How to install front stabilizer links on a 2004 ford freestar
SOURCE: ford freestar 2004 the TRAC OFF message comes
I had the same problem and apparently fixed it by mistake. I replaced the cruise control deactivation switch under the master cylinder, hoping the cruise would be fixed. Some how with that the "trac off" light went out and gave me the ability to turn it on/off from the button again. The part was $30 from the local dealer and easy to replace. Before you run out to replace the switch check the connections on the old one. It plugs in upside down which may accumulate water from puddles and things causing connection issues ( a known problem ).
Posted on Sep 23, 2009
  • 4369 Answers
SOURCE: 2004 Ford Freestar with P0340 Code. What is it
camshaft position sensor
Posted on Jan 16, 2010
SOURCE: 2004 ford freestar rear hatch latch broken
have you fixed yours yet? mine started doing this last year
Posted on Mar 18, 2010
  • 1757 Answers
SOURCE: Install Serpentine Belt 2004 Ford Freestar
Click on the following free direct Link. It has the correct Serpentine/Drive Belt Diagram for your 2004 Ford Freestar. You either have the 3.9L or 4.2L V6 Engine. I am not sure what Engine options (AC/No AC, etc.) you have. If this Diagram is not correct: check on the underside of your Hood for the correct Belt Diagram. However the below "How To" remains accurate.
http://www.2carpros.com/car_repair_information/year/2004/make/ford/model/freestar/2004_ford_freestar_drive_belt_routing_diagram.htm
"HOW TO":
Standard Rules to Removal the Serpentine Belt with an Automatic Tensioner:
1. Find the Tensioner(s). (See Diagram on Link)
2. Using a Serpentine Belt Tensioner Tool, Or Wrench OR Ratchet, Rotate/Move the Tensioner USING THE AVAILABLE NUT (on the Pulley or Arm Base) OR the OPENING (3/8ths or 1/2 inch square opening) rotating the Tensioner Pulley/Arm - moving it away from contact with the belt and towards the area where the belt is not in contact with the Tensioner Pulley. The Tensioner is spring loaded, and is hard to rotate/move.
3. Remove the loosened belt off one of the other more easily accessed Pulleys.
4. DO NOT quickly release the Tensioner, but gently allow the Tensioner to rest in its closed position.
Standard Rules for Installing the Serpentine Belt with an Automatic Tensioner:
a. Pick a Pulley that is most easily accessed. This will usually be on top. This will be the last Pulley that the belt will go on.
b. Using the Diagram: Install the new Serpentine Belt on the remainder of the Pulleys....over, under, left right.
c. Using a Serpentine Belt Tensioner Tool or Wrench or Ratchet Tool: Rotate/Move the Tensioner Pulley/Arm "away" from Belt contact area on the Tensioner. This spring is pretty hard and with a new belt, it will be even harder to install. Rotate/Move this to as-close to the maximum allowed inorder to have enough slack in the belt to get it up and over the last pulley.
d. Using your other hand - Pull the Belt up and over the Last remaining Pulley.
e. Before releasing the pressure on the Tensioner, visually inspect the remainder Pulleys and the Belts' Positioning on them.
Let me know if this helped, or if you have additional information questions. Feel Free to contact me at FixYa.com!
Posted on Apr 05, 2010
SOURCE: replace spark plugs on a ford freestar
I have a 2004 ford freestar and it's missing a lot I changed the spark plugs and fuel filter. what else can I do ?
Posted on Jun 05, 2010
What is the Front Hub Bearing Torque specs
In case you have a issue in the future there was a recall on the vehical
Recall ID # 42233 - WHEELS:CAP/COVER/HUB plus.gif Full Details Recall Date SEP 13, 2004 Component WHEELS:CAP/COVER/HUB Model Affected Freestar Potential Units Affected Read more: http://www.motortrend.com/cars/2004/ford/freestar/recalls/#ixzz389x5ubZp
But the answer to your orginal question is
Torque to this setting. Axle Nut: 96 Ft/Lbs - Apply threadlock to the last five axle shaft joint threads before installing the nut.Flange Bolts: N/A.Wheel Studs: 100 Ft/Lbs.
Jul 22, 2014 | 2005 Ford Freestar
6 mont a go
Is the ABS light on also?
Traction control systems use the anti-lock brake system to achieve stability. If the ABS system is not functioning correctly, it will render the stability control system useless, since they are, essentially, the same system.
Apr 26, 2014 | 2004 Ford Freestar
Is there a fuse for the vent button in a 2004 ford freestar
maybe try this link
http://www.edmunds.com/ford/freestar/2004/consumer-discussions.html
Jan 15, 2013 | 2004 Ford Freestar
I have 2004 ford freestar it makes a poping noise as u drive changed cv joint don't know what else it might be
lots of things can make it "pop". check the hub bearings, the stabilizer links, the tie rod ends, the balljoints, the struts and strut mounts, the engine cradle bushings, the control arm bushings ,and the engine mounts. GOOD LUCK!
Jun 14, 2012 | 2004 Ford Freestar
2004 ford freestar van idles rough
For rough idle and error code issues on your ford freestar.Click the link below:----
http://howtobyme.blogspot.in/2012/01/2004-ford-freestar-van-idles-rough.html
--------This will help.Thanks.
Jan 31, 2012 | 2004 Ford Freestar
Replace broken sway bar for a 1996 ford windstar
Section 04-01: Suspension and Wheel Hubs, Front 1996 Windstar Workshop Manual REMOVAL AND INSTALLATION Stabilizer Bar Removal
  1. Raise and support the vehicle. Refer to Section 00-02 .
  1. Support vehicle with hoist or safety stands behind front sub-frame (5C145).
  1. stw~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: To avoid damage to the 6 mm drive hole in the front stabilizer bar link ball stud, do not use an Allen wrench to break loose or tighten or final tighten the front stabilizer bar link-to-shock absorber nut.
    Using care not to damage the front stabilizer bar link ball stud seal, remove the RH and LH front stabilizer bar link-to-front shock absorber nut.
  1. Using care not to damage the front stabilizer ball link stud seal, remove the RH and LH front stabilizer bar link-to-front stabilizer bar nut.
  1. stw~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use extreme care not to damage the ball joint boot.
    With another set of support safety stands under front sub-frame, remove two rear sub-frame retaining bolts. Lower rear of the front sub-frame to obtain access to stabilizer bar brackets (5486).
  1. Remove front stabilizer bar bracket bolts, stabilizer bar brackets, stabilizer bar bracket insulators and front stabilizer bar (5482) as required.
Installation
  1. Clean front stabilizer bar to remove dirt and contamination in area of stabilizer bar bracket insulator installation position.
  1. Lubricate inside diameter of new stabilizer bar bracket insulator with Rubber Suspension Insulator Lube E25Y-19553-A meeting Ford specification ESF-M99B112-A or equivalent. Do not use any mineral or petroleum based lubricants as they will deteriorate the rubber stabilizer bar bracket insulators.
  1. Install new stabilizer bar bracket insulators onto front stabilizer bar and position them in approximate location.
  1. Install stabilizer bar bracket on stabilizer bar bracket insulators and install new bolts. Tighten to 55-63 Nm (40-46 lb-ft).
  1. Raise front sub-frame and install new front sub-frame-to-body retaining bolts. Tighten to 115-132 Nm (85-97 lb-ft).
  1. Install front stabilizer bar link (5K483) to front shock absorber. Use care not to damage link ball joint boot seal.
    Install a new front stabilizer bar link-to-shock absorber nut. Tighten to 90-100 Nm (66-74 lb-ft).
Apr 28, 2010 | 1996 Ford Windstar
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
