Question about Coffee Makers & Espresso Machines
Tchibo caffissimo Why does the water drop light blink three times in succession, repeatedly, when there is enough water in the water tank?
Shuttle83
  • 1139 Answers
SOURCE: The PT-53WX52
This looks like a problemcausing the shutdown circuit to trigger. The shutdown circuit prevents the TV from being further damaged by an overcurrent or overvoltage event. The overcurent event is caused by a component being over driven and thus it decreases in resistive value causing an increase in current, The over voltage event is caused by a component increasing in its resistive value either due to an open circuit or decrease in the component's conductive area. In any event the shutdown circuits senses these eventes and shuts the TV down to prevent futher damage.
I would suggest taking the set to your local TV repair shop.
I hope this helps,
Shuttle83
Posted on Nov 16, 2007
SOURCE: panasonic PT 47WX53G
I just replaced these parts a couple of months ago, but used "generic" parts.
You can bet I won't make THAT mistake again!
LOL!
Posted on Sep 15, 2008
  • 4894 Answers
SOURCE: air bag light is on
Common fault on FORD
Usually due to a poor connection in the YELLOW PLASTIC CONNECTOR underneath the passenger seat.
Just push it together properly and it should clear the AirBag fault
Posted on Sep 06, 2009
ginko
  • 19396 Answers
SOURCE: toshiba 72HM195 blue light blinks
Hi.
Rather than the number of blinks you need to count the blinking time intervals.
If the yellow is staying on 3 seconds, and the blue blinks last half second, then the problem is the lamp cage door. In that case:
  • Disconnect power cord for ten minutes.
  • If problem persists, disconnect again and check lamp cage door.
  • Replace door switch (must be done by technically trained person).
I uploaded here the full error code troubleshooting for this model. Click on the link, then click on the picture again to enlarge. Alternatively print out the error codes page.
Regards.
Ginko.
Posted on Mar 27, 2011
welcomejee
  • 10594 Answers
SOURCE: The power/standby light blinks red
Please make sure lamp cover is fixed properly as it was removed to replace/ check lamp in tv.
If lamp cover is not fixed, tv will not turn On and red light will blink 3 times.
Thanks.
Posted on Apr 28, 2011
Clean light keeps blinking and I cannot get dishwasher to start cleaning dishes. It seems to be hung up.
If it blinks 7 times, then pauses, then 7 times....over & over, then the computer control has failed to see an increase in water temperature during the last cycle. That means the heater could be out, the temperature sensor is out, the heater drive circuit is bad, there is not enough water or the water is not circulating properly. The newer models have different blink sequences that mean other things. On most models you can press hi temp wash>heated dry>hi temp wash>heated dry in quick succession to enter a service mode. All the lights will come on, then after the control clicks a few times, just press cancel & the control will be reset & you can run another cycle. If it does the same thing again at the end of the next cycle, it will need repairs.
Feb 16, 2016 | KitchenAid Dishwashers
Why does the water valves continually pulse?
It's hard to answer such a general question. I will assume your reference refers to a toilet, and that 'pulse' is regards a recurrent slight refill action of the tank fill valve. If this is the case the cause is probably a slowly leaking flush valve. When the tank water level drops enough to activate the fill valve, there will be a slight refill action (pulse) to top up the tank water level. It will repeat until the leaking flush valve is fixed.
Jun 06, 2015 | Home
I just replaced the bulb last week, yet this time the TV will still not turn on and all three lights are still blinking.
It is possible that the replacement lamp is bad but more likely the TV has a protection mode that triggers wen the lamp goes out. Check the manual for ways to reset the lamp usage back to zero or a function that needs to be manually reset when the lamp is changed.
May 02, 2015 | Televison & Video
Why does the power light keep blinking
The blinking light is wrongfully indicating that there is not enough water in the tank. The sensor is a small magnet that is floating in a compartment at the bottom of the water tank. (The black square in the corner) You shold be able to see it. Check if it is stuck at the bottom and if it is floating in its chamber. If that is OK, the sensor inside the coffee maker that is reading the magnet might either have come faulty or dispaced (due to a shock?). That would need a disasembly of the coffee maker.
Villi
Jul 05, 2014 | Philips Senseo HD7820 Espresso Machine
My hec washer wont spin fast enough to remove the water at the end of the cycle?
If your washer is over three years it would be good to check your motor brushes. Get spares from advts on this site, there are several. Before that check your motor for brushes (gud videos on YouTube to guide you regarding brush change). Slow or bad spin is usually connected with worn motor brushes.
Click if helped pl.
Mar 04, 2013 | Washing Machines
2003 toyota avalon xls abs,traction, and vsc lights come on when raining
Sounds like water intrusion into one or more Wheel Speed Sensors. You need to have it scanned and see which sensors are dropping out when they get wet. Then replace them or have them replaced.
Mar 05, 2012 | 2003 Toyota Avalon
Jag s type 2001 the water header tank burted en toute and due to coolant the engine management systemreduced engine power until i stopped uppon cooling down i filled with lookwarm water and limped home...
Sometimes this bleed method is not enough.
Bleed air out of the very top water hoses on the engine (when cold!) whilst filling. Then run the engine for a short time, check tank level again and if required refill when cool enough to be safe, repeat this if water level drops in tank again. When water level in header tank stays constant run the car up to full temp. and see if problem is fixed. Then check level again when cool.
good luck. Hope this helps.
Sep 08, 2009 | 2001 Jaguar S-Type
Laptop will not boot
ok, take the battery out and leave it unplugged for a few hours.  Only plug the ac adapter in after.  Press and hold the power button for 10 seconds.  Does it still do it?  If it does work, then chances are your mobo has bit the dust or you have knocked loose an internal charging part.
Mar 09, 2009 | Compaq Evo N410C Notebook
Whirlpool quiet partner I won't run just keeps blinking
is the cean light blinking 7 times and then repaeating?? If so this is a water heating fault and means that the computer sensed that the water temp didnt rise just 3deg in the last main wash cycle. If its not blinking 7times then repeat, it sounds like the user interface (membrane switches) have failed. Let me know more and i can help.
Apr 19, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
No suction
I finally got my steamvac F5914-900 suction to work after I read someone review about it on amazon. Here is what that person suggested for suction problem and to my surprise it worked.
1. Any time you aren't getting suction, the first thing to do is check the dirty water bin. I re-seated the thing about ten times this morning, trying to figure out why suction on the unit had ceased. (The dirty water tank was bone dry.) I was frustrated because I was absolutely sure everything was seated properly, but was still getting no suction.
Finally, I pushed on the lid from the _sides_ rather than the back or front while attaching it to the tank, and it seated a little bit differently. Suction was restored!
2. To clean out the suction area, pour some hot water on a tile floor (NOT wood) and **** it up. Repeat until everything is flowing smoothly. Sometimes, reduced or minimal suction is due to gnarly clogs. Again, though, if you're getting NO suction, the culprit is probably the dirty water bin's lid.
I hope this helps.
Mar 23, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Coffee Makers & Espresso Machines Logo
145 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
