Question about Olevia LT37HVS 37 in. LCD HDTV
Blue light flashing onand off and tvwant come on
Battery light and stop light comes onand off when accelerating occationally
your alternator has a bad connection /may need replaced and try renewing belt
Apr 20, 2016 | Cars & Trucks
Faby 2 compressor turns onand immediately it shuts off again
could be one of many problems. the most common is the 4 minute timer that keeps the compressor from short-cycling. open up the right front panel and the timer is gray and almost circular and near the top of the inside. with the machine off, unplug the 2 long, thin blue wires that go to the motor of the timer, but do not unplug the orange, light blue and brown wires going to the timer. now turn the machine on and using a flat head screwdriver, turn the slotted head in the front of the timer clockwise until the compressor turns on. now the timer is disabled, and the timer isn't that necessary. if you still have a problem and all switches are on, you may have a blockage in the high side refrigerant line and the higher pressure triggers the compressor to shut off
Oct 02, 2014 | Kitchen Appliances - Others
2005 xr6 mk11 a light in th shape of a hand flashes onand off located to the left of the speedo
Its the symbol to let you know the "smartshield" security system is operating. It is supposed to stay on for about 3 seconds when you start the car but should go out and stay out. If its flashing on and off during driving, you must have something wrong with the security system. You could try disconnecting and then reconnecting the battery (Leave disconnected with the headlights on to drain all residual power) for about 1 hour. reconnect the battery and try it then. If this doesn't work, it may need a resolution by a Ford Dealer. They have the special electronic equipment to locate and solve the problem. Hope this works out for you.
Oct 16, 2013 | Car Audio & Video
A6 TDI ESP LIGHT COMES ON
The light indicates a fault in the system. You must now have the Audi dealer perform scan and diagnostics to determine the cause of the warning light.
Sep 14, 2012 | Cars & Trucks
Check engine light on and flashing, car shaking, all of a sudden
you have a bad engine missfire. a flashing check engine light means you are in danger of damaging your catylitic converter and you should scan the car. most causes of missfires are plug wires and or coil pack.
Dec 12, 2011 | 2001 Chevrolet Cavalier
What does 2 flashing blue light mean on the S9.
Blue (three flashes) powering on/enabling indicator light
Blue (steady) pairing mode
Blue with 10 quick purple flashes
pairing successful
Blue (long flash)
standby (connected but not
on a call or streaming music)
Blue (quick flash)
incoming call
Blue (long pulse)
on a call
these are all the normal blue flashes that the s9 makes
Dec 10, 2009 | Motorola Mobility S9 Headphones
Engine light onand OD OFF light flashing on 95 Lexus ES300
You just need a scan to reveal the actual error codes to you.
Fear not.
Rate this
Jun 04, 2009 | 2001 Lexus ES 300
Glowplug light on my golf tdi
Hi Andy,
Remarkably, this problem is often associated with a faulty brake light switch down at the pedal!
It happened to my '97 Sharan the other day whilst driving along, and the merest tap on the brake pedal with my left foot stopped the glow plug light flashing.
Posh folk sometimes replace the switch; I would suggest checking the connecting wires down there first :-)
Hope this helps you a bit. If it does, a "Fixya" rating would be much appreciated. If it doesn't
help you, I'd be grateful if you didn't bother with a rating at present - they can't be increased later if I do manage to solve your problem! Just come back and tell me what you found. Cheers, D
Dec 03, 2008 | 2001 Volkswagen Golf
I have an HPDV2000
You need a new hard drive. Sorry.
Aug 18, 2008 | Computers & Internet
Olevia LT37HVS 37 in. LCD HDTV Logo
27 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
