Question about Bolt. Air distributor. Engine air cooling. INSIDE/OUTSIDE rear
Wind is blowing rain aginst my out side wall to the interior wall its a cavity wall
    Problem Solver:
  • 7 Answers
You didn't say front or rear? But, if rear take the panel out of wall. Take your time, because if you break or tear, parts are expensive.
Usually a plastic shield is not glued or connected. If you can stretch and attach with contac cement, this should work. Or cut a piece of plastic from the hardware store about 1 to 2 inches more than you need and then attach, working from top to bottom. If the car is newer, this sounds like a production problem. Contact a dealer and see what they say.
Posted on Apr 18, 2014
Rinnai wall heater lights but in about 5 or 10 minutes makes a wind blowing noise and goes out. Including the pilot lite.
The model number would be nice to know! I am concerned about the way you say it is vented.
Dec 07, 2016 | Rinnai Heating & Cooling
Mercury marine
Could be blocked drain pipes for the sun roof; try blowing the out using compressed air or check the fire wall and the bottom of your wind shield for traces of water.
Sep 09, 2014 | 2007 Mercury Mariner Premier 4WD
Winding windows up and down does not clear rain drops
that would appear to be the problem , these seals are usually classed as weather strips , there main function is to stop water ingress to the door interior but usualy do clear window as you say , your choices are get new strips fitted and hope they are of the type that should clear window , perhaps contact a suzuki dealer and ask them if this is the case as may not be good luck
May 17, 2014 | 2010 Suzuki Alto 1.0
When it rains my 2005 chevy aveo floor fills up with water. I have cleaned out all vents and checked for leaks - but can find nothing. Please help me.
The waterchannels down from the roof to each side of the vehicle through the inside of the fenders, even though the vents are clear the channels to divert the water may be plugged. Look behind the fender (sounds impossible, but open the doors and look where the hinges are, you should be able to see somewhat behind the fenders, check for debris lodged within the cavity behind the fender, water can fill up and run back into the interior of the vehicle. A leaking door seal will also allow water to seep into the interior.
Apr 05, 2013 | 2005 Chevrolet Aveo
After a rain the drivers side interior carpet is soaked where is leak at
CHECK DOOR SEALS OR WIND SHIELD FOR LEAKS , GET IN CAR AND HAVE SOME ONE RUN A HOSE OVER THE CAR THAT MAY HELP SEE WHERE THER LEAK IS
Dec 21, 2011 | 1994 Geo Metro
The house I've just bought has a Smeg 60 cm wall oven installed. Possibly 4-5 yrs old. I can't get it to work. An orange light comes on on the door panel when the temp control is turned on. Light goes...
Most of these ovens have two fans. A fan forced fan in the oven and a cavity extractor fan inside the cavity of the unit between the outer skin and the oven wall. The cavity fan blows hot cavity air out the front of the unit so it remains cool. If the orange indicator light is coming on this would normally be the oven element thermostat. Leave it on and see if it gets hot. If the light goes off when you select the function switch it means you are turning it off the oven function. Your interior oven light may be blown.
Hope this helps.
Feb 07, 2011 | Smeg SE399X/5 Stainless Steel Electric...
The heater pilot goes out when the wind blows outside of the wall where the heater is installed. The heater is only six months old, so the thermo-couple is OK.
You mention that the thermocouple is OK, has it been changed or tested? This $4 part is usually the first thing to fail and I have found bad parts right out of the package. If I were you and I would contact the installing contractor to have them check out the following: Is the vent termination located as per manufacturing instructions (away from interior adjoining walls), Are the vent parts installed correctly, replace the thermocouple under the warranty, and check to make sure the pilot is both good and strong and it is hitting the thermocouple where it should. I have these heater installed on the top of Mount Washington where the wind blows at over 60 miles an hour and do not experience a pilot outage due to wind. The interior design of the venting system combats the wind effects. Good luck to you.
May 06, 2010 | Cozy (W352E) Heater
Lincoln navigator handles fine with no wind or rain present. With cross winds or light rain the navigator has unstable side to side ''jerky'' tendencies. Additionally, when passing box trucks and ''18...
you could try replacing the shock absorbers, use a stiffer/firmer shock. ( check out "bilstein" shocks). inspect the sway bars, look at the rubber mounts, make sure they are still in good condition. Or maybe install a aftermarket sway bar. also see if you can adjust the ride height of the suspension. I can adjust the ride height on my 89 Mark VII. up or down.
Oct 17, 2009 | 1999 Lincoln Navigator
I have an Ascot wall hanging hot water heater.The wind frequently blows out the pilot light. Can I make a safe housing around it to protect it from wind and rain
Yes you can, but make sure that it has access to air. Leave at least 6" of space between the shelter and the pilot. Is it outside? I've never seen one outside.
May 29, 2009 | Water Heaters
Bolt. Air distributor. Engine air cooling. INSIDE/OUTSIDE rear Logo
Top Buick Vehicle Parts & Accessories Experts
Marc Taylor
Thomas Perkins
Thomas Perkins
Jeff Turcotte
Jeff Turcotte
Are you a Buick Vehicle Part and Accessory Expert? Answer questions, earn points and help others
