Question about Mitsubishi WD-65833 65" HDTV
Tv shuts off then nothing works, even buttons on the front panel.
RCA LCD TV gets stuck on one channel
sounds like you have an intermittent defective main board. ebay rca model for replacement board.
Jan 11, 2015 | RCA Televison & Video
Rca model# d52w135d screen won't turn on
Are you saying that the screen goes black after the DVD player stops working?
Jan 10, 2008 | RCA D52W135D 52 in. TV/DVD Combo
Blank screen with sound, unresponsive panel buttons
Nothing is forever or for free, suggest you donate it or recycle it.
Dec 03, 2012 | Niko OTP-3211W 32 in. LCD Television
My aiwa tv-- A219 is showing message AGING 19DCH in red color and nothing else except dispaly button is working.pls help me
my aiwa tv-- A219 is showing message AGING 2F01H in red color and nothing else except dispaly button is working.pls help me
Nov 11, 2010 | Aiwa F2000 20" TV
On/Off Button on TV not working, constant flashing message
www.lg.com/us/tv-audio-video/pdf/47LG50_spec_sheet.pdf
http://elektrotanya.com/lg_lcd_tv_la84a_mfl41370007_47lg50-ua.pdf/download.html
Above user manual top, below is your service manual, perform the troubleshooting procedures and you should be able to localise your problem.
May 13, 2010 | LG 47LG50 47 in. LCD HDTV
TV stuck/locked up
Hard reset for 4 hours. Completely unplug from the wall....
Apr 16, 2009 | Philips Magnavox 42MF521D/37 Television
HCJ552W 55' samsung rear project....won't turn on
dear friend you have a power supply problem, get one of those cheap meters and open the set, look for a blown fuse, if they are ok wich i doubt, you have to call the repairman.
good luck
caypianan@yahoo.com
Oct 23, 2008 | Samsung HCJ552W 55" Rear Projection...
Front panel button turn tv on and off
If both the remote and the front panel buttons do not work, I would be thinking that it is a problem with the TV's main uPC area. This type of fault can be involved, and would require factory level service where the fault can be properly analysed.
I can tell you in advance, that this type of fault can be expensive to service.
Jerry G.
Jul 30, 2008 | RCA TruFlat 27F520T 27" TV
WS-B55 - Remote doesn't respond, front panel partial response
Genius!! Thanks! I took a dry cotton towl and ran it across the keys on my front panel and whatever was stuck, became unstuck..The internet just saved me $150.
Jun 15, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Remote won't work tv, and stuck in volume down
you sound like you might be having front button problems. if you take the front speaker grill off then unplug connector ZF and it restores normal operation than the front panel buttons are bad. basically the tv will respond first to the buttons and nothing else until the button is depressed.
Mar 29, 2008 | Mitsubishi WS-65611 65" Rear Projection...
Mitsubishi WD-65833 65" HDTV Logo
23 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
