders with smaller shred sizes require extra oil. A 1/4" strip cut shredder used only one to two hours per week will only require a weekly oiling. A cross cut shredder, on the other hand, requires oil after every half hour of use. If you remember to oil your shredder every time you change the bag you'll be in good shape.
There are two fast, easy ways to oil a paper shredder:
The first method involves applying the oil directly to the cutting head. Shredder oil is packaged either in plastic squeeze bottles or aerosol cans, designed for easy application. No tools are required, just aim the bottle directly at the cutting head, through the paper entry point, and apply a fine stream of oil from one end of the cutter to the other. Run the machine in reverse for 10-15 seconds until the entire cutting mechanism is coated. Finally, shred a few pieces of paper to remove any excess oil from the cutters.
The alternative method requires streaming oil onto a piece of paper. Do not soak the sheet in oil, but cover it evenly from edge to edge. Shred the oiled sheet of paper and then run the shredder in reverse for 10-15 seconds to allow the oil to coat the entire cutting mechanism. Finally, shred a few sheets of paper to remove any excess oil from the cutters. In any case, run a couple of sheets of paper through the shredder after oiling to remove excess oil. procedure may be repeated up to three times to ensure proper lubrication.
If you take a few seconds once a week or every time you change your shredder bag to oil the cutting mechanism in your paper shredder, you'll maintain your warranties and keep your shredder running smoothly and efficiently document after document.
click this link directly for more detailed help
---- http://www.howtocleanstuff.net/house/appliances-and-fixtures/how-to-clean-a-shredder/ --------
thanks.please do rate the solution.thank you for using fixya.keep updated.
Sep 22, 2009 | Royal 1280MX Shredder
My shredder keeps running and won't stop in on/auto mode
UNPLUG THE SHREDDER.
If this model has electronic eyes (optics) to control the auto-start/stop function and you oil the cutters, chances are the optics are contaminated with shredder oil. Take a cotton swab with a little alchohol and clean and dry the optics.
If you removed the top cover, it is a possibility that you disconnected the wires from the PC Board.
Mar 01, 2009 | Royal VF1012mx Shredder
Sep 15, 2008 | Office Equipment & Supplies
Does the shredder have the electronic eye to sense paper? Sometimes dust will collect on the sensor causing it to keep running.
Apr 07, 2007 | Tech Solution TS-4500 Shredder
186 people viewed this question
jasbo
jasbo
