Question about Dryers
Roper gas dryer
No heat
  • Dryers Master
  • 2,699 Answers
Don;t know if anybody helped you,if you live in the camb.area or around that area in ma. peter de's is a great tech 781-760-9692
Posted on Feb 15, 2014
  • Sal De Feb 15, 2014
    i'm sorry the number is 781-438-9442 peter de's appliance
4 Suggested Answers
tony2155
  • 64 Answers
SOURCE: my roper gas dryer is not heating up,
check the ignter and or fuse
Posted on Jul 01, 2009
SOURCE: Roper dryer runs but has no heat
my roper dryer does not heat up i checked thermostat, thremo fuse and heating element they show working could it be my timer when dryer is running timer does nt advance it stays in the same position.
Posted on Feb 07, 2010
SOURCE: my Roper gas dryer runs, but will not heat up in
gass dryers have what they call an igniter it is either electronic or a ceramic stater check to see if it sparks or if in case its ceramic it glows look by the gas inlet and determin which one you have the ceramic igniter looks like a little torpito it just un clips the electronic starter takes a little knowlege allways disconect power before servicing good luck
Posted on Apr 12, 2010
Roper Electric Dryer...model RED4440XQ0 will not heat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 04, 2011 | Roper RES7646KQ Electric Dryer
Roper gas dryer has no no heat. not really sure of dryer #. but this is the basic set up.
heatman101[
Mar 24, 2011 | Roper RGX4634KQ Gas Dryer
Roper gas dryer won't heat,even after installing a new inginter what else
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 19, 2011 | Roper RGX4634KQ Gas Dryer
Want heat roper heavy duty dryer
heatman101
Dec 14, 2010 | Roper REX4634KQ Electric Dryer
Roper gas dryer does not heat, timer does not move, runs continuously, can the timer malfunction cause dryer not to heat?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 22, 2010 | Roper Dryers
Low heat from roper clothes drier
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 13, 2010 | Roper Dryers
ROPER GAS DRYER WILL NOT BUT RUNS
heatman101
Aug 13, 2010 | Roper REX4634KQ Electric Dryer
Roper dryer gives off no heat
heatman101
jjk
Nov 24, 2009 | Roper RGX4634KQ Gas Dryer
Roper gas dryer does not heat.
If the ignitor is not powering , go to the switch. That has to send power to the ignitor, then on to the gas valve.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 22, 2009 | Roper RGX4634KQ Gas Dryer
Dryer tumbles, no heat
its a gas dryer it doesnt have ,,heating element...replace thermal fuse
Dec 28, 2008 | Roper RGX4634KQ Gas Dryer
Open Questions:
Dryers Logo
Top Dryers Experts
