Question about Wheels, Tires & Parts for Toyota Cressida
On my 91 toyota mr2 if I change from 14 inch wheels to 15 inch wheels what size tires will I need to run
I just installed megan racing struts so I can adjust the ride height if necessary
    New Friend:
  • 35 Answers
There are a few variables with this question. How wide are they, and are you wanting to change the overall height of tire (not recommended)? Go to your tire store with your 14" tire and have them match the height with a 15" tire. Give them the width of your 15" wheels as well.
Posted on Feb 16, 2014
What is bolt pattern for 1986 mr2¿
have a read
Toyota MR2 1986 Wheel Tire Sizes PCD Offset and Rims specs
89 mr2 lug bolt pattern? - Toyota Nation Forum : Toyota Car and ...
www.toyotanation.com > ... > Toyota Passenger and Sports Car Forums > MR2 Forum
Dec 10, 2011 - My lil brother has a 89mr2, lookin to pick some rims up for him but i dunno what his lug bolt pattern is...ne1 now thanks? Im thinkin 4x100? 1991 Lug Pattern...
15 Dec 2011
what is the bolt pattern on a '91 MR2?
11 Dec 2011
4 bolt pattern on my cressida can it be done
10 Jan 2008
Bolt Pattern Question
27 Apr 2005
More results from www.toyotanation.com
Wheels for 1986 Toyota MR2 - Tire Rack
www.tirerack.com/wheels/results.jsp?autoMake=Toyota...MR2...1986... For your 1986 Toyota MR2 . The right fit. Always. Tire Rack makes it easy when you shop by vehicle.
Toyota Mr2 Wheels at Andy's Auto Sport
https://www.andysautosport.com/wheels/toyota_mr2.html Not every wheel can fit every Toyota Mr2 vehicle. In fact, there are dozens of different bolt patterns for wheels, which can make Toyota Mr2 wheel shopping difficult. It's the reason, in fact, that we at Andy's customized our website to only show you wheels that fit your vehicle -- so that you don't have to guess if a rim fits or not.
Toyota MR2 Wheels ' eBay
www.ebay.com/bhp/toyota-mr2-wheels Find great deals on eBay for Toyota MR2 Wheels in Wheels. Shop with ... 1991-1992 Toyota MR2 14" Staggered Aluminum Wheel Rims Set of 4 OEM. $299.00. Buy It Now. Bolt Pattern: 5x115. Rears: 14x7. .... 14X5.5" INCH TOYOTA MR2 1985 1986 1987 OEM Factory CHROME Wheel Rim 69204 (Fits: Toyota MR2).
Jan 01, 2018 | Cars & Trucks
I put 20" wheels on my chevy lumina & now I only have bout a 1" clearance between tires& strut. I can't afford a lift kit .how can I raise my struts up bout a inch or so.
put the original sized wheels back on it . you will mess up the mileage , possibly the tranny in the long run also .
Oct 18, 2016 | Cars & Trucks
I own a 2000 2.4 lt dodge caravan and rim siza is 14 " .but if I switch tenm for 15" will b a problem or they will not fit at all ?thanl
You can change the rim/tire size to 15 inch as long as the wheel stud pattern is the same. Your speedometer is calibrated for the 14 inch wheel so the speed showing on the speedometer will not be correct. You will be going faster than the speedometer reads
Nov 14, 2015 | Dodge Cars & Trucks
Tires for 92 bucik regal
If you have 15" mags, you will need 15" tires.
The way tire sizes work is as follows:
  • The first number (205) is the TREAD WIDTH in millimeters;
  • The second number (70) is the percentage of the specified tread width the measurement between the tread and the wheel is (which means that the distance between the tread and the wheel is 143.5mm).
  • The third number, 15, is the rim diameter in INCHES.
Do a little math and you can figure out the proper size tire for your vehicle with the after-market wheels you are using.
Aug 15, 2014 | Cars & Trucks
Will 235/70R/15 tires fit on a 91 ford taurus?
Thats a tall tire but it depends on the size tire/rims that are on it. I have a 91 taurus that has 14 inch rims, the only draw back on taller tires are the fender wells, make sure the tires do not rub the fenders. especially the front, if you put them on, turn the front wheels to the left, then check to feel or see that they do not rub. then turn wheels to the right and recheck for clearance. good luck, if the fit and clear.
Dec 29, 2010 | 1991 Ford Taurus
What tire sizes will fit toyota corolla 2002 ce
Usually a toyota corolla has 195/65R15 tires if it has 15 inch wheels. Some of the sport models have 16 inch wheels. Those sizes are 205/55R16. If you have any concerns all manufactures will post the Original Equipment sizes on the inside of the drivers side door jam.
Nov 16, 2010 | 2002 Toyota Corolla
Size of rims on my 2005 Dodge Grand Caravan
Read the side of the tire. It will read like P225-70- 15 the last number is the diameter of the wheel. 14=14 inches 15=15 inches and so on.
Nov 03, 2009 | 2005 Dodge Grand Caravan
Speedomoter reads consistenly 8miles per hour fater than i am actually going.
Check your tire size. This problem will happen if you go from a "70" series to a "60" series tire. It can happen going from a "15" inch to a "14" inch wheel.
Some mustangs had an odd "15.5" wheel and you would get the same problem going to a "15" inch.
There are electronic programmers to reset the speedometer. Check a good Tire store. Or you may have to change the speedo drive gear and get the next size with an extra tooth.
Sep 23, 2009 | 2003 Ford Mustang
Tire size
Front Tire Size P185/65R14 Rear Tire Size P185/65R14
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Apr 09, 2009 | 2002 Nissan Sentra
Wheels, Tires & Parts for Toyota Cressida Logo
Top Toyota Vehicle Parts & Accessories Experts
ashburton
Colin Stickland
Colin Stickland
jamie suver
Level 1 Expert
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
