Question about YouTube Videos
Pashto hot mast dANCE VIDEOS - YouTube Videos
How good can you dance
as good as you feel. there is no "set way " to dance. just move to how you feel. bored: slow moves .happy: jump about ..the best dance is one you make up on the night. practice in front of a mirror and if you like how it feels and looks then chances are some one will like it too
Apr 26, 2015 | HOW Video Game Consoles & Games
Dance moms you tube
It is unscripted, but like all "reality" shows, it is edited... http://dancemoms.wikia.com/wiki/Dance_Moms
Jun 30, 2014 | YouTube Videos
Language software 900
Hi
If you N900 phone's language is set to English by default, go to Menu - Settings - Language & Region - Device Language, then you select the language of your choice, click options and save... Good luck with this
Apr 07, 2014 | Nokia N900 Smartphone
My roomba makes a banging noise and goes around in circles
hi.
a roomba going round in circles is so common that it is known as the "circle dance" problem and there are videos on you tube showing you how to fix it, step by step. search for "roomba circle dance" on youtube.
i would not normally redirect you to another site, but these videos are clearer than any written instructions i can give here. watch a few of the videos as there are some slight differences to the basic problem and follow th eone that matches your symptons most closely.
hope this helps
Apr 17, 2011 | Vacuums
My utube keeps freezing while watching my line dancing videos its stops during the dance.
YouTube freeze can happen due to many reasons. Major reasons are overload on website, simultaneous running of many programs on your computer, Low RAM, Slow internet connection or corrupt windows registry.
For smooth watching of YouTube Videos take following actions:
1. Watch videos at off peak times, if possible
2. Do not run other programs while watching videos. They slow down computer in general by making use of memory.
3. Add RAM on your computer. More RAM will make easy execution of heavy programs on your system.
4. Get better and speedy internet connection. Talk to your ISP in this regard.
5. Regularly clean windows registry. Windows registry is vital place that stores information for important computing functions. A congested or corrupted windows registry makes computer slow that causes YouTube like freezes. For this, get the best registry cleaner reg in out and optimizer. Use it once in a fortnight for fast computing to avoid YouTube freezes and system slow down.
Nov 30, 2010 | YouTube Videos
Electric Radio Antenna on 1994 Toyota Celica
Reverse the wires, one is hot going up and the other hot going down, the easiest way to deal with this is to just reverse them.
Nov 29, 2008 | 1990 Toyota Celica
Running program difficulties
what was the actual error message that showed on your screen?
Either the problem is in the CD "Pashto level 1"that you've inserted or there is a missing file on the installation CD...try using a different copy first and if it doesn't fix it, try re-installing it...
Jul 24, 2008 | Rosetta Stone Pashto Level I Personal...
Installation of vt holden commodore aerial rope and mast
You access the ariel via the left hand wheel arch.
1. Remove left wheel mud guard. It is held in with a bunch of press studs which can be difficult to remove. I found pulling on the plastic mud guard whilst turning the screw helped.
2. unbolt the electric ariel assembly. There is an earth strap that needs to be unscrewed as well.
You should be able to get the ariel out far enough to work on it.
3. Remove chrome plated nut to top end of mast tube.
4. With great anger and force, remove the dead ariel and drive cable from the mast.
It's difficult to get the mast to work unless it's earthed properly.
5. Get you hand inside the wall and remove the ariel face plate. Swear if you have to.
6. Put the ariel mast assembly back into the wall and hook it all up minus the new ariel.
7. Switch your radio on, then put the new ariel into the mast. Gears facing the rear of the car. Switch the radio off, it should retract. If not you may need to push it in a little further.
8. Remove the ariel mast again and slip the chrome nut to top end of mast tube and tighten securely.
9. Ask the spouse to close up whilst you have a beer.
Apr 03, 2008 | Car Audio & Video
YouTube Videos Logo
12 people viewed this question
Top YouTube Computers & Internet Experts
Michael Terence...
Michael Terence...
Mike
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
