Question about Ricoh Aficio AP410N Laser Printer
Paper exit cover error
Solution above the error
Standard top bin full remove all paper from bin
there are four black plastic finger type actuators protruding from the exit rollers ( in the catch tray) these help push the paper down after exit from printer - in some cases where damp paper is common the curl generated by the fuser heat is enough to trip these \'Fingers\' into the position where the printer thinks the output tray is full to capacity
do you ntoice when the paper leaves the machine if there is any curling in the paper if this is the case open a new ream of fresh paper and try again
also the output tray full sensor is probably covered in dust/paper debris- removing the top cover will reveal the position of the sensor connected to the actuator arms clean and dust this to cure error ( assuming theres no damp paper)
Dec 11, 2013 | HP LaserJet P3005 Printer
I have a Canon imageclass D880 multifunction, error"Paper Jam, slide platen..." I can see the paper deep within the machine ( fuser?) but cannot get to it to get it out.
Hi marcbachm177,
Please follow the steps below on how to remove paper jams inside printers in hard-to-reach places, a pair of medical forceps is often useful.
1. Take off 3 plastic covers one above exit area-slide top to left to access screw. Remove lower exit cover and side cover -unsnaps with 2 pins and there is one more cover I think over the fan that needs to come off.
2.Locate black plastic sheet covering a circuit board carefully pull this back-disconnect 3 plastic connectors that lead from the heater to the circuit board.
3. Using a offset phillips #2 screwdriver remove 3 screws that hold the fuser to the frame.
4. Carefully lift fuser up and out toward the exit area.
5. Pop off black cover remove 2 screws from top of fuser, disengage cover lid locks with a small screwdriver, lift upper fuser heater - be careful NOT to damage plastic heater membrane. remove paper jam and reassemble.
Hope it helps.
Thank you for using FixYa.
Aug 17, 2011 | Office Equipment & Supplies
I have a xerox workcentre XL2130. It had a bad paper jam. I cleared it - now it has an error code E4. I've turned it off and on - hit the clear button - nothing is clearing it? Help! Thanks, Stacia
YOU STILL HAVE A PROBLEM IN THE PAPER PATH...
DOWNLOAD THE USER MANUAL
Clearing the Paper Path
- E-1, E-2, E-3, E-4, E-5
When a paper misfeed occurs the red misfeed indicator flashes
on the WorkCentre diagram, and an E status code will flash in
the Display Window. Paper misfeeds may occur in the areas
shown below. Follow the steps below to locate and clear the
misfeed.
Note: Ensure that the alternate paper tray is lowered
(XL2140df only).
Caution: Do not touch the shiny drum cartridge surface.
Scratches or smudges will result in poor copy quality.
Do not remove paper through the bypass. Unfused toner may
adhere in the area, resulting in smudged copies.
E-1
Steps 1-2 for XL2140df only
1. Lower the right Side Tray 2 Access Door.
2. Remove the misfed paper.
3. Close the Access Door.
If paper cannot be removed, open drawer (2) clear misfed paper.
4. Close the Side Cover.
E-2
1. Press the Release Latch to open the Side Cover.
Exit Area
Paper Feed Area
Fuser Area
Side Cover
35
- E-1, E-2, E-3, E-4, E-5 (continued)
Caution: Do not touch the shiny Drum Cartridge surface.
2. Carefully remove the misfed paper in the direction shown.
If paper cannot be reached, open the paper trays and remove
misfed paper.
E-3
Fuser Area
Warning: The fuser area is hot. Take care when removing
paper from the fuser area.
Note: Ensure that the Alternate Paper Tray is lowered
(XL2140df only).
1. Press the Release Lever to open the Side Cover.
2. Pull down on the fuser lever.
• This will release pressure on the paper.
Caution: Do not pull paper up through the fusing unit. Unfused toner
may adhere in the area, resulting in smudged copies.
3. Remove the sheet of paper in the direction shown.
E-4 and E-5 (2-sided Reverse Copy XL2140df only)
Exit Area
1. Pull down on the fuser lever.
2. Gently pull the paper out through the exit area.
36
3. If not accessible, turn the knob in the direction of the arrow
to move the paper to the exit area.
4. Gently pull the paper out through the exit area.
Feb 12, 2011 | Xerox WorkCentre XL2130f Laser Printer
I have a message "remove paper from standard
I have seen the flag sensor (white part dangling on the left side by where the paper exits the printer) pops loose from the frame. If you can wiggle it, it has popped loose. If this is the case, you can open the left side cover and remove the redrive cap (long plastic piece above where paper exits) to gain easier access to this. If you have more questions about this sensor, feel free to request more info.
Jan 07, 2011 | Lexmark T640 Laser Printer
Error: open upper cover exit jam
Feed Jam or Exit Jam ecblank.gif ecblank.gif dot.gif ecblank.gif 1. Remove the tray and clear any misfed sheets as given above.
2. Open the top cover.
WARNING! The fuser area will be hot. This area is clearly marked. Do not touch it.
CAUTION! Never expose the image drum unit to light for more than 5 minutes. Never expose the image drum unit to direct sunlight. Always hold the image drum unit by the ends or from the top. Never touch the surface of the green drum inside the image drum unit.
3. Carefully lift out the image drum, complete with the toner cartridge. Be careful not to touch or scratch the green drum surface.
4. Remove any jammed sheets from the paper path.
5. Re-install the image drum complete with toner cartridge, ensuring that it correctly locates into the slots on each side of the printer.
6. Close the top cover and press down to latch it closed.
7. The printer will warm up and commence printing when ready. he page lost through the jam will normally be reprinted.
NOTE If the edge of the jammed paper protrudes (or can be seen) from the exit, reinstall the image drum, close the top cover and switch the printer on. Remove the jammed paper from the exit when the exit roller begins rotating after a few seconds after switching on. However, if the jammed paper cannot be removed, contact a service representative.
Mar 12, 2010 | OKI B4350 Laser Printer
Need to identify where paper sensors are in paper path. Can not clear paper jam. have totally cleared paper path removed all necessary parts even removed covers and blew machine off. also, sensor for over...
its probably exit sensor which is in the right hand corner just above fuser. hard to get to will need to remove fuser,front small square cover and prob exit cover ull see actuator and a long shaft which will lead u to a sensor.it will prob out of place or covered in dust.
Feb 24, 2010 | Ricoh Aficio 180 Laser Printer
My xerox workcenter 416s has the following error: close offset cover. What is this??
There is a small cover where your paper exits into the tray. It probably is just ajar and not actuating the switch. Check in the area above the right side where you would clear a jam and where the already made copy comes out. Something there is not closed all the way, or the interlock switch has popped out.
Jan 06, 2010 | Xerox WorkCentre Pro 416SI All-In-One...
Close Exit Cover to Continue error message won't go away
sounds to me like one of two things has happened.
More than likely the actuator tab on the cover snapped off,
Look for an opening around the edge of the cover , there is a cover interlock switch in there. Note its position and look at the cover to verify there is a tab on the cover to actuate the switch, Or you may have a loose connector on the interlock switch, or a bad switch, although I have never seen one of those switches go bad.
Jan 30, 2009 | Xerox Phaser 8400 Laser Printer
Canon D880 Printer/Fax
remove lower exit cover and side cover -unsnaps with 2 pins and there is one more cover I think over the fan that needs to come off.
3. using a offset phillips #2 screwdriver remove 3 screws that hold the fuser to the frame. carefully lift fuser up and out toward the exit area.
4. pop off black cover remove 2 screws from top of fuser, disengage cover lid locks with a small screwdriver, lift upper fuser heater-be careful NOT to damage
Nov 15, 2008 | Canon imageCLASS D880 All-In-One Laser...
XEROX 5328
That is an exit Jam code in the fuser.
You may just have one of the fingers bent straight down blocking the paper.
There also may be a secondary code that is causing the E-4-0.
But that is where to start. Look under the exit web cover for a piece of paper crumpled in that area.
Once there you may have to remove the fiser web cover to remove that jam and straighten out the finger.
MAKE SURE IF YOU GO INTO THAT AREA TO UNPLUG THE MACHINE.
Dec 07, 2007 | Office Equipment & Supplies
Ricoh Aficio AP410N Laser Printer Logo
19 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
