Question about Canon Office Equipment & Supplies
Will not print after ink replacementit shows
The printer ink level indicators show full but it puts out blank sheets when asked to print although it sounds as if it,s trying to print
    Problem Solver:
  • 5 Answers
Shut down computer
unplug printer from power outlet ( it must be unplugged )
remove both printer cartridges
make sure there is no tape or other items on cartage
reinstall cartridges
plug printer in
turn on printer
turn on computer
Posted on Feb 15, 2014
  • 1003 Answers
SOURCE: PRINT command
uninstall ink with printer on and turn off then back on when printer says install ink do so if that doesnt work clean contacts with rubbing alcohl on ink cartriges.
Posted on Jan 07, 2008
The Machine
  • 788 Answers
SOURCE: printing blank pages
Did you remove the seals from the cartridges before putting them into the printer?
Posted on Jan 17, 2008
SOURCE: Black ink stopped printing
Did you solve this problem, the exact same thing has happened with mine?!?
Posted on Mar 11, 2008
  • 66 Answers
SOURCE: printer will not print anything. Ink levels are
If it has been longer than 3 or 4 weeks since anything last printed, the problem may be clogged print heads. Run thru several cleaning cycles and see if anything begins to appear on the paper. If not, changing the ink cartridges may solve the problem. If it's been quite a long time since last printing, you may need new (and expensive) printheads. If that's the case, replacing the printer would be more cost effective. Sorry for the bad news.
Posted on Aug 13, 2009
bob_computer
  • 3153 Answers
SOURCE: Refilled Lexmark X4530. Printer continues to show
It is highly unlikely to be a driver issue.
Most modern cartridges have an ink level chip built on to them.
Should the level drop below 25% then most of these chips lock up and will not reset.
If you are lucky you should be able to find either a resetter
-cli8-pgi5.html" rel=nofollow target=_blank>chip resetter around on the internet
OR
Even better empty cartridges that never need to be reset.
That's the option I like I realise these are not for your specific printer but there are others listed on both those sites as well
Posted on Aug 20, 2009
Testimonial: "I think you are right. That is a great idea to find a a refillable cartridge! Thanks."
When i gave print from doucment machine takes paper and give it as it as blank, solve my problem,
Solution one: Check the ink levels To allow for full use of the cartridges, some printers continue to print even after the cartridges are completely out of ink. Follow these steps to check the ink levels in the Toolbox . The Toolbox is part of the standard printer software. Depending on the version of Toolbox on your computer, the appearance of the Toolbox features might vary. NOTE: Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low ink levels, consider having a replacement cartridge available to avoid possible printing delays. Print quality deteriorates as cartridges run out of ink.
  1. Click Start .
  2. Click Printers and Faxes .
  3. Right-click the icon for your printer (c01532298.gif ), and then click Printing Preferences .
  4. Click the Features tab.
  5. Click the Printer Services button. The Toolbox window opens.
  6. Click the Estimated Ink Levels tab. A window opens that indicates the estimated ink level of each cartridge. NOTE: Depending on the printer, the estimated ink level indicators can vary in appearance. Examples of estimated ink level indicators c01867289.gif c01867290.gif
  7. If the ink level indicators show that a cartridge is low or empty, replace the cartridge.
  8. Try printing again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution two: Restart the printer Restarting the printer might clear the issues and allow the printer to function correctly again.
  1. Press the Power button (c01602202.gif ) to turn off the printer. NOTE: Pressing the Power button might not turn off the printer. This might happen if the printer is in an error state. Continue with these steps regardless.
  2. Disconnect the power cord from the back of the printer. Figure 1: Disconnect the power cordc01869581.gif
  3. Disconnect the USB cable from the back of the printer. Figure 2: Disconnect the USB cablec01850063.gif
  4. Wait 30 seconds.
  5. Reconnect the USB cable to the printer. Figure 3: Reconnect the USB cablec01868577.gif
  6. Reconnect the power cord to the printer. Figure 4: Reconnect the power cordc01869582.gif
  7. Press the Power button (c01602202.gif ) to turn on the printer.
for more information see this page
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01892627&lc=en&dlc=hu&cc=hu&product=1138373#N46
i hoprt his helpful
thank you for using fixya
Feb 15, 2011 | HP Officejet 4355 All-In-One InkJet...
Problem with inkjet indicator
sometimes the ink level report does not reflect the true picture. what you should do is see whether it is printing faded or not printing blank. If printin normal you really shouldn't worry. If it were not printing I would suggest you returned it but that is not the case.
Oct 27, 2009 | Lexmark X6575 All-In-One InkJet Printer
Printer is printing blank pages ink levels read full.
Make sure that what you are printing from the PC is black. This sounds so trite, but if for some reason you have set the font to white you may be able to see what you have written on the screen - but it won't print. Another possibility is that somehow the print in the document has been set to 'hidden'. That doesn't help either.
Failing that you may have to reinstall the printer. Use the printer disc to do this.
Jul 08, 2009 | Lexmark Z600 InkJet Printer
No ink coming out on my Canon S900
1. Start with the printer OFF
2. Hold down RESUME and then hold down POWER
3. release RESUME
4. press RESUME twice, then release POWER
5. Let green light blink until printer is done moving print head.
6. Select functions below with RESUME press POWER to execute:
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Jun 29, 2009 | Canon S900 InkJet Printer
932c prints intermittantly
this is b coz of paper quality and sometimes due to moisture but try loosing the static and restart the system
May 07, 2009 | HP DeskJet 932c InkJet Printer
My printer can't read the new ink level after refilling
The ink level indicator is only an estimate to give you an idea when it's time to buy a new cartridge. You cannot reset the ink level indicator so simply ignore it if you refill your cartridges. See pg 72 of the user manual which you can get here: http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
Dec 06, 2008 | HP DeskJet F4280 All In One Printer InkJet
Epson c60 problem
methinks you'll need to do a clean and calibrate on those new ink stations.
May 11, 2008 | HP PhotoSmart 7260 InkJet Printer
No ink showing on page
there is no issue with the cartriage this issues occur most of times open the printer clean all parts and try again
Jan 24, 2008 | HP Deskjet 3845 InkJet Printer
Pixma MP780 Printer, not printing
sometimes those measures of ink levels are not very accurate. actually they're usually rather far off... try a new cartridge Usually the easiest solution.
Aug 13, 2007 | Canon PIXMA MP780 All-In-One InkJet...
27 people viewed this question
old marine
old marine
