Question about Rosen GPS
Screen wont turnon but radio works
Radio still functions but touch screen nav wont turn on
WHAT IS PROBLEM IF RADIO/CD PLAYS BUT NAV/RADIO SCREEN IS BLACK
its internal circuit problem in radio ,it selector switch is not moving to radio position,
Jun 15, 2014 | 2009 Dodge Journey RT
Radio/nav screen won't turn on
Its not reading the disk which means it has a internal fault so remove the radio and seek profession advice
Nov 29, 2013 | 2005 Maserati Quattroporte
Nissan primera no heaters no sat nav no radio or cd plus the doors wont lock any solutions thanks
check all your fuses and relays could also be a short in a wire somewhere.
Feb 20, 2013 | 2003 Nissan Primera
Radio/nav system dead
I have 2010 Porsche Cayenne and Nav screen just goes black and turns back on - sometimes it does it few times a day sometimes its working fine ..any idea?
Jul 13, 2010 | 2006 Porsche Cayenne
I purchased a 2002 Range Rover Borrego recently.
I have experienced many electical demons with all my British cars. The nav units can and do fail. I had a goofy one this summer and the only way it got fixed was to replace it. The module not the head unit
Mar 24, 2010 | 2002 Land Rover Range Rover
2000 bmw x5 nav screen blank. radio works but no
I know this is an old thread, but my 2006 325i Nav screen went bank also, but the radio still played. I noticed the glove box light and trunk light did not turn on also. I was told from mechanics is was probably a CID module for $2200, even though I mentioned the glove box and trunk light light were out and specifically inquired about a fuse. The mechanics never checked the fuses, because I checked my fuses in the glove box and found the fuse 61 marked with a BMW symbol that looks like light bulb was blown. The Nav screen started back up once the fuse was changed.
Feb 03, 2010 | 2000 BMW 5 Series
2004 BMW X5 4.4i Left lights on resulting in flat battery. Car was jump started from another vehicle (Ford Transit van). Everything fine for a few days. Now, intermittently the radio/sat nav goes haywire!...
sounds like your car has the multi function steering wheel, i know on the 7 and 5 series they come out of sync, im not sure why.
its about £75 to get plugged in at the dealers and they reprogram it, sometimes i have had the odd car with a damaged slip ring, it does all sorts of things, 1 in particular kept on beeping the horn,
i would say if u got 1 urs got upset when battery flat.
Apr 22, 2009 | 2009 BMW X5
Nav system
Do you still have warranty left? If so bring it into the dealer for service. Otherwise if you don't have any warranty left there is a software update the dealer can do that may fix it, if that doesn't fix it, a new radio is around 1900 dollars.
May 28, 2008 | 2007 Jeep Wrangler Unlimited Rubicon 2...
GPS Logo
27 people viewed this question
Top Rosen GPS Experts
Will Halftowaite
Are you a Rosen GPS Expert? Answer questions, earn points and help others
