Question about Maytag Centennial MVWC500V Washer
WILL NOT SPIN WATER OUT PROPERLY ON FINAL CYCLE MAKES A THUMPING NOISE
SolutionGuy
  • 331 Answers
SOURCE: Loud noise when spinning
I agree with Gittos on the bearing assessment. This considered part of the drive system. If it's less than 5 years old, your next move is to contact Sears and claim a warranty repair on the tranny (it has a 5 year warranty on it). If it's more than 5? Well, honestly it wouldn't be worth the repair. You'd have spent more money on all the parts required than what the unit is worth (worth= what it would sell for in working condition on the market). Hope it's less than 5!
Posted on Aug 12, 2007
  • 38 Answers
SOURCE: making screeching noise during spin cycle
Problem: very irritating squealing sound when washer is spinning or coasting to a stop after the spin cycle.
Case:  1. Snubber damage defective.
           2. Foreign material (sand/dust or grit) is on the base.
Solution: 1. Replace the snubber.
                2. clean base.
     The snubber is a ring that is located between the convex (domed up) center portion of the base and the domed down center portion of the LEG & DOME ASSEMBLY.
     The snubber has teflon strips at the top and bottom edges that slide easily on the base as well as the underside of the leg and dome assembly.
     This system makes the machine very stable by providing isolation between the leg & dome assy. Which carries both the inner and outer tubs, as well as the main motor and transmission and the base; which is of course connected to the cabinet. This means that the machine is capable of spinning out of balance loads.
     As simple as this system is, if one on the strips is bent or there is some foreign material on the base in the snubber area, the result can be an extremely obnoxious scratching or squealing sound that can make the consumer very unhappy.
     A very similiar sound can be produced when the belt is worn but the difference is that a snubber noise can be produced during the spin cycle or when the cycle has finished and the spin tub is coasting to a stop. A worn belt noise can only be produced while the motor is actively engaged in spinning the spin tub. If it is discovered that the belt is worn and the base has black, shredded belt residue then it may not necessary to clean it out (belt residue generally will not cause a problem with the snubber). It will be necessary however, to find the cause of the belt failure.
     The following procedure should be followed to diagnose and eliminate this condition:
Removing the snubber:
The base must be wiped whether the snubber is replaced or not.  Any residue whether it is dust or grit of any kind (other than belt residue as noted above) can cause the objectionable sound to occur.
Remove the front service panel and place the timer in the spin cycle and start the machine.  You want to try to duplicate the complaint.  Inspect the base for sign of any foreign material.  Lift the top panel up and over and lean it against the rear wall.
You will need a tool to raise the entire Leg & Dome Assembly (to which the main motor, tubs and transmission are attached).  The machine will not need to be disassembled; the springs will not even be released.
Some Techs use a length of two-by-four" to raise the assembly.  A pry-bar makes a superior tool when combined with a block of wood to act as a fulcrum (or pivot point).
Before raising the assembly, pull forward on it so that when you do raise it, the rear of the tub cover does not catch on the rear cabinet frame as it is being lifted.
Using your body weight, raise the assembly high enough to slide the snubber out.  You will need to inspect the snubber for defects or damage.  It is a good idea to be prepared with some sort of supports (like 3/4 inch pieces of wood) to slide between the lower edge of the assembly and the base to help support it if it were to slide off your pry-bar.
Posted on Mar 14, 2009
dwrooker
  • 6 Answers
SOURCE: maytag PAV2300AWW Washer makes grinding sound when agitating
Sounds like it is the bearing on the water pump. Take off back plate and replace and remove 3 screws and two hoses (the one hose is a waste line so make sure you have a bucket to empty our waste water) after removing these remove belt on bottom of pump.
Posted on Oct 06, 2009
  • 17 Answers
SOURCE: make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Posted on Oct 24, 2009
BIKER T
  • 909 Answers
SOURCE: will not do final spin cycle leaving clothes
Your drain pump has something lodged in it. Remove drain motor, open it up and inspect for obstruction. remove it then reassemble.retrywashing cycle.
Posted on Nov 12, 2009
LG front load washer makes thumping sound in spin cycle. It sounds like fun rubs when machine is filling . It is not off balance.
Hello..
Check the machine legs and ground level properly, and also dont put a single blanket or a single weight cloth sure it will make noise..
Feb 06, 2018 | LG Washing Machines
Loose washer drum, load noise on spin cycle
your basket hub is stripped and to gain has a specific tool to remove and not destroy the locking nut for basket the agitor and items need to be removed it may be best to call a tech in your area
Sep 01, 2009 | Kenmore Washing Machines
Loud thumping while stopping after spin cycle.
make sure the shiping rod is out it will do that if it,s not out
May 29, 2009 | Kenmore 22422 Top Load Washer
Thumping Noise
it must be due to the damaged belt inside the motor. check it out.
thank you
Mar 09, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Whirlpool Duet won't drain, won't spin and makes a light thumping noise
can help but need to know a few things first in drain do you hear any thing running and turn it back to wash and see what happens don't rate me till were done un less you just want to give me my four boxes lol
Jan 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Yes the brakes are grabbing too hard....I will sometimes lubricate them....Or replace the basket drive assy. You do know how to take the cabinet off i take it??
Oct 02, 2007 | Washing Machines
Washer makes loud thumping after finished spin cycle
I replaced the drive block and it solved my problem. (thumping noise at the end of spin cycle) Easy repair. Videos on utube show all the steps.
Jun 07, 2006 | Whirlpool LSR7333 Top Load Washer
Maytag Centennial MVWC500V Washer Logo
27 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
