Question about Cub Cadet Garden
What are signs of hyraulic problems
I have a Cub Cadet 3240 with approx. 500 hours. I use it to clear snow and I am starting to have issues. It is fine at start. After heavy use reverse sometimes reduces to half speed, hydraulic lift for blower is not as responsive at times and now rear diff is starting to slip a bit. Are my hydraulics starting to go out.
  • djgrider
    djgrider Feb 15, 2014
    I forgot to mention I changed all fluid and filter.
    New Friend:
  • 20 Answers
You have a leak some where that you loosened or un did is not properly attaced
Posted on Apr 14, 2014
4 Suggested Answers
SOURCE: John Deere 1020 Weak 3 point hydraulics
I would suggest you find a JD dealer and buy a manual if you want to do the maintenance yourself. You can also do a Google search and find manuals.
I would also suggest you completely drain the old hydraulic fluid and replace it with new fluid and a new filter if it has not been serviced any time in the recent past.
The symptoms you describe can be low fluid and/or a clogged filter. If you or anyone else has run the tractor too long and it has low fluids and/or a clogged filter, you can damage the hydraulic pump and that can get costly.
Posted on May 01, 2009
SOURCE: the electric clutch on my cub cadet lt1045 does not stay running
I had the exact same issue early this mowing season on a LT1045 with 184 hours on it. On a wild hunch I lifted the seat and simply sprayed the PTO shut-off safety switch with electronic contact cleaner/enhancer and have had to problems since.
Posted on Jun 14, 2010
SOURCE: JD 4020 Row Crop Tractor; No power Steering, No
In regard to the problem - JD 4020 Row Crop Tractor; No power Steering
What was the problem and how did you fix it I'm having a simlar problem
Posted on Oct 09, 2011
What type of oil do i use
(32 degrees and above, 30w oil) - (32 degrees to 0 degrees, 10w-30) - (32 degrees to -20 degrees below 0 and beyond -20, 5w-20 or 5w-30) Cub Cadets call for a low ash oil. it can be purchased at any cub cadet tractor dealership.
Jan 21, 2016 | Cub Cadet Snow Blowers. 28 in. Two-Stage...
My Cub Cadet just got serviced for another 500 bucks and is doing the same thing as last year. Ran it all day then it starts to sputter and stalls. Model GT 1554 HELP!
Make sure the fuel filler cap breather hole is clear if its blocked it will create a vacuum in the tank which prevents the fuel flowing forward.
May 25, 2015 | Cub Cadet Garden
Blowing white smoke
use a good gas additive and non ethynol gas
should clear it up
Dec 07, 2013 | Cub Cadet Snow Blowers. 26 in. Two-Stage...
How to replace ignition module on a cub cadet 3240
Sending a couple of drawings. Maybe they will help.
Nov 18, 2017 | Garden
Cub Cadet LT1050-Replaced the solenoid, had starter checked out-it's good, battery has full charge, but mower won't start. Help!!
You need to check that there is a 12volt supply from the low tention wire at the solinoid when the key is turned, if there is not either the switch is bad, or the wire from the switch is bad, or the fuse has blown.
Mar 04, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet 2165 Mower Shuts Down
did you happen to check the gas cap if the vent is clogged in it ? when it stalls loosen the gas cap and see if it makes a whoosh sound
Aug 31, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
